Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Pandora’s box
Old 12-29-2021, 18:07   #16 (permalink)
ghr
Member: 1282787
Sonork: 100.1673491
Thanks Meter: 307
only adb repir rest became null heloo to all make it perment after resset original imei
Old 12-29-2021, 19:36   #17 (permalink)
Member: 1610674
Sonork: 210921
Thanks Meter: 217
Grate update thanks team
Old 01-04-2022, 15:17   #18 (permalink)
ali_ipi's Avatar
Member: 1655288
Thanks Meter: 90
is it permanent imei repair or after reset revert back orignal ?
Old 01-04-2022, 16:46   #19 (permalink)
Member: 2133894
Thanks Meter: 8
oppo imei repair permanent??
Old 01-04-2022, 17:35   #20 (permalink)
Z3X
Member: 706257
Thanks Meter: 5,065
Hello. Patch - its always temporary solution.
Old 01-18-2022, 01:29   #21 (permalink)
Member: 2606038
Sonork: jaanam
mr. rahul. khan
my. card not activated please add Pandora box card
and activate please my card. .....AA7BF9F2..
please reply. i wait. for answer z3x theam
Old 01-18-2022, 07:24   #22 (permalink)
Member: 2606038
Sonork: jaanam
Please activate my card AA7BF9F2
my pandora box not activated on z3x server
please add my card and activate my card
my card Please activate my card AA7BF9F2
Old 01-18-2022, 11:13   #23 (permalink)
Member: 897964
Sonork: 100.1673443
Thanks Meter: 58
Hello dearest please fix all problem when i imei repair from pandora box all mobile going in stock logo or only vibrate... sir please tell me what is problem please sir you must be Fix all error
Old 01-18-2022, 11:46   #24 (permalink)
Z3X
Member: 706257
Thanks Meter: 5,065
Hello. Only reseller able to add card to server.
Old 01-25-2022, 07:06   #25 (permalink)
Member: 2664255
Thanks Meter: 8
oppo a73 5g cph2161 whats proble version 10 but not working pandora box
Wait for device connecting... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0]
Device found at COM29 [BROM]
Open port... OK
Send start cmd... OK
Get HW code from device... 0996
Get HW & SW version from device... OK
HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00
Detect chip [MT6853]
Library Version [2]
Select platform... OK
Init BROM... OK
Force Charge... OK
Disable WatchDog Timer... OK
Reopen port for libver2... OK
Get ME ID... OK
ME_ID = 0xF3DBA31D, 0xCFCDECD4, 0x4E9AAEE3, 0xC1135373
Get Chip ID... [MT6853]
Get SOC ID... [8DBD8F263CF8C80E0C014DF2582361283F6732D2E1943B67E6 E1FE16DB5E4CA2]
Get sec config... OK [000000E0]
Load DownloadAgent... OK
Search DA... OK [30]
Send preloader... OK
Start preloader... OK
Check preloader answer... OK
Send bootloader... OK
Start bootloader... OK
Wait for answer from bootloader... OK
Send SYNC signal... OK
Setup device enviroment... OK
Setup device parametres... OK
Receive DA SYNC signal... OK
Set DA parametres... OK
Get device connection agent... [BROM]
Get device info... OK
UFS CID (FW VER): KM8V8001JM-B813 (1900)
Load EMI from phone... OK
Parse EMI config... OK
Init EXT RAM... OK
Send 2nd DA... OK
UFS INFO:
UFS_CID : KM8V8001JM-B813
UFS_FWVER : 1900
BLOCK_SIZE: 0x0000001000 (4.00Kb)
UFS_LU0 : 0x0000400000 (4.00Mb)
UFS_LU1 : 0x0000400000 (4.00Mb)
UFS_LU2 : 0x1DCB000000 (119.17Gb)
RAM INFO:
INT_SRAM: 0x0000070000 (448.00Kb)
EXT_RAM : 0x0100000000 (4.00Gb)
Check USB status... USB_HIGH_SPEED
Read partitions info from phone... OK
Check A/B state... OK
Read product info... OK
Product Board : oppo6853
Board Platform : MT6853
Build ID : QP1A.190711.020
Build Date : Tue Sep 29 13:52:29 CST 2020
Security Patch : 2020-09-05
Version SDK : 29
Version Release : 10
Version Codename : REL
Read partition "nvdata"... OK
Read partition "nvram"... OK
Read NVDATA files... OK
Read NVRAM files... OK
Read IMEI... error
Repairing IMEI...
IMEI 1: 351429600081109
IMEI 2: 351429600081117
Write IMEI [NVDATA]... OK
Load partiton for patching...
Exception: Access violation at address 0042CD6B in module 'PandoraTool.exe'. Read of address 00000000
Old 02-10-2022, 15:34   #26 (permalink)
Member: 770229
Sonork: 29050
Thanks Meter: 101
Oppo CPH2119 Oppo F17 Pro after repair imei my mobile bricked
(the current image(boot/recovery)have been distroyed and can not boot) plz gide me how can we do it ok ?
Old 04-30-2022, 08:11   #27 (permalink)
vijay rana's Avatar
Member: 1303334
Sonork: 100.1605942
Thanks Meter: 25
oppo A16 imei repair time patch inpossible problem plz solved it
Old 04-30-2022, 14:13   #28 (permalink)
Member: 2076643
Sonork: 100.1650096
Thanks Meter: 70
STILL EROR HOW TO SOLVE THIS PROBLEM ?
Selected model: Infinix X657 (Infinix Smart 5)
Operation: Erase FRP
Software version: 3.0
Host Power Off... OK
Switch virtual port to USB... OK
Connect Type-C to BOX... OK
Host Power On... OK
Connect phone to BOX in BROM mode
Wait for device... OK
Read usbhost speed... FULL
Read Device Descriptor...
Get VID/PID...0E8D/0003
Get HW code from device... 6580
Detect chip [MT6580]
Get sec config... OK [00000005]
Active sec flags: [SBC DAA]
Advanced Bypass Security... OK
Disconnect virtual port... OK
Connect Type-C to HUB... OK
Device found at COM19 [BROM]
Open port... OK
Library Version [1]
Init BROM... OK
Force Charge... OK
ME_ID = 0x9006B359, 0xF0474694, 0xA2A8A345, 0x242A8DA1
Get sec config... OK [00000000]
Get BROM version... OK
Search DA... OK [26]
Check bootloader answer... OK
Wait for hw detection... OK
Wait DA version... v4.2
Send BROM version... OK
Send storage config... OK
SyncBmtInfoWithDA... OK
Set params... OK
Read flash info... OK
EMMC_ID: 0x510001154133365860390342FB580297
Init DRAM... OK
Enable DRAM... OK
Sync with DA...
Exception: Invalid pointer operation
Old 08-29-2022, 14:11   #29 (permalink)
Member: 1861126
Thanks Meter: 32
Selected model: OPPO CPH1821 (Oppo F7)
Operation: Read IMEI Info
Software version: 3.9
Switch virtual port to NONE... OK
Host Power On... OK
Connect phone to BOX in BROM/PRELOADER Mode
Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM_V1632 (Android),usb2ser.sys,3.0.1504.0]
Device found at COM386 [PRELOADER]
Open port... OK
Get HW code from device... 0788
Detect chip [MT6771]
Library Version [2]
Init BROM... OK
Force Charge... OK
Force switch to BROM... OK
Host Power On... OK
Wait for device... timeout
many model this eror how to fix
Old 10-31-2022, 16:11   #30 (permalink)
Member: 2154625
Thanks Meter: 76
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Host Power On... OK
oo i ahve this error
Selected model: OPPO CPH2239 (Oppo A54)
Operation: Read Flash Info
Software version: 3.10
Host Power On... OK
Device found at COM120 [PRELOADER]
Open port... OK
Get HW code from device... 0766
Detect chip [MT6765]
Library Version [2]
Init BROM... OK
Force Charge... OK
Host Power On... OK
Wait for device...
Page generated in 0.29082 seconds with 8 queries
