12-05-2019, 11:45 | #1 (permalink) |
Freak Poster Join Date: May 2011 Location: Bulgaria
Member: 1569900 Status: Offline Thanks Meter: 129 | Iphone XS Max Restarts every 3 minutes phone keep restart in every 3 minutes any one with solution for this problem? |
12-07-2019, 01:23 | #3 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Europe Age: 44
Member: 126827 Status: Offline Sonork: 100.70299 Thanks Meter: 60 | bad charging flex can cause this issue, try to plug good one to board (tested one) before fiting after market flex oftenly have same issue good luck |
The Following User Says Thank You to Mark-Zone For This Useful Post: |
12-22-2019, 18:43 | #4 (permalink) |
No Life Poster Join Date: Apr 2005 Location: colchester Age: 56
Member: 134206 Status: Offline Thanks Meter: 17 | Yes had this problem on xs max after replacing back glass- I used laser machine to remove glass but removed board and cameras first after reassemble had reboot fault - maybe laser machine damage the charging flex ??? Did you find the fault magdavuza |
The Following User Says Thank You to porn For This Useful Post: |
03-20-2020, 03:22 | #8 (permalink) | |
Freak Poster Join Date: Jun 2017 Location: USA
Member: 2730637 Status: Offline Thanks Meter: 101 | Quote:
Be patient and careful! | |
The Following User Says Thank You to phryne For This Useful Post: |
11-23-2020, 02:58 | #11 (permalink) |
Junior Member Join Date: Aug 2020 Location: USA Age: 25
Member: 2965059 Status: Offline Thanks Meter: 1 | Hope I can help you. You can try these methods: 1 Force Restart Your iPhone 1) Quickly press and release the volume up button. 2) Quickly press and release the volume down button. 3) Press and keep holding the side button until the screen turns off and then turns back on. Then you can release the side button when the Apple logo appears. After that, your iPhone will restart automatically. 2.Use iOS repair tool to Fix Without Data Loss and also easy. 3. Using iTunes To Restore iPhone 1) Simply connect your iPhone to a computer and launch iTunes. 2) A pop-up window will appear not long after iTunes finish detecting a problem with your iPhone. Just hit "Restore". 3) If the pop-up didn't show up, you can click on "Summary" and then "Restore iPhone" to restore your iPhone manually. For More details: why does my iphone keep restarting |
The Following User Says Thank You to claudiapeng For This Useful Post: |
02-01-2021, 09:59 | #14 (permalink) |
Insane Poster Join Date: Feb 2006 Location: Italia Age: 53
Member: 237150 Status: Offline Thanks Meter: 2 | Hi I have a problem with an iphone xs max after replacing the back glass with the laser method the phone slowed down and turns off every 3 minutes. I replaced charging flex but the problem remains. helps me? |
