09-12-2019, 11:27 | #34 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Sri Lanka
Member: 164422 Status: Offline Thanks Meter: 24 | redmi 7 mi account unlock i have a redmi 7 mi account lock but allways getting this error and cannot unlock.seems ur server problem. Hydra Qualcomm Tool Ver 1.0.1 Build 32 Windows 7 Service Pack 1 (Version 6.1, Build 7601, 32-bit Edition) Intel(R)Core(TM) i5-2430M CPU @ 2.40GHz Ram Installed : 2.74 GB ******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 19030 Initialize : OKAY Status : Activated Selected Comport : Auto Selected Loader : Auto Searching Qualcomm 9008 Port[FOUND](COM3) Getting device info.. Device MODE : SAHARA Connecting to Firehose... Ping.. Ok Configuration. Xiaomi Authentication needed... Signature Request -> blob[AQAAAF0BAADc9yt-P1pS9VZmKhZN2CB5zN-V4g] Hydra Xiaomi Server... Waiting for server response.................... Server not responding..., please try again later Unable to generate authkey...Failed Running : Failed Device is not in Firehose Mode Elapsed Time : 00:32:15 |
09-14-2019, 03:17 | #38 (permalink) |
Freak Poster Join Date: Dec 2013 Location: India
Member: 2077370 Status: Offline Sonork: 100.1616788 Thanks Meter: 268 | Redmi note 7s mi ac other shop keeper flash redmi note 7 pro file set dead and after flash note 7 file baseband unknown what to do I flash with note 7 file lavander india ver and globle ver but same basebend unknown also i write qcn file but set not on proper go to recovry and show nv data crupt then again flash with hydra dongle set on but basebend unknown Sent from my Lenovo A7020a48 using Tapatalk |
09-14-2019, 08:53 | #39 (permalink) | |
No Life Poster Join Date: Feb 2012 Age: 39
Member: 1724862 Status: Offline Thanks Meter: 448 | Quote:
note 7 mi account not possible by any tool, its relased by android 9 version, for fix unknown baseband when flash by hydra untick skip security partitions | |
09-14-2019, 13:55 | #40 (permalink) |
Freak Poster Join Date: Oct 2016 Location: Surandai TN India Age: 37
Member: 2637068 Status: Offline Thanks Meter: 276 | Lyf F120B Format Done Code: Hydra Qualcomm Tool Ver 1.0.1 Build 32 Windows 7 Service Pack 1 (Version 6.1, Build 7601, 32-bit Edition) Intel(R) Celeron(R) CPU G550T @ 2.20GHz Ram Installed : 3.372 GB ******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 190300000278 Initialize : OKAY Status : Activated Selected Comport : Auto Selected Loader : Auto Searching Qualcomm 9008 Port[FOUND](COM23) Getting device info....... Serial No.: 0x13A37793 MSM ID : 0x000940E1 PBL Ver : 00000000 PK HASH : 911B8F01C36F8A876A5C0A75595102EE 09708CA73EA62AFBE301C0110307CEC6 Firehose Loader[prog_emmc_firehose_8909_ddr_1.mbn] Sending ..............Ok Connecting to Firehose... Ping... Ok Configuration......Ok Chip Configuration : MemoryName : eMMC MaxPayloadSizeToTargetInBytes : 1048576 MaxPayloadSizeToTargetInBytesSupported : 1048576 MaxPayloadSizeFromTargetInBytes : 4096 MaxXMLSizeInBytes : 4096 TargetName : 8909 Version : 1 Running : Ok Phone Information..... Model : F120B Brand : LYF Android Ver : 6.0.1 Manufacturer : Jio Device : msm8909_512 Board : msm8909 Display ID : LYF-F120B-001-02-16-080419 Security Patch : xxxx-xx-xx Platform : msm8909 Kernel ID : xxxx-xx-xx FRPPST : /dev/block/bootdevice/by-name/config ====================================== Formatting Userdata... Format Safe method Ok Format Done!! All Done ====================================== |
09-14-2019, 14:25 | #41 (permalink) | |
Member: 164422 Status: Offline Thanks Meter: 24 | not happy hydra team Quote:
09-16-2019, 10:18 | #42 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Tukiye/izmir Age: 39
Member: 204211 Status: Offline Thanks Meter: 41 | mi 8 lite (platina) needs authentication but you said that doesn't need |
The Following User Says Thank You to oldcoyoteinc For This Useful Post: |
09-16-2019, 14:16 | #43 (permalink) | |
Product Manager Join Date: Aug 2018 Location: Ukraine / Harkov
Member: 2857401 Status: Offline Thanks Meter: 6,861 | Quote:
Its doesnt need auhtorized server, if you are select brand and model, if you got any error please open new a theread with screen shot and logs, then we will try help you and more understand the issue, if you need guides you can check Guides & Helps Folder at Hydra Support Area folder. BR Hydra Team | |
The Following 2 Users Say Thank You to Hydra Tool For This Useful Post: |
