Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NTool by Setool Team
Old 07-31-2018, 20:13   #16 (permalink)
Member: 9519
Thanks Meter: 1,944
NTool v0.037
- Fixed issue, when original IMEI was restored after OTA update.
Just rewrite required IMEI1/IMEI2 with this version, no credits required ( account balance should be non-zero )
The Following 5 Users Say Thank You to the_laser For This Useful Post:
Old 08-18-2018, 17:50   #17 (permalink)
GsmEasy's Avatar
Member: 608359
Sonork: 100.1576815
Thanks Meter: 6,254
Added to NTOOL support unlock NOKIA 3310_3g , 3310_4g and 8110 by imei!
How to enter my Unlock Code on Nokia 3310_3g , 3310_4g , 8110?
1 - Switch ON your phone without SIM Card
2 - Compose #PW+YOURCODEHERE+1# or Compose #PW+YOURCODEHERE+7#
The letter P appear after press 3 times quickly the button star ( * )
The letter W appear after press 4 times quickly the button star ( * )
The letter + appear after press 2 times quickly the button star ( * )
The Following 7 Users Say Thank You to GsmEasy For This Useful Post:
Old 09-29-2018, 00:25   #18 (permalink)
Member: 9519
Thanks Meter: 1,944
NTool v0.038
- Nokia 2.1 support added
- Nokia 5.1 support added
The Following 3 Users Say Thank You to the_laser For This Useful Post:
Old 09-29-2018, 14:59   #19 (permalink)
Member: 9519
Thanks Meter: 1,944
regarding new HMD security.
if phone new security ( identify in NTool, Project Code is xxx1 ) - then you need to downgrade security using OTA update via recovery and sdcard, otherwise you will not be able to flash/service/unlock bootloader of thise phone using NTool.
for PLE, D1C, ND1 phones ( Nokia 5, Nokia 6 ) you can use Nokia5_June2017_Update.zip
put file on sdcard, enter recovery, apply update, wait for error, then unlock bootloader and reflash phone.
for Nokia 6.1, Nokia 7, Nokia 7 plus, Nokia 8, Nokia 8 Sirocco, Nokia X6 currently there is no solution, but we working on it.
The Following 6 Users Say Thank You to the_laser For This Useful Post:
Old 11-04-2018, 03:32   #20 (permalink)
Member: 9519
Thanks Meter: 1,944
Warning.
if you have flashed chinese vearant of Nokia 6.1 ( Model P2C ) to WW variant with special fimrware ( 00CN-00WW ), then DO NOT accept OTA update, otherwise phone will be killed and repair via disassembly and testpoint will be required.
The Following 2 Users Say Thank You to the_laser For This Useful Post:
Old 11-16-2018, 15:09   #21 (permalink)
Member: 9519
Thanks Meter: 1,944
NTool v0.040
- Nokia 5.1 Plus support added
- Nokia 7.1 support added
The Following 7 Users Say Thank You to the_laser For This Useful Post:
Old 01-20-2019, 22:58   #22 (permalink)
Member: 9519
Thanks Meter: 1,944
Important !
If you have nokia 5.1 plus phone with firmare 2.xxx (android 9) DO NOT perform service/reset frp functions - phone wil became brick.
we will release fix and support for 2.xxx firmwares soon.
you can check firmware version with identify function.
The Following 4 Users Say Thank You to the_laser For This Useful Post:
Old 01-21-2019, 04:58   #23 (permalink)
Member: 9519
Thanks Meter: 1,944
NTool v0.043
- Nokia 3.1 Plus support added
- fixed Nokia 5.1 Plus FRP reset/Service functions with 2.xxx ( Android 9 ) firmwares
Old 01-21-2019, 05:03   #24 (permalink)
Member: 9519
Thanks Meter: 1,944
if you have bricked Nokia 5.1 Plus phone using FRP/Service functions and NTool<0.043,
here is how to fix it :
1. download from NTool support area Nokia 5.1 Plus folder archive BootFix.zip
2. unpack it to any folder, better c:\bootfix
3. follow README.TXT inside extracted folder
if you want to DOWNGRADE Nokia 5.1 plus phone with Android 9 firmware ( ver 2.xxx )
then you MUST flash PDA_2XXX_Downgrade.NBx file first, then you are free to flash lower firmware versions.
Otherwise you will need to repair boot.
Old 02-01-2019, 18:29   #25 (permalink)
Member: 9519
Thanks Meter: 1,944
NTool v0.044
- fixed Nokia 5/6 FRP reset with 6.xxx ( Android 9 ) firmwares. Service for this firmware version not available, you need to downgrade.
if you have bricked Nokia 5/6 phone using FRP/Service functions and NTool<0.044,
start FRP operation, then connect phone to cable and enter download mode next way :
hold volume up+volume down+power, after few seconds phone will vibrate and restart, still hold keys, and IMMEDIATELY after second vibrate release all buttons
Old 02-19-2019, 05:28   #26 (permalink)
Member: 9519
Thanks Meter: 1,944
NTool v0.045
- Nokia 8.1 ( Nokia X7 ) support added.
if you wish to convert chinese Nokia X7 to global, you must change SKUID to 600WW.
Old 03-13-2019, 16:10   #27 (permalink)
Member: 9519
Thanks Meter: 1,944
Important !
If you have nokia 3.1 plus phone with firmare 2.xxx (android 9) DO NOT perform service/reset frp functions - phone wil became brick.
Old 03-18-2019, 17:58   #28 (permalink)
Member: 9519
Thanks Meter: 1,944
If you have nokia 3.1 phone with firmare 3.xxx (android 9) DO NOT perform service/reset frp functions - phone wil became brick.
bootfix uploaded on support area.
If you have nokia 5.1 phone with firmare 3.xxx (android 9) DO NOT perform service/reset frp functions - phone wil became brick.
we will release support for 3.xxx firmwares soon.
Old 03-20-2019, 13:01   #29 (permalink)
Member: 9519
Thanks Meter: 1,944
NTool v0.046
- fixed Nokia 3.1 FRP reset with 3.xxx ( Android 9 ) firmwares. Service for this firmware version not available, you need to downgrade. Before flashing Android 8.x firmware, you MUST flash ES2_Downgrade_Android_P.NBx package
- fixed Nokia 3.1 Plus FRP reset with 2.xxx ( Android 9 ) firmwares. If you want to flash Android 8.x firmware, you MUST flash ROO_Downgrade_Android_P.NBx package first.
if you have bricked Nokia 3.1/3.1 plus /5.1 phone using FRP/Service functions and NTool<0.046,
download bootfix package from support site, unpack it to some folder, then run flash_tool.exe, press only "download" button, then connect damaged phone to cable while pressing both volume up+volume down buttons. Sometimes it can't boot properly from first time, just disconnect phone, press "download" button again and connect phone same way as before.
Old 04-11-2019, 13:02   #30 (permalink)
Member: 9519
Thanks Meter: 1,944
NTool v0.047
- support for Nokia 5.1 3.xxx ( Android 9 ) firmwares enabled. If you want downgrade phone to Android 8.x firmware, you MUST flash CO2_Downgrade_Android_P.NBx package
- support for Nokia 2.1 1.xxx ( Android 9 ) firmwares enabled
- service support for Nokia 3.1 3.xxx ( Android 9 ) firmwares enabled
Page generated in 0.38882 seconds with 7 queries
