01-15-2020, 09:27 | #1 (permalink) |
Product Manager Join Date: Aug 2018 Location: Ukraine / Harkov
Member: 2857401 Status: Offline Thanks Meter: 6,861 | Blocked Dongles & "Error : LOCKED and NOT USABLE" Post Here *** Warning Hydra Dongle **** ERROR : Hydra Dongle Locked and NOT USABLE Please TAKE NOTE OF THE FOLLOWING:
DO NOT USE THE OUTDATED SOFTWARE VERSIONS. if you are see This life at log : Life : 0-[10-0-0-0-0] Its blocked, with Master Reset buton which at HumTool you can fix it, Master Reset allow 2 time to reset it. if Life become like this : Life : 2-[10-0-0-0-0] Its mean your card blocked and you are already use 2 time Master Reset Buton, Please contact with us for Rebuild your card, it will take 5-7 working days Thank you. Best Regards | Hydra Team |
The Following 26 Users Say Thank You to Hydra Tool For This Useful Post: |
03-18-2020, 16:41 | #3 (permalink) |
Freak Poster Join Date: Apr 2013 Location: Bangladesh Age: 40
Member: 1910629 Status: Offline Sonork: 100.1653190 Thanks Meter: 65 | Hydra MediaTeK Tool Ver 1.0.1 Build 76 Windows 10 (Version 10.0, Build 18362, 64-bit Edition) Intel(R) Core(TM) i3-6100 CPU @ 3.70GHz Intel(R) HD Graphics 530 Ram Installed : 8 GB Windows Access Right Admin ******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 191000002474 Initialize : OKAY Status : Activated Life : 2-[10-0-0-0-0] =========== HYDRA DONGLE ALERT =============== Error : LOCKED and NOT USABLE TAKE NOTE ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED Last edited by RKS ROPON; 03-18-2020 at 16:47. |
03-19-2020, 05:03 | #4 (permalink) |
Insane Poster Join Date: Apr 2007
Member: 487150 Status: Offline Thanks Meter: 22 | Hydra Main Tool Ver 1.0.0 Build 20 - Samsung Windows 10 (Version 10.0, Build 18362, 64-bit Edition) Intel(R) Core(TM) i5-4430 CPU @ 3.00GHz AMD Radeon HD 5450 Ram Installed : 16 GB Windows Access Right Admin ******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 190400000785 Initialize : OKAY Status : Activated Life : 0-[1-0-0-0-0] =========== HYDRA DONGLE ALERT =============== Error : MODULE SECURITY DATA NOT MATCHED TAKE NOTE ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED |
The Following User Says Thank You to pigo1 For This Useful Post: |
03-19-2020, 07:16 | #5 (permalink) | |
Member: 2857401 Status: Offline Thanks Meter: 6,861 | Quote:
Life : 0-[10-0-0-0-0] Please always use dongle at direct pc hub, do not use at external pc hub, due low voltage your dongle is blocked, and allow 2 time reset dongle, Master ReseT Buton at HumTool (Star Icon) Click it, it will Reset your card, But Please next time becareful to use at direct pc hub. | |
The Following 3 Users Say Thank You to Hydra Tool For This Useful Post: |
03-19-2020, 07:16 | #6 (permalink) | |
Life : 2-[10-0-0-0-0] Please always use dongle at direct pc hub, do not use at external pc hub, due low voltage your dongle is blocked, and allow 2 time reset dongle, Master Reset, You are use 2 time Reset buton, Please contact with us for Rebuild your card, it will take 3-5 working days | |
03-19-2020, 08:29 | #7 (permalink) |
Member: 487150 Status: Offline Thanks Meter: 22 | I will not use the hub, only the new Hydra MainTool v1.0.0.20 program will lock the key, it works fine on Hydra MainTool v1.0.0.12 =========================================== Hydra Main Tool Ver 1.0.0 Build 20 - Samsung Windows 10 (Version 10.0, Build 18362, 64-bit Edition) Intel(R) Core(TM) i5-4430 CPU @ 3.00GHz AMD Radeon HD 5450 Ram Installed : 16 GB Windows Access Right Admin ******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 190400000785 Initialize : OKAY Status : Activated Life : 1-[0-0-0-0-0] =========== HYDRA DONGLE ALERT =============== Error : MODULE SECURITY DATA NOT MATCHED TAKE NOTE ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED |
03-19-2020, 08:36 | #8 (permalink) |
Member: 487150 Status: Offline Thanks Meter: 22 | Hydra Main Tool Ver 1.0.0 Build 12 -SAMSUNG Windows 10 (Version 10.0, Build 18362, 64-bit Edition) Intel(R) Core(TM) i5-4430 CPU @ 3.00GHz AMD Radeon HD 5450 Ram Installed : 16 GB Windows Access Right Admin ******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 190400000785 Initialize : OKAY Status : Activated Life : 1-[0-0-0-0-0] ========================================== After the reset, he lost his life, but the problem remained |
03-19-2020, 08:39 | #9 (permalink) | ||
The Following 4 Users Say Thank You to Hydra Tool For This Useful Post: |
03-23-2020, 14:39 | #11 (permalink) |
Freak Poster Join Date: May 2004 Location: Slovakia Age: 45
Member: 66497 Status: Offline Thanks Meter: 80 | Connecting to Hydra Server... Server 2 - Other Country...Ok ******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 190700001470 Initialize : OKAY Status : Activated Life : 2-[0-0-0-0-0] =========== HYDRA DONGLE ALERT =============== Error : LOCKED and NOT USABLE TAKE NOTE ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKEDFailed |
03-24-2020, 06:54 | #12 (permalink) | |
Plase PM Me! BR | Hydra Team | |
The Following 2 Users Say Thank You to Hydra Tool For This Useful Post: |
03-28-2020, 19:33 | #14 (permalink) |
Freak Poster Join Date: Feb 2009 Location: Rx Tx Gnd
Member: 964064 Status: Offline Sonork: 1596401 Thanks Meter: 59 | Hail Hydra, First of all, i like your products, platform type and many more But i have a lot of problem about your products. Since the day i buy this dongle, I dont have any success even on boot info in SPD tools, Qualcom Tools, Only MTK tools got success. Only once. Flare P1 FRP in MT6580 chipset. Untill this current update arrive and i was very hopefully that my problem could be fix. But sadly my hope was been broken. and my problem was getting worse. I incountered this Error : LOCKED and NOT USABLE situation. As i read above i Master reset my dongle and the problem was solve. A few moment later, after changing and changing module which is normally a repair man can do. Same problem occur. And My dongle was directly connected to USB Port at the back of my PC. I hope someone of your technical team solve my issue. Because i really need it. Tnx WBr, |
The Following User Says Thank You to rapm3tal For This Useful Post: |
03-29-2020, 01:26 | #15 (permalink) |
Member: 2857401 Status: Offline Thanks Meter: 6,861 | Hello @rapm3tal, Please send full logs of HumTool, so you can check your life you can read first message and check your life and take action on it. BR | Hydra Team |
The Following 9 Users Say Thank You to Hydra Tool For This Useful Post: |
