Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSM Shield Box
Old 09-26-2019, 19:47   #1 (permalink)
Member: 2919205
Thanks Meter: 21
Arrow [HOW TO] Use SDCARD Reader as ISP Interface
In above image, you can easily understand pinouts of any SDCARD reader.
In order to connect your device to ISP Interface, mostly you need only DATA0, CLK, CMD, VCC, VCCQ and GND.
In some devices, you must connect VCCQ which is typically 1.8v. As there is no 1.8v supply in SDCARD, mostly people connect VCC to VCCQ, but in some cases, it may cause damaged.
If you have other ISP hardware, which appears in Device Manager under Disk Drives, you can also use that.
We have our own hardware which is very much safe and easy to use. Till then, if you want, you may continue using SDCard Reader.
Br,
GSB
The Following 8 Users Say Thank You to GSM SHIELD For This Useful Post:
Page generated in 0.16576 seconds with 7 queries
