The Market Feed Back Write here your feedback and your Comments about buyers, sellers or Product Feed Back, Read Carefully The Related Rules for this Section. |
05-30-2019, 17:49 | #1 (permalink) |
Freak Poster Join Date: Jan 2004
Member: 48396 Status: Offline Thanks Meter: 82 | www.unlockpark.com - need feedback I used this service unlockpark.com - S8 S8 PLUS G950F / G955F IMEI REPAIR,BAD,BLACKLISTED REPAIR SINGLE SiM. (CPID) 3rd time. First two times it was no problem, G950F and G965FD was repaired successfully, updated to latest Android 9 fw and worked as it should. Now I used this service for G955F. IMEI was repaired, sim count was changed from single to dual (it's not a problem), but after I flash it from v4 combination to regular first or latest Android 9 fw there is no IMEIs. Tried G955FXXS4DSE1 and G955FXXU4DSE4 with no luck. After downgrade it to Android 8 G955FXXS4CRLB fw IMEIs are back and phone is in working condition. I contacted guy who did it and he told "it’s problem on your software". What sw? I used latest ODIN v3.13.3 and tried latest z3x sw too - result is same. Firmwares was downloaded via SamFirm sw and from sammobile site. There is no any info phone can't be upgraded to Android 9 after imei repair. So is there someone used this service for Samsung G955F imei repair? What I'm doing wrong? Is there a fix for this problem? What should I do, ask full/partial refund or what? I promised to my client a phone will work without any restrictions after imei repair. Otherwise I could use cert patch procedure via Chimera tool, which is cheaper and now works with Android 9. |
05-31-2019, 07:06 | #2 (permalink) | |
Product Manager Join Date: Apr 2009 Location: BD,BH,CN
Member: 1004001 Status: Offline Sonork: WhatsApp+971506319003 Thanks Meter: 448 | Quote:
06-06-2019, 06:21 | #3 (permalink) |
Member: 48396 Status: Offline Thanks Meter: 82 | Hello, I contacted you last Friday, upgraded a phone to the latest Android 9 fw as you told me and got no baseband. Sent you screenshots etc. After that you didn't offered any solution. Contacted you at Monday, you didn't replied and still there is no any solution from you. Do you know or not, but before Android 9 you could use sim+sim+sdcard (so called sandwich method) in dual sim phones and it was fixed on Android 9, so you can't do it anymore without root. Only sim+sim or sim+sdcard. You changed my single sim phone to dual sim and may be it is a reason why we got this problem? May be you can change it back to single sim and it will solve this problem? I don't know, it's just my thoughts. But anyway you didn't offered any solution till now. |
