Nokia 6.1 TA-1054 Code: RUNNING NTool 0.049 |
Dont flash this....it will brick ur device Sent from my TA-1054 using Tapatalk |
Test point is only a solution...u can check if ur boot is ok or not... download minimal adb .....type fastboot devices See, if ur device recognize, then knock me... Telegram @juwelrana091 Sent from my TA-1054 using Tapatalk |
the only solution : Nokia6.Plate2.PL2/BootFix |
Hello again ... did test point but is starting direct in download mode. I took test point with Positive from battery like in Read Me file ..., put an 3.5 battery positive on that point and gnd to gnd ... still the same P.S. managed to save the display:))) Any ideeas ? thanks |
you did something wrong. follow guide to the letter and all will be fine. for example, first disconnect phone from battery and usb cable, connect testpoint to +3.3 ( at least +1.8 ), then connect usb cable and detach testpoint if you using battery terminal, then you need to connect testpoint, attach battery, attach usb cable, detach testpoint . |
Did: disconnect battery - Outside Power 3.3v - > connect battery -> connect USB - direct in download mode Same with battery terminal.... - Direct in download mode ... any other ideea ? |
First connect battery ,short 2 pin then connect usb with pc....check driver if show Qualcomm port 9008... update it to qloader 9008.then flash TA1054 stock firmware nbo format with emergency download mode.....it failed but dont worry...now try same firmware with ntool...it take flash Sent from my TA-1054 using Tapatalk |
https://drive.google.com/file/d/11sX...w?usp=drivesdk Here is 2 pin for Short Sent from my TA-1054 using Tapatalk |
