03-18-2022, 11:18 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: bhakkar Age: 38
Member: 770229 Status: Offline Sonork: 29050 Thanks Meter: 101 | Oppo a15 imei repair not work [Solved] Operation: Repair Software version: 3.2 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [Microsoft,usbser,USB Serial Device,usbser.sys,10.0.18362.1] Device found at COM92 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x9ACEA18C, 0xB372F41D, 0x17A64D63, 0xD6A0A5D3 Get Chip ID... [MT6765] Get SOC ID... [73F1E61A91807BB22DC93CA37A7F145B87DDAB0E25B8F153CE 380E38DACFF1C2] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x90014A68423861503E03000B6E1BA78D Load EMI config from database [DB VER: 203 DB DATE: 02-22-2022] OK [1] Trying EMI [44724C4B, 7805E65B, 148572B4, AD4E4796, 4ECF8C5A, 667E0B28, 4C76F2A3, F1ADA01B, 703B5CDE, 08EDF5FC] Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x90014A68423861503E03000B6E1BA78D EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0747C00000 (29.12Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0080000000 (2.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read partition "nvdata"... error(8), skip Read partition "nvram"... error(2), skip Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI: 357800156160212 Write IMEI [NVDATA]... error(1) |
03-18-2022, 11:29 | #2 (permalink) |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,062 | Hello. Delete all preloader and mediatek port drivers and install drivers from pandora box folder. |
The Following User Says Thank You to Z3X For This Useful Post: |
