Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NTool by Setool Team
Old 05-27-2019, 22:11   #1 (permalink)
Member: 644581
Thanks Meter: 16
Nokia 6.1 TA-1054
RUNNING NTool 0.049
SELECT FIRMWARE PACKAGE
Will flash : PL2-3270-0-00CN-00WW.NBx
PLEASE CONNECT POWERED OFF PHONE
PHONE "PL2GAM1811800045" CONNECTED
Project : PL21
model : P2C
sub_model : none
software version :
SW model :
build number :
hardware version : 5.0
RF band id : G_850_900_1800_1900^W_1_2_5_8^C_0^T_34_39^L_1_3_
secure : yes
Bootloader type : commercial
Download size : 00000384 mB
Security version : 0004
Challenge : 04F21EB37B6BDC74C0C3BECE27CD5EA05E63CE2F
Waiting for calculation process ...
RESPONSE: "SUCCESS" [256]
BOOTLOADER AUTH PASSED
Flash "B2N-0-3270-xbl_service.zip" to "xbl_a"
FATAL ERROR: Failed to write "xbl_a", error : "(xbl_a) No such partition"
Elapsed: 2 secs.
Any Help ?
Old 05-27-2019, 22:46   #2 (permalink)
Member: 2835334
Thanks Meter: 23
Dont flash this....it will brick ur device
Sent from my TA-1054 using Tapatalk
The Following User Says Thank You to juwelrana091 For This Useful Post:
Old 05-27-2019, 23:43   #3 (permalink)
Member: 644581
Thanks Meter: 16
Is already bircked ... is just in download mode and wont exit... there isnt nothing except testpoint ?
Old 05-28-2019, 02:53   #4 (permalink)
Member: 2835334
Thanks Meter: 23
Test point is only a solution...u can check if ur boot is ok or not... download minimal adb .....type fastboot devices
See, if ur device recognize, then knock me...
Telegram @juwelrana091
Old 05-28-2019, 07:30   #5 (permalink)
Member: 644581
Thanks Meter: 16
Bootloader is ok. i cant add you on telegream. if you have skype or soething
Old 05-28-2019, 11:12   #6 (permalink)
Member: 9519
Thanks Meter: 2,150
the only solution : Nokia6.Plate2.PL2/BootFix
The Following User Says Thank You to the_laser For This Useful Post:
Old 05-28-2019, 11:42   #7 (permalink)
Member: 2835334
Thanks Meter: 23
Bootfix https://drive.google.com/file/d/1RjB...w?usp=drivesdk
The Following 2 Users Say Thank You to juwelrana091 For This Useful Post:
Old 05-30-2019, 21:40   #8 (permalink)
Member: 644581
Thanks Meter: 16
Hello again ... did test point but is starting direct in download mode.
I took test point with Positive from battery like in Read Me file ..., put an 3.5 battery positive on that point and gnd to gnd ... still the same
P.S. managed to save the display))
Any ideeas ? thanks
Old 05-30-2019, 23:07   #9 (permalink)
Member: 9519
Thanks Meter: 2,150
you did something wrong.
follow guide to the letter and all will be fine.
for example, first disconnect phone from battery and usb cable, connect testpoint to +3.3 ( at least +1.8 ), then connect usb cable and detach testpoint
if you using battery terminal, then you need to connect testpoint, attach battery, attach usb cable, detach testpoint .
Old 06-04-2019, 21:31   #10 (permalink)
Member: 644581
Thanks Meter: 16
Nothing is working
Did: disconnect battery - Outside Power 3.3v - > connect battery -> connect USB - direct in download mode
Same with battery terminal.... - Direct in download mode ...
any other ideea ?
The Following User Says Thank You to spinky360 For This Useful Post:
Old 06-05-2019, 07:07   #11 (permalink)
Member: 2835334
Thanks Meter: 23
Originally Posted by spinky360 View Post
Nothing is working
any other ideea ?
Knock me...i faced same problem... And i solved it by myself
Old 06-07-2019, 00:06   #12 (permalink)
Member: 644581
Thanks Meter: 16
Could you pleas post the solution here ? there are other ppl like me ... this is why we are a forum ... Thanks
Old 06-07-2019, 16:59   #13 (permalink)
Member: 2835334
Thanks Meter: 23
First connect battery ,short 2 pin then connect usb with pc....check driver if show Qualcomm port 9008... update it to qloader 9008.then flash TA1054 stock firmware nbo format with emergency download mode.....it failed but dont worry...now try same firmware with ntool...it take flash
Old 06-07-2019, 17:01   #14 (permalink)
Member: 2835334
Thanks Meter: 23
https://drive.google.com/file/d/11sX...w?usp=drivesdk
Old 06-07-2019, 18:41   #15 (permalink)
Member: 2835334
Thanks Meter: 23
Here is 2 pin for Short
Page generated in 0.21232 seconds with 8 queries
