12-24-2018, 10:04 | #1 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | iPhone 6 backlight common method to Fix over Conditions:
Tools:
Check the J2019 socket (PIN 29) voltage by iPOWER X tester to measuring if have 1.8V. and also measuring C2040 C2039 FL2027 if have 1.8V. |
The Following 3 Users Say Thank You to .::Gsmdenis::. For This Useful Post: |
12-24-2018, 10:22 | #2 (permalink) |
Member: 79315 Status: Offline Thanks Meter: 6,024 | Step 1 - measure result have 1.8V Step 2: Check the J2019 socket (PIN 26) voltage by iPOWER X tester to measuring if have 5.7V. and also measuring C2094 c2071 FI2037 C2050 C2051 C2070 C1569 if have 5.7V. |
12-24-2018, 10:43 | #3 (permalink) |
Member: 79315 Status: Offline Thanks Meter: 6,024 | Step 2 - measure result have 5.7V Step 3: Check the J2019 socket (PIN 28) voltage by iPOWER X tester to measuring if have - 5.7V. and C2044 FI2061 C1504 also must be - 5.7V |
12-24-2018, 10:53 | #4 (permalink) |
Member: 79315 Status: Offline Thanks Meter: 6,024 | Step 3 - measure result have - 5.7V Step 4: Check the J2019 socket (PIN 14) voltage by iPOWER X tester to measuring if have 1.8V (this is Reset signal) to C2200 FL2036 R2052 |
The Following 4 Users Say Thank You to .::Gsmdenis::. For This Useful Post: |
