Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GSMFABRICA Products > HYDRA TOOL
Old 05-19-2019, 07:41   #1 (permalink)
Deni's's Avatar
Member: 1800628
Thanks Meter: 940
Oppo F9 CPH1823 loader failed
with auto or manual mode get error loader failed
loggs with auto select
Hydra MediaTeK Tool Ver 1.0.0 Build 97
Windows 10 (Version 10.0, Build 17763, 64-bit Edition)
******* Dongle Info *******
Version : Hydra Tool v 1.1
Serial : 190100000115
Initialize : OKAY
Status : Activated
Connection[WAITING]Found
Mode[BROM] Port[COM19] Status[Opened]
Identifying Hardware ID
BROM CPUID : 0788 (0000)MT6771[6771]
BROM HW_SW_VER : 8A00 CA00 0000 0000
SECURE VERSION : 05
BL VERSION : FE
BR Secured : E5[SBC+SDA+SEL]
Using Default AUTH
Security Authorization[auth_sv5.auth] NOT Accepted
Load Correct Auth File
Elapsed Time : 00:00:13
Old 05-19-2019, 11:34   #2 (permalink)
Hydra Tool's Avatar
Member: 2857401
Thanks Meter: 6,861
Hello, You need do TestPoint to Device.
Hydra Team
Old 05-20-2019, 02:29   #3 (permalink)
Deni's's Avatar
Member: 1800628
Thanks Meter: 940
Hydra Team
yes i know that but result same boss
Old 05-20-2019, 04:50   #4 (permalink)
Deni's's Avatar
Member: 1800628
Thanks Meter: 940
please tell me what wrong?
Old 05-20-2019, 19:24   #5 (permalink)
Shaankhan's Avatar
Member: 1590088
Thanks Meter: 3
Disconnect battery short test point try again.
Old 08-15-2019, 10:37   #6 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,034
OPPO F9 [ CPH1823 ] Boot issue
Same thing - cannot be booted, even with TP:
The SW see it, but ...
Anyone have solution about?
Old 08-15-2019, 10:59   #7 (permalink)
Deni's's Avatar
Member: 1800628
Thanks Meter: 940
i think still bug for remove pass code by hydratool and i never success.
team please fix it.....
Old 08-15-2019, 14:23   #8 (permalink)
Hydra Tool's Avatar
Member: 2857401
Thanks Meter: 6,861
Hello,
Its Already fixed, Wait for next update of MTK Module.
Hydra Team
The Following User Says Thank You to Hydra Tool For This Useful Post:
Old 08-15-2019, 14:26   #9 (permalink)
Member: 4627
Thanks Meter: 1,034
You can do it.
The phone do not accept current eMMC config. So - open Hydra MediaTek Tool. Sellect brand OPPO, F7 or F9, on PREL line use preloader_oppo6771_18311.bin -> download it from here .
Use Testpoint for new security [ for old ones just both Vol+ and Vol- are enough ] .
Go to PM and use Listing partitions. Connect now testpointed [ to GND ] phone with cable to PC. You will see the miracle - partitions will appear. Readout Userdata just for safe. Rewrite it with clean one from here.
All be fine - no more uselocks and FRP.
WBR, DebeliaMark, BG
P.S. Sorry - i just close phone, otherwise shall make an picture explanation.
P.S. 2 - integrated preloader seem cannot handle all types of eMMC or some of them [ in my case - Samsung ] - that is the reason to fail last booting step.
The Following User Says Thank You to debeliamark For This Useful Post:
Page generated in 0.16079 seconds with 9 queries
