Hardware Repair Item Wanted Post here if you are looking for test equipment or service tools. |
10-05-2008, 17:27 | #2 (permalink) |
Junior Member Join Date: Sep 2008
Member: 865987 Status: Offline Sonork: 0027 Thanks Meter: 2 | i have a problem in nokia 6610 on lcd displays ,the lcd displays brings only lights without data information, i tried to replace the lcd but the problem still there so you can help |
The Following 2 Users Say Thank You to hitimana fiacre For This Useful Post: |
10-16-2008, 14:16 | #7 (permalink) |
Junior Member Join Date: Sep 2008 Location: southafrica Age: 40
Member: 864068 Status: Offline Sonork: aminkhan Thanks Meter: 2 | mail me on [email protected] |
02-07-2009, 08:42 | #13 (permalink) |
No Life Poster Join Date: Nov 2006 Location: philippines Age: 42
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 264 | first no one can help you better if you don't post better, there are 3 kinds of n70 white screen, there is lcd problem, crystal display problem and the voltage supply problem. which is it? doed the phone have 112 when you dial it even with white screen or not? 2100 white display also has 2 problems, LCD and contact service. i know some will react, "white screen? contact service?" YES. if you haven't encountered that kind of problem in 2100. you probably repaired phones yesterday so don't bother to post blogs. heres the solution to all: n70 1. LCD = replace LCD 2. CRYSTAL DISPLAY IC = replace CRYSTAL DISPLAY IC near back up battery usually looking like a watch battery soldered to the board. the crystal IC is square and a bit shiny. 3. look here: http://forum.gsmhosting.com/vbb/show...0+white+screen, post number 8. 2100 1. LCD = change LCD 2. try to reprogram the phone with mcu, ppm, pmm and then edit imei and unlock full factory settings. 3. reheat or replace COBBA ic and do number 2. hope it helped you. next time post with more information about your problem so people can help you better. BR. eivelice |
The Following User Says Thank You to eivelice For This Useful Post: |
02-12-2009, 06:35 | #14 (permalink) |
Insane Poster Join Date: May 2007
Member: 515694 Status: Offline Thanks Meter: 14 | Originally Posted by ettctcdownload n70 white display and 2100 white display first no one can help you better if you don't post better, there are 3 kinds of n70 white screen, there is lcd problem, crystal display problem and the voltage supply problem. which is it? doed the phone have 112 when you dial it even with white screen or not? 2100 white display also has 2 problems, LCD and contact service. i know some will react, "white screen? contact service?" YES. if you haven't encountered that kind of problem in 2100. you probably repaired phones yesterday so don't bother to post blogs. heres the solution to all: n70 1. LCD = replace LCD 2. CRYSTAL DISPLAY IC = replace CRYSTAL DISPLAY IC near back up battery usually looking like a watch battery soldered to the board. the crystal IC is square and a bit shiny. 3. look here: http://forum.gsmhosting.com/vbb/show...0+white+screen, post number 8. 2100 1. LCD = change LCD 2. try to reprogram the phone with mcu, ppm, pmm and then edit imei and unlock full factory settings. 3. reheat or replace COBBA ic and do number 2. hope it helped you. next time post with more information about your problem so people can help you better. BR. eivelice |
6020 LCD lights and keypad light not working | walli Turab | Nokia Hardware & Hardware Repair | 6 | 06-16-2010 10:45 |
5610 LCD light problem !!! | shahzadthe1 | Nokia Hardware & Hardware Repair | 2 | 03-29-2010 21:47 |
w550 no lcd light and keypad light | acelai00 | Sony Ericsson Hardware Repair | 5 | 11-17-2006 19:37 |
^510 no keypad light and no lcd light | uwenk98 | Nokia Hardware & Hardware Repair | 0 | 05-25-2006 07:03 |
6230 neither keypad lights not LCD lights | doctormike | Nokia Hardware & Hardware Repair | 4 | 04-05-2006 10:54 |
