05-19-2019, 07:41 | #1 (permalink) |
No Life Poster Join Date: Aug 2012 Location: Bali-Indonesia
Member: 1800628 Status: Offline Thanks Meter: 940 | Oppo F9 CPH1823 loader failed loggs with auto select Hydra MediaTeK Tool Ver 1.0.0 Build 97 Windows 10 (Version 10.0, Build 17763, 64-bit Edition) ******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 190100000115 Initialize : OKAY Status : Activated ===================================== Connection[WAITING]Found Mode[BROM] Port[COM19] Status[Opened] Identifying Hardware ID BROM CPUID : 0788 (0000)MT6771[6771] BROM HW_SW_VER : 8A00 CA00 0000 0000 SECURE VERSION : 05 BL VERSION : FE BR Secured : E5[SBC+SDA+SEL] Using Default AUTH Security Authorization[auth_sv5.auth] NOT Accepted Load Correct Auth File ===================================== Elapsed Time : 00:00:13 Last edited by Deni's; 05-19-2019 at 07:46. |
08-15-2019, 10:37 | #6 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | OPPO F9 [ CPH1823 ] Boot issue Same thing - cannot be booted, even with TP: The SW see it, but ... Anyone have solution about? |
08-15-2019, 14:26 | #9 (permalink) | |
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Quote:
The phone do not accept current eMMC config. So - open Hydra MediaTek Tool. Sellect brand OPPO, F7 or F9, on PREL line use preloader_oppo6771_18311.bin -> download it from here . Use Testpoint for new security [ for old ones just both Vol+ and Vol- are enough ] . Go to PM and use Listing partitions. Connect now testpointed [ to GND ] phone with cable to PC. You will see the miracle - partitions will appear. Readout Userdata just for safe. Rewrite it with clean one from here. All be fine - no more uselocks and FRP. WBR, DebeliaMark, BG P.S. Sorry - i just close phone, otherwise shall make an picture explanation. P.S. 2 - integrated preloader seem cannot handle all types of eMMC or some of them [ in my case - Samsung ] - that is the reason to fail last booting step. | |
The Following User Says Thank You to debeliamark For This Useful Post: |
