10-22-2018, 16:34 | #2 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | NTool server working okay 100% - you using wrong password and server blocked your IP after few wrong login attempts. wait 30 minutes, use proper password and all will be fine. note, that if you generated new password, you need to use new password. new password written automatically in ini file and could be found in session logs. |
The Following User Says Thank You to the_laser For This Useful Post: |
10-23-2018, 01:21 | #3 (permalink) |
Junior Member Join Date: Jan 2016 Location: Ecuador
Member: 2522260 Status: Offline Sonork: 1503 Thanks Meter: 3 | I continue with the problem, now I buy another license and it marks me the same error. Can somebody help me? Last edited by josepilamunga; 10-23-2018 at 01:27. |
10-23-2018, 01:52 | #4 (permalink) |
Member: 2522260 Status: Offline Sonork: 1503 Thanks Meter: 3 | The problem is that even with a new account that buys I still have the same error does not work. my pc is already cleaned and still with the same error |
10-23-2018, 17:58 | #5 (permalink) |
Member: 9519 Status: Offline Thanks Meter: 2,150 | wait 30 minuites, IP ban will be lifted, only then try with valid username/password also, show me your username, so i'll check and tell you exactly if you ever changed password or someone sold you account with changed password |
