01-25-2022, 16:03 | #1 (permalink) |
No Life Poster Join Date: Mar 2018 Location: Future.... ✌️
Member: 2825953 Status: Offline Thanks Meter: 246 | Oppo A16s CPH2271 IMEI Repair Fail Load partition for patching... error(ERR_RS) Operation: Repair Software version: 2.10 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM5 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x7200987D, 0x9F1237A2, 0x8FBD34A5, 0xC21BFF00 Get Chip ID... [MT6765] Get SOC ID... [233DABCF1DE55C88A0FAA3B56FD65BBAFF4D6BA68D646A2394 ED8E4F5416A35D] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [23] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x90014A68433861503E03105D58657803 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x90014A68433861503E03105D58657803 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0E8F800000 (58.24Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6765 Board Platform : MT6765 Build ID : RP1A.200720.011 Build Date : Fri Jul 23 03:33:33 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-08-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1626981447835 Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Read IMEI... error Repairing IMEI... IMEI: 8 Write IMEI [NVDATA]... OK Load partiton for patching... error(ERR_RS) |
01-25-2022, 16:15 | #2 (permalink) |
No Life Poster Join Date: Jan 2016 Location: Pakistan Age: 27
Member: 2511027 Status: Offline Sonork: 100.1662953 Thanks Meter: 1,113 | Wait For New Update May Be Pandora Team Fix Android 11 Version In Next Update |
The Following User Says Thank You to KAS HIF For This Useful Post: |
01-25-2022, 23:46 | #4 (permalink) | |
Freak Poster Join Date: Sep 2015 Location: Lombok
Member: 2465890 Status: Offline Thanks Meter: 176 | Choose oppo a55 model Quote:
The Following User Says Thank You to AWEXSS For This Useful Post: |
03-04-2022, 14:22 | #5 (permalink) |
No Life Poster Join Date: May 2008 Location: bhakkar Age: 38
Member: 770229 Status: Offline Sonork: 29050 Thanks Meter: 101 | Selected model: OPPO CPH2271 (Oppo A16s) Operation: Repair Software version: 2.12 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [Microsoft,usbser,USB Serial Device,usbser.sys,10.0.18362.1] Device found at COM92 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [Microsoft,usbser,USB Serial Device,usbser.sys,10.0.18362.1] Device found at COM92 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xF1588F19, 0x7C6C7151, 0xA17B3219, 0x441B8341 Get Chip ID... [MT6765] Get SOC ID... [C8502ABE9C0A9CA812AD18E8628AE74A9F2AC7D94D39EAAE96 86973B2A1CEA63] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x90014A68433861503E03100E23B788E3 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x90014A68433861503E03100E23B788E3 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0E8F800000 (58.24Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6765 Board Platform : MT6765 Build ID : RP1A.200720.011 Build Date : Wed Nov 24 02:12:03 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-11-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1637690366587 Read partition "nvdata"... error(8), skip Read partition "nvram"... error(2), skip Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 357869007494000 IMEI 2: 357860048900000 Write IMEI [NVDATA]... OK Load partiton for patching... error(ERR_LD) |
03-04-2022, 15:13 | #6 (permalink) | |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Online Thanks Meter: 5,063 | Quote:
03-04-2022, 15:58 | #7 (permalink) | |
Member: 770229 Status: Offline Sonork: 29050 Thanks Meter: 101 | Quote:
Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [Microsoft,usbser,USB Serial Device,usbser.sys,10.0.18362.1] Device found at COM92 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [Microsoft,usbser,USB Serial Device,usbser.sys,10.0.18362.1] Device found at COM92 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xF1588F19, 0x7C6C7151, 0xA17B3219, 0x441B8341 Get Chip ID... [MT6765] Get SOC ID... [C8502ABE9C0A9CA812AD18E8628AE74A9F2AC7D94D39EAAE96 86973B2A1CEA63] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x90014A68433861503E03100E23B788E3 Load EMI from phone... Skip Load EMI config from database [DB VER: 203 DB DATE: 02-22-2022] OK [3] Trying EMI [E395B304, A5FE5CDA, 10D75741] Init EXT RAM... error(2) | |
03-07-2022, 09:47 | #10 (permalink) | |
Operation: Read PTT Software version: 3.0 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [Microsoft,usbser,USB Serial Device,usbser.sys,10.0.18362.1] Device found at COM92 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [Microsoft,usbser,USB Serial Device,usbser.sys,10.0.18362.1] Device found at COM92 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xF1588F19, 0x7C6C7151, 0xA17B3219, 0x441B8341 Get Chip ID... [MT6765] Get SOC ID... [C8502ABE9C0A9CA812AD18E8628AE74A9F2AC7D94D39EAAE96 86973B2A1CEA63] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x90014A68433861503E03100E23B788E3 Load EMI config from database [DB VER: 203 DB DATE: 02-22-2022] OK [1] Trying EMI [7805E65B, 4ECF8C5A, 667E0B28, F1ADA01B, 154C2947, A5FE5CDA] Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x90014A68433861503E03100E23B788E3 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0E8F800000 (58.24Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6765 Board Platform : MT6765 Build ID : RP1A.200720.011 Build Date : Wed Nov 24 02:12:03 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-11-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1637690366587 Read partition "super"... error(8), skip Read partition "userdata"... error(STATUS_UNSUPPORT_CMD), skip Saved to C:/Users/JH%20MOBILE/Desktop/DUMP_PARTITIONS_(2022-3-7_10-45-53)/ Dumping Partitions done! how can we read sir see this errar | |
03-07-2022, 10:33 | #11 (permalink) | |
The Following 3 Users Say Thank You to Z3X For This Useful Post: |
