02-17-2019, 14:50 | #17 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | connected battery not required for boot repair. it is enough to connect marked testpoint with any +3.3 ( in fact, +1.8 is enough ) source, then insert usb cable - if you do all properly, phone will connect in EDL mode check Guide.txt for more detailed instructions |
02-18-2019, 14:51 | #18 (permalink) |
No Life Poster Join Date: Sep 2001 Location: Hungary, Pécs Age: 48
Member: 6142 Status: Offline Sonork: i dont use it Thanks Meter: 47 | Hi. Edl mode is ok now, i got this, when i run load_fh cmd: 3. Qualcomm HS-USB QDLoader 9008 is COM14. c:\Documents and Settings\user\Dokumentumok\Downloads\Ta-1054 bootfix>QSaharaSer ver.exe -p \\.\COM14 -s 13:c:\Documents and Settings\user\Dokumentumok\Downloads \Ta-1054 bootfix\B2N-0-2230-prog_emmc_ufs_firehose_Sdm660_ddr.elf Binary build date: Oct 31 2016 @ 22:51:05 QSAHARASERVER CALLED LIKE THIS: 'QSaharaServer.ex'Current working dir: c:\Docume nts and Settings\user\Dokumentumok\Downloads\Ta-1054 bootfix Sahara mappings: 2: amss.mbn 6: apps.mbn 8: dsp1.mbn 10: dbl.mbn 11: osbl.mbn 12: dsp2.mbn 16: efs1.mbn 17: efs2.mbn 20: efs3.mbn 21: sbl1.mbn 22: sbl2.mbn 23: rpm.mbn 25: tz.mbn 28: dsp3.mbn 29: acdb.mbn 30: wdt.mbn 31: mba.mbn 13: c:\Documents 14:47:09: ERROR: function: find_file:110 Could not find the file 'c:\Documents', returning NULL 14:47:10: ERROR: function: sahara_start:495 2. Matching input image for ID 13 no t found 14:47:10: ERROR: function: sahara_main:924 Sahara protocol error 14:47:10: ERROR: function: main:303 Uploading Image using Sahara protocol faile d A folytatáshoz nyomjon meg egy billentyűt . . . If i run again load_fs cmd, than i got this : 3. Qualcomm HS-USB QDLoader 9008 is COM14. c:\Documents and Settings\user\Dokumentumok\Downloads\Ta-1054 bootfix>QSaharaSer ver.exe -p \\.\COM14 -s 13:c:\Documents and Settings\user\Dokumentumok\Downloads \Ta-1054 bootfix\B2N-0-2230-prog_emmc_ufs_firehose_Sdm660_ddr.elf Binary build date: Oct 31 2016 @ 22:51:05 QSAHARASERVER CALLED LIKE THIS: 'QSaharaServer.ex'Current working dir: c:\Docume nts and Settings\user\Dokumentumok\Downloads\Ta-1054 bootfix Sahara mappings: 2: amss.mbn 6: apps.mbn 8: dsp1.mbn 10: dbl.mbn 11: osbl.mbn 12: dsp2.mbn 16: efs1.mbn 17: efs2.mbn 20: efs3.mbn 21: sbl1.mbn 22: sbl2.mbn 23: rpm.mbn 25: tz.mbn 28: dsp3.mbn 29: acdb.mbn 30: wdt.mbn 31: mba.mbn 13: c:\Documents 14:50:49: ERROR: function: sahara_rx_data:237 Unable to read packet header. Only read 0 bytes. 14:50:49: ERROR: function: sahara_main:924 Sahara protocol error 14:50:49: ERROR: function: main:303 Uploading Image using Sahara protocol faile d A folytatáshoz nyomjon meg egy billentyűt . . . What is wrong?? |
02-18-2019, 17:27 | #20 (permalink) |
Member: 6142 Status: Offline Sonork: i dont use it Thanks Meter: 47 | Thx for a lot of help Mr. Laser! Finally i repaired my phone. Anyway very interesting phone was dead not by flashing Ntool ( that was succesfull and phone works good). After got softwareupdate through wifi, and phone gone to download mode and it wasnot possible flashing anymore by normal usb mode. |
02-18-2019, 17:30 | #21 (permalink) |
Member: 9519 Status: Offline Thanks Meter: 2,150 | it is normal behavior for "converted" 0CN phone to 0WW once it will get OTA update - bye-bye, display module and welcome, testpoint. |
The Following User Says Thank You to the_laser For This Useful Post: |
