12-18-2018, 19:40 | #21 (permalink) |
Freak Poster Join Date: Jul 2012 Location: Costa Rica
Member: 1790061 Status: Offline Thanks Meter: 63 | Detect cpu : OK ! Make xml : OK ! Reading modem... OK ! Reading sbl1... OK ! Reading sbl1bak... OK ! Reading aboot... OK ! Reading abootbak... OK ! Reading rpm... OK ! Reading rpmbak... OK ! Reading tz... OK ! Reading tzbak... OK ! Reading hyp... OK ! Reading hypbak... OK ! Reading pad... OK ! Reading modemst1... OK ! Reading modemst2... OK ! Reading misc... OK ! Reading fsc... OK ! Reading ssd... OK ! Reading splash... OK ! Reading DDR... OK ! Reading fsg... OK ! Reading sec... OK ! Reading boot... OK ! Reading system... OK ! Reading persist... OK ! Reading cache... OK ! Reading recovery... OK ! Reading keystore... OK ! Reading config... OK ! Reading oem... OK ! Reading PrimaryGPT... OK ! Reset phone : OK ! |
The Following 2 Users Say Thank You to YisusCell For This Useful Post: |
01-21-2019, 08:55 | #23 (permalink) |
Insane Poster Join Date: Jan 2019
Member: 2889927 Status: Offline Thanks Meter: 55 | Huawei Y625 Repair imei Succesfuly Code: Select port : COM189 Open port : OK ! Check device : OK ! Read Info : OK ! Build : Mar 29 201711:56:45Oct 29 201504:00:00BAAAANWZ Realese : 8x10_PL190335_20141120 Imei 1 : 86244702297.... Imeı repair step 1 : OK ! Imeı repair step 2 : OK ! Imeı repair step 3 : OK ! Reset : OK ! If the device has not restarted, please start it manually ! |
The Following User Says Thank You to solution_gsm For This Useful Post: |
01-21-2019, 09:52 | #24 (permalink) |
Member: 2889927 Status: Offline Thanks Meter: 55 | NOKIA 8 FRP RESET DONE BY GRT Dongle Code: Make tmp file : OK ! Start adb : OK ! Detect device : ONE Read info : OK ! Brand name : [NOKIA] Model name : [TA-1004] Android version : [8.1.0] Reset frp : OK ! |
01-21-2019, 13:14 | #25 (permalink) |
Member: 2889927 Status: Offline Thanks Meter: 55 | NOKIA 6 TA-1021 8.1.0 FRP Reset Done Code: Make tmp file : OK ! Start adb : OK ! Detect device : ONE Read info : OK ! Brand name : [NOKIA] Model name : [TA-1021] Android version : [8.1.0] Reset frp : OK ! |
01-21-2019, 14:37 | #26 (permalink) |
Member: 2889927 Status: Offline Thanks Meter: 55 | LG G3 D855 Screen Lock Reset Done With Out Data Lost By GRT Dongle Code: Searching port : OK ! Port : COM201 Open comport : OK ! Detect Mod : OK ! Mod : Download Detect protocol : OLD Open device : OK ! Reading info : OK ! Model Name : LG-D855 Software version : D85510n Android Version : 4.4.2 Chipset : msm8974 Imei : 3525xxxxxxxxxxxx Reset lock please wait... OK ! Close device : OK ! Reboot normal : OK ! |
01-22-2019, 14:55 | #27 (permalink) |
Member: 2889927 Status: Offline Thanks Meter: 55 | read xml dump g6 Detect cpu : OK ! Make xml : OK ! Reading modem... OK ! Reading sbl1... OK ! Reading sbl1bak... OK ! Reading aboot... OK ! Reading abootbak... OK ! Reading rpm... OK ! Reading rpmbak... OK ! Reading tz... OK ! Reading tzbak... OK ! Reading hyp... OK ! Reading hypbak... OK ! Reading pad... OK ! Reading modemst1... OK ! Reading modemst2... OK ! Reading misc... OK ! Reading fsc... OK ! Reading ssd... OK ! Reading splash... OK ! Reading DDR... OK ! Reading fsg... OK ! Reading sec... OK ! Reading boot... OK ! Reading system... OK ! Reading persist... OK ! Reading cache... OK ! Reading recovery... OK ! Reading keystore... OK ! Reading config... OK ! Reading oem... OK ! Reading PrimaryGPT... OK ! Reset phone : OK ! |
01-22-2019, 15:30 | #28 (permalink) |
Member: 2889927 Status: Offline Thanks Meter: 55 | frp HUAWEI SCL-L21 done Code: Make tmp file : OK ! Start adb : OK ! Detect device : ONE Read info : OK ! Brand name : [HUAWEI] Model name : [HUAWEI SCL-L21] Android version : [5.1.1] Reset frp : OK ! |
