10-06-2019, 20:55 | #1 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Copenhagen, Denmark Age: 58
Member: 51434 Status: Offline Thanks Meter: 16 | Back glass replacement What is the best laser machine for iPhone back glass separating ? Best regards Henrik |
The Following 2 Users Say Thank You to Henrik Liss For This Useful Post: |
11-18-2019, 03:20 | #2 (permalink) |
Freak Poster Join Date: Jun 2017 Location: USA
Member: 2730637 Status: Offline Thanks Meter: 101 | I bought one from REWA. It works great. They have detailed introduction video and after-sales videos support, and that is amazing! |
The Following User Says Thank You to phryne For This Useful Post: |
11-08-2022, 10:20 | #5 (permalink) |
Junior Member Join Date: Mar 2022 Location: UK Age: 32
Member: 3009116 Status: Offline Thanks Meter: 4 | iPhone Back Glass Repair Tips If your back cover glass is accidentally broken, there are two ways to repair it, one is to go to the official after-sales service, and the other is to go to a third-party repair point for repair. 1. Go to the official after-sales service point for maintenance Generally, if your back cover is accidentally broken, if you go to the after-sales service for maintenance, if your display screen and rear camera are no problem, then the after-sales service will replace all accessories except the display screen and rear camera for you. This repair Plans apply to all iPhone 12 series, with repairs ranging from $349 to $599 All after-sales repair shops repair in the same way. They will not replace the back cover glass for you alone. If your iPhone 12 is dropped and the back cover is broken and the screen is also faulty, you can only replace the whole machine. 2. Third-party repair shop Most of the third-party repair shops can replace the rear cover glass, and the price varies according to the quality of the rear cover glass and the way of repair. It should be noted that there are no original accessories for the individually replaced back cover glass. If you need to replace the original back cover, you can only replace the disassembly accessories with the middle frame. 3. How to replace the back cover by a third-party repair shop At present, the mainstream professional repair shops on the market usually use a laser machine to polish the rear cover, and then heat it at a low temperature to remove the damaged glass, remove it and clean it, and then install a new glass. This repair method is the current maintenance method. The least damage to the mobile phone, not only does not need to disassemble and high temperature baking, basically zero damage to the mobile phone. |
The Following 2 Users Say Thank You to Luis Willam For This Useful Post: |
