07-16-2018, 14:19 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: PAKISTAN Age: 34
Member: 1082907 Status: Offline Sonork: 100.1606954 Thanks Meter: 342 | nokia 5 ta-1053 9008 |
07-16-2018, 17:29 | #2 (permalink) | ||
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | NTool only support working phones. it is no problem to repair boot of Nokia5 or any other Nokia, though. download ND1_BootFix.zip archive from NTool support area ( Nokia 5 firmwares ) and unpack it in some folder. then attach your phone with dead boot and make sure that drivers are installed, in device manager you should see "HS-USB Diagnostics 9008" in ports if not, install drivers from NTool drivers folder. ok, now, when you have proper drivers, reset phone ( hold power on + volume up until phone restarts ) and IMMEDIATELY after phone will be redetected by windows run as administrator Quote:
after you see success, run as administrator Quote:
after this phone should be detected as normal fastboot device and could be normally flashed by NTool however, if other tool damaged phone security partitions, phone will not get network ;( | ||
07-30-2018, 15:03 | #5 (permalink) |
Member: 9519 Status: Offline Thanks Meter: 2,150 | setool2 support all current sony models, at least flashing. alas, there is no any weakness in S1 security or i can't find any and we can not use sony equipment for sim unlock because it will be blocked in week time maximum ;( |
The Following User Says Thank You to the_laser For This Useful Post: |
07-30-2018, 15:10 | #6 (permalink) | |
No Life Poster Join Date: Aug 2015 Location: Bangladesh Age: 30
Member: 2443283 Status: Offline Thanks Meter: 518 | Quote:
07-30-2018, 16:56 | #7 (permalink) |
Member: 9519 Status: Offline Thanks Meter: 2,150 | this is not EDL mode, this is sahara ramdump mode and it is usually dead end - you can only fix this phone with EDL testpoint. however, there is very small chance, that you can enter fastboot mode via reset : hold volume up + power buttons for 10 seconds, probably phone will enter fastboot mode. |
