Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NTool by Setool Team
Old 02-16-2019, 21:51   #16 (permalink)
Member: 6142
Sonork: i dont use it
Thanks Meter: 47
For repair using testpoint method need battery connected or enough +3.3 v to testpont and connect to pc?
Old 02-17-2019, 14:50   #17 (permalink)
Member: 9519
Thanks Meter: 2,150
connected battery not required for boot repair.
it is enough to connect marked testpoint with any +3.3 ( in fact, +1.8 is enough ) source, then insert usb cable - if you do all properly, phone will connect in EDL mode
check Guide.txt for more detailed instructions
Old 02-18-2019, 14:51   #18 (permalink)
Member: 6142
Thanks Meter: 47
Hi.
Edl mode is ok now, i got this, when i run load_fh cmd:
3. Qualcomm HS-USB QDLoader 9008 is COM14.
c:\Documents and Settings\user\Dokumentumok\Downloads\Ta-1054 bootfix>QSaharaSer
ver.exe -p \\.\COM14 -s 13:c:\Documents and Settings\user\Dokumentumok\Downloads
\Ta-1054 bootfix\B2N-0-2230-prog_emmc_ufs_firehose_Sdm660_ddr.elf
Binary build date: Oct 31 2016 @ 22:51:05
QSAHARASERVER CALLED LIKE THIS: 'QSaharaServer.ex'Current working dir: c:\Docume
Sahara mappings:
2: amss.mbn
6: apps.mbn
8: dsp1.mbn
10: dbl.mbn
11: osbl.mbn
12: dsp2.mbn
16: efs1.mbn
17: efs2.mbn
20: efs3.mbn
21: sbl1.mbn
22: sbl2.mbn
23: rpm.mbn
25: tz.mbn
28: dsp3.mbn
29: acdb.mbn
30: wdt.mbn
31: mba.mbn
13: c:\Documents
14:47:09: ERROR: function: find_file:110 Could not find the file 'c:\Documents',
returning NULL
14:47:10: ERROR: function: sahara_start:495 2. Matching input image for ID 13 no
t found
14:47:10: ERROR: function: sahara_main:924 Sahara protocol error
14:47:10: ERROR: function: main:303 Uploading Image using Sahara protocol faile
d
A folytatáshoz nyomjon meg egy billentyűt . . .
If i run again load_fs cmd, than i got this :
Sahara mappings:
2: amss.mbn
6: apps.mbn
8: dsp1.mbn
10: dbl.mbn
11: osbl.mbn
12: dsp2.mbn
16: efs1.mbn
17: efs2.mbn
20: efs3.mbn
21: sbl1.mbn
22: sbl2.mbn
23: rpm.mbn
25: tz.mbn
28: dsp3.mbn
29: acdb.mbn
30: wdt.mbn
31: mba.mbn
13: c:\Documents
14:50:49: ERROR: function: sahara_rx_data:237 Unable to read packet header. Only
read 0 bytes.
14:50:49: ERROR: function: sahara_main:924 Sahara protocol error
14:50:49: ERROR: function: main:303 Uploading Image using Sahara protocol faile
d
What is wrong??
Old 02-18-2019, 15:34   #19 (permalink)
Member: 9519
Thanks Meter: 2,150
unpack package to c:\bootfix
Old 02-18-2019, 17:27   #20 (permalink)
Member: 6142
Thanks Meter: 47
Thx for a lot of help Mr. Laser! Finally i repaired my phone. Anyway very interesting phone was dead not by flashing Ntool ( that was succesfull and phone works good). After got softwareupdate through wifi, and phone gone to download mode and it wasnot possible flashing anymore by normal usb mode.
Old 02-18-2019, 17:30   #21 (permalink)
Member: 9519
Thanks Meter: 2,150
it is normal behavior for "converted" 0CN phone to 0WW
once it will get OTA update - bye-bye, display module and welcome, testpoint.
The Following User Says Thank You to the_laser For This Useful Post:
Page generated in 0.13711 seconds with 9 queries
