Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NTool by Setool Team
Old 08-20-2018, 10:23   #16 (permalink)
Member: 694226
Server is down, how to make it work?
I have sent you private messages but you didn't reply
Old 08-20-2018, 13:39   #17 (permalink)
Member: 9519
Thanks Meter: 2,150
NTool server working okay.
solve problems on your PC.
Old 08-24-2018, 23:23   #18 (permalink)
Member: 950756
Sonork: Adan JMZ
Same error??
RUNNING NTool 0.037
PLEASE CONNECT POWERED OFF PHONE
PHONE "PLEGAR27C0300309" CONNECTED
ProjectCode : PLE1
model : PLS
sub_model : none
software version : PLE-558E-0-00WW-B01
SW model : 00WW
build number : B01
hardware version : 5.2
RF band id :
_850_900_1800_1900^W_1_2_4_5_8^L_2_3_4_7_12_17_28_38
chip version : none
MCP info : none
EMMC version : Unknown 5.1 32GB
secure : yes
Bootloader type : commercial
Download size : 00000511 mB
Security version : 0004
Challenge : 1b0835ac797bd424eac1af69ca2093ffdb5d4d82
Waiting for calculation process ...
RESPONSE: "UNSUPPORTED MODEL PLE1" [0]
server error: unspecified server error [0x1B]
FATAL ERROR: server error: No server found.
Elapsed: 4 secs.
Old 08-25-2018, 11:25   #19 (permalink)
Member: 9519
Thanks Meter: 2,150
HMD introduced new securuty : UNSUPPORTED MODEL PLE1
NTool do not support new HMD security.
workaround could be done via manual old FOTA update installation via recovery and sdcard.
Old 08-25-2018, 12:57   #20 (permalink)
Member: 87188
Thanks Meter: 227
Same problem.
PLE1 no on, only recovery menu.
138mb update zip not help
Is there a full OTA zip?
SERVER CREDITS LEFT/USED: 90/110
Elapsed: 0 secs.
SELECT FIRMWARE PACKAGE
Will flash : PLE-560C-0-00WW-B01_Android_8.1.0.NBx
PHONE "PLEGAR1790719098" CONNECTED
ProjectCode : PLE1
model : PAD
sub_model : none
SW model : 00WW
build number : B01
hardware version : 5.1
RF band id :
_850_900_1800_1900^W_1_2_5_8^L_1_3_5_7_8_20_28_38_ 40
chip version : none
MCP info : none
EMMC version : Hynix 5.1 32GB
secure : yes
Challenge : a5c17fa18243935442c91cf372ce4155042ec5de
Elapsed: 0 secs.
Old 08-25-2018, 13:07   #21 (permalink)
Member: 9519
Thanks Meter: 2,150
OTA package should be old enough and contain bootloader files.
after OTA update attempt ( it WILL be unsuccessfull ) reflash phone using NTool
The Following 2 Users Say Thank You to the_laser For This Useful Post:
Old 08-25-2018, 13:25   #22 (permalink)
Member: 87188
Thanks Meter: 227
Oh, I have not heard that.
And it works!
Thanks! (again)
ProjectCode : PLE
model : PAD
sub_model : none
software version : PLE-5580-0-00WW-B01
SW model : 00WW
build number : B01
RF band id :
chip version : none
MCP info : none
secure : yes
Challenge : a27452f967bbe3ecb15a3cc304a51d97378375a1
RESPONSE: "SUCCESS" [256]
BOOTLOADER AUTH PASSED
Flash "D1C-0-560C-emmc_appsboot_service.zip" to "aboot"
PHONE "PLEGAR1790719098" REMOVED
Perform auth routine
ProjectCode : PLE
UID : ed4bc55a01255caf4a8783245843692f179e42cb
SERVICE AUTH PASSED
Flash "PLE-0-3140-gpt_both0.bin" to "partition"
Skip flashing "D1C-0-560C-emmc_appsboot_service.mbn"
Flash "D1C-0-560C-rpm.mbn" to "rpm"
Flash "D1C-0-560C-rpm.mbn" to "rpmbak"
Flash "D1C-0-560C-sbl1.mbn" to "sbl1"
Flash "D1C-0-560C-sbl1.mbn" to "sbl1bak"
Flash "D1C-0-560C-tz.mbn" to "tz"
Flash "D1C-0-560C-tz.mbn" to "tzbak"
Flash "D1C-0-560C-hwcfg.img" to "hwcfg"
Flash "D1C-0-560C-adspso.bin" to "dsp"
Flash "D1C-0-560C-cmnlib.mbn" to "cmnlib"
Flash "D1C-0-560C-cmnlib.mbn" to "cmnlibbak"
Flash "D1C-0-560C-cmnlib64.mbn" to "cmnlib64"
Flash "D1C-0-560C-cmnlib64.mbn" to "cmnlib64bak"
Flash "D1C-0-560C-devcfg.mbn" to "devcfg"
Flash "D1C-0-560C-devcfg.mbn" to "devcfgbak"
Flash "D1C-0-560C-keymaster.mbn" to "keymaster"
Flash "D1C-0-560C-keymaster.mbn" to "keymasterbak"
Perform fastboot command "reboot-bootloader"
Perform fastboot command "oem alive"
ProjectCode : PLE
SERVICE AUTH PASSED
Flash "PLE-00WW-013-splash.img" to "splash"
Flash "D1C-0-560C-ftm.img" to "ftmboot"
Flash "PLE-00WW-013-multi-splash.img" to "multi_splash"
Flash "PLE-0-560C-00WW-boot.img" to "boot"
Flash "PLE-0-560C-00WW-system.img" to "system"
Flash "PLE-0-560C-00WW-recovery.img" to "recovery"
Erase "userdata"
Erase "logdump"
Flash "D1C-0-560C-00WW-persist.img" to "persist"
Erase "cache"
Flash "PLE-00WW-001-sutinfo.img" to "sutinfo"
Flash "D1C-0-560C-NON-HLOS.bin" to "modem"
Flash "PLE-0-0010-0001-hidden.img.ext4" to "hidden"
Flash "PLE-00WW-013-cda.img" to "cda"
Flash "fver" to "systeminfo"
Flash "PLE-0-1010-0001-userdata-ftm.img.ext4" to "ftmlog"
Flash "D1C-0-560C-NV-default.mbn" to "default_nv"
Flash "D1C-0-560C-sec.dat" to "sec"
Flash "D1C-0-560C-00WW-mdtp.img" to "mdtp"
ProjectCode : PLE
SERVICE AUTH PASSED
Flash "D1C-0-560C-emmc_appsboot.mbn" to "aboot"
Flash "D1C-0-560C-emmc_appsboot.mbn" to "abootbak"
Flash "md5.dat" to "md5"
FINISHED
Elapsed: 536 secs.
Old 08-25-2018, 13:30   #23 (permalink)
Member: 9519
Thanks Meter: 2,150
btw,
Nokia 5 ( ND1 ), Nokia 6 ( PLE ), Nokia 6 ( D1C ) are basically same phones, so one can use one suitable OTA package ( i'm used, for example, Nokia5_June2017_Update.zip on Nokia 6 PLE )
however it is quite hard to enter recovery menu
Old 08-25-2018, 13:38   #24 (permalink)
Member: 87188
Thanks Meter: 227
This is interesting.
I was lucky with the recovery menu.
just came in, just to that, did not do anything else :-)
Old 09-01-2018, 01:41   #25 (permalink)
Member: 2753871
nokia 6
my phone is nokia 6 i cant make imei it says unsoported model it has the august patch 2018 is there going to be a new update for this problem i don want to risk to downgrade my phone already buyed the credits i unloicked it but got my signal down
Old 09-01-2018, 13:53   #26 (permalink)
Member: 9519
Thanks Meter: 2,150
one day new HMD security will be supported for sure.
no ETA, though.
p.s.
there are no any risks with downgrade via OTA package.
Old 09-01-2018, 20:37   #27 (permalink)
Member: 2753871
where can i download the ota the firmware to do the downgrade i am new whith the tool first time using it thanks again for the reply
Old 09-02-2018, 10:20   #28 (permalink)
Member: 9519
Thanks Meter: 2,150
OTA downgrade package for Nokia 5 ND1, Nokia 6 PLE, Nokia 6 D1C avalable on NTool support area.
The Following User Says Thank You to the_laser For This Useful Post:
Old 09-02-2018, 18:00   #29 (permalink)
Member: 2753871
Where is support area??????
Old 09-03-2018, 05:15   #30 (permalink)
Member: 2753871
nokia 6 august 2018 security
thans alot setool team i was nervous about the downgread but was 100 porcent succesful i downloaded the ota of nokia 5 flashed and then iit let me flash the july update and then it let me repair my signal thanks alot i 100 porcent recommend the tool
Page generated in 0.24411 seconds with 9 queries
