05-27-2019, 22:11 | #1 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 644581 Status: Offline Thanks Meter: 16 | Nokia 6.1 TA-1054 Code: RUNNING NTool 0.049 SELECT FIRMWARE PACKAGE Will flash : PL2-3270-0-00CN-00WW.NBx PLEASE CONNECT POWERED OFF PHONE PHONE "PL2GAM1811800045" CONNECTED Project : PL21 model : P2C sub_model : none software version : SW model : build number : hardware version : 5.0 RF band id : G_850_900_1800_1900^W_1_2_5_8^C_0^T_34_39^L_1_3_ secure : yes Bootloader type : commercial Download size : 00000384 mB Security version : 0004 Challenge : 04F21EB37B6BDC74C0C3BECE27CD5EA05E63CE2F Waiting for calculation process ... RESPONSE: "SUCCESS" [256] BOOTLOADER AUTH PASSED Flash "B2N-0-3270-xbl_service.zip" to "xbl_a" FATAL ERROR: Failed to write "xbl_a", error : "(xbl_a) No such partition" Elapsed: 2 secs. Last edited by the_laser; 05-28-2019 at 11:12. |
05-28-2019, 02:53 | #4 (permalink) |
Freak Poster Join Date: May 2018
Member: 2835334 Status: Offline Thanks Meter: 23 | Test point is only a solution...u can check if ur boot is ok or not... download minimal adb .....type fastboot devices See, if ur device recognize, then knock me... Telegram @juwelrana091 Sent from my TA-1054 using Tapatalk |
The Following User Says Thank You to juwelrana091 For This Useful Post: |
05-30-2019, 21:40 | #8 (permalink) |
Member: 644581 Status: Offline Thanks Meter: 16 | Hello again ... did test point but is starting direct in download mode. I took test point with Positive from battery like in Read Me file ..., put an 3.5 battery positive on that point and gnd to gnd ... still the same P.S. managed to save the display)) Any ideeas ? thanks |
05-30-2019, 23:07 | #9 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | you did something wrong. follow guide to the letter and all will be fine. for example, first disconnect phone from battery and usb cable, connect testpoint to +3.3 ( at least +1.8 ), then connect usb cable and detach testpoint if you using battery terminal, then you need to connect testpoint, attach battery, attach usb cable, detach testpoint . |
The Following User Says Thank You to the_laser For This Useful Post: |
06-04-2019, 21:31 | #10 (permalink) | |
Member: 644581 Status: Offline Thanks Meter: 16 | Quote:
Did: disconnect battery - Outside Power 3.3v - > connect battery -> connect USB - direct in download mode Same with battery terminal.... - Direct in download mode ... any other ideea ? | |
The Following User Says Thank You to spinky360 For This Useful Post: |
06-05-2019, 07:07 | #11 (permalink) | |
Member: 2835334 Status: Offline Thanks Meter: 23 | Quote:
Sent from my TA-1054 using Tapatalk | |
06-07-2019, 16:59 | #13 (permalink) |
Member: 2835334 Status: Offline Thanks Meter: 23 | First connect battery ,short 2 pin then connect usb with pc....check driver if show Qualcomm port 9008... update it to qloader 9008.then flash TA1054 stock firmware nbo format with emergency download mode.....it failed but dont worry...now try same firmware with ntool...it take flash Sent from my TA-1054 using Tapatalk |
06-07-2019, 18:41 | #15 (permalink) |
Member: 2835334 Status: Offline Thanks Meter: 23 | https://drive.google.com/file/d/11sX...w?usp=drivesdk Here is 2 pin for Short Sent from my TA-1054 using Tapatalk |
