[25/09/2019] GSM Shield Samsung Setup v1.0 Initial Release is OUT General Flasher - Predefine Scenario for Easy Flahsing - Fully Customizable Flashing Interface - Support for LZ4 Format Firmware - Thousands of Samsung Devices Supported Root Functions - Easy to make Root Image - Select either boot.img or AP Tar - LZ4 Format Supported - Flash Root Image MDM and Call Me Remover - Remove Call Me Lock - Remove MDM Lock - Remove Android Locks 4 Different Methods for FRP Reset - Format Method - Eng Boot Method - UART Method (For UFS Chip Only) - ADB Method ScreenLock ByPass Firmware Maker - Supports SystemUI or LockSettings Method - Need to select Combination + BL + AP only - LZ4 Firmware Format Supported - Flash generated Firmware using Flash Firmware function Selective Flashing Interface - Read Partition from Device directly - Load files of your choice and Flash Added Eng Boot File: - G920TUEE3DPD6 - G925AUCT5DPJ1 - G925TUVE3EPD1 - G930AUCE4CRE4 - G930FXXE2EREM - G930TUVE4BQB1 - G930W8VLE3CRE3 - G930XUCE4CRE4 - G9350ZCE2CRF5 - G935AUCE4BQA6 - G935AUCE4CRE4 - G935FXXE2EREM - G935W8VLE3CRE3 - G935XUCE4CRE4 - J250FXXE2ARI1 - J701FXVE4ARC4 - N920PVPE2BPD2 Supported Model for FRP Reset - Format Method / ADB Method - A310F - A310M - A310N0 - A310X - A310Y - A320F - A320FL - A320Y - A5100 - A510F - A510FD - A510K - A510L - A510M - A510S - A510Y - A520F - A520K - A520L - A520S - A7100 - A7108 - A710F - A710FD - A710K - A710L - A710M - A710S - A710X - A710Y - A720F - A810F - A810YZ - A9000 - A910F - C5000 - C5010 - G389F - G390F - G530T - G530T1 - G530W - G531BT - G531F - G531H - G531M - G531Y - G550FY - G570 - G570F - G570Y - G6000 - G600FY - G610F - G610M - G610Y - G611F - G890A - G903F - G903N - G903W - G906K - G9200 - G9208 - G9209 - G920A - G920AZ - G920F - G920i - G920K - G920L - G920P - G920R4 - G920R7 - G920S - G920T - G920T1 - G920V - G920W8 - G9250 - G925A - G925F - G925i - G925K - G925L - G925P - G925R4 - G925R7 - G925S - G925T - G925V - G925W8 - G9280 - G928A - G928C - G928F - G928G - G928i - G928K - G928L - G928P - G928R4 - G928S - G928T - G928V - G928W8 - G9300 - G9308 - G930A - G930F - G930FD - G930K - G930L - G930P - G930R4 - G930R7 - G930S - G930T - G930T1 - G930V - G930W8 - G9350 - G935A - G935F - G935FD - G935L - G935P - G935R4 - G935S - G935T - G935V - G935W8 - J105F - J105H - J105M - J106B - J106F - J106H - J106M - J111F - J200F - J200G - J200H - J200M - J320F - J320FN - J320G - J320H - J320M - J320N0 - J320P - J320R4 - J320W8 - J320Y - J320ZN - J330F - J330FN - J5007 - J5008 - J500F - J500FN - J500G - J500H - J500M - J500Y - J5108 - J510F - J510FN - J510FQ - J510GN - J510H - J510K - J510L - J510MN - J510S - J510UN - J7008 - J700F - J700H - J700K - J700M - J700P - J700T - J700T1 - J701F - J701M - J7108 - J7109 - J710F - J710FN - J710FQ - J710GN - J710K - J710MN - J727P - J727R4 - J727S - J727T - J727T1 - J727U - J727V - N920 - N9200 - N9208 - N920A - N920C - N920G - N920i - N920K - N920L - N920P - N920R4 - N920R7 - N920S - N920T - N920V - N920W8 (Some devices with latest firmware may not work) Supported Model for FRP Reset - UART Method - G9200 - G9208 - G9209 - G920A - G920AZ - G920F - G920i - G920K - G920L - G920P - G920R4 - G920R7 - G920S - G920T - G920T1 - G920V - G920W8 - G9250 - G925A - G925F - G925i - G925K - G925L - G925P - G925R4 - G925R7 - G925S - G925T - G925V - G925W8 - G9280 - G928A - G928C - G928F - G928G - G928i - G928K - G928L - G928P - G928R4 - G928S - G928T - G928V - G928W8 - G9300 - G9308 - G930A - G930F - G930FD - G930K - G930L - G930P - G930R4 - G930R7 - G930S - G930T - G930T1 - G930V - G930W8 - G9350 - G935A - G935F - G935FD - G935L - G935P - G935R4 - G935S - G935T - G935V - G935W8 - N920 - N9200 - N9208 - N920A - N920C - N920G - N920i - N920K - N920L - N920P - N920R4 - N920R7 - N920S - N920T - N920V - N920W8 (Some latest SBOOT may be unsupported, need to downgrade) Download GSM Shield Control Panel Software HERE |
