Hardware Repair Item Wanted Post here if you are looking for test equipment or service tools. |
02-02-2017, 14:36 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Madrid, Spain
Member: 591052 Status: Offline Sonork: 100.1592747 Thanks Meter: 95 | looking for soldering products |
02-06-2017, 18:36 | #3 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | I advice you to use hakko soldering station , as I use also . about flux amtech is good . but u may check there any other brand . let me know I'll try to guide . |
02-09-2017, 11:39 | #4 (permalink) |
No Life Poster Join Date: Oct 2012 Location: Republic of Serenissima
Member: 1825965 Status: Offline Thanks Meter: 874 | Hi i use Ersa I-CON Nano and Xytronic LF3000 more Hakko FX951 (chinese clone ) these as iron solder . Ersa with small handpiece and 0,1 mm thin tip so useful for capacitors, resistor very small, 0802 , 01002 .. (unfortunately 65w are few) Flux : amtech( original no clone ) nc559 very good but for me the best is Mg chemical 8341 - NO CLEAN, although it may be more dense. come on share your experiences ! Last edited by orx; 02-09-2017 at 17:11. |
02-10-2017, 09:10 | #7 (permalink) |
Member: 1825965 Status: Offline Thanks Meter: 874 | hi yes for me the Hakko clone is discreet , if the original much more cost there will be a reason..if you use it a few minutes it seems ok but if you use it for a couple of hours see its limits .. anyway , tips cost are important ..hakko family Fx spare tips are expensive respect to others. to distinguish if the Solder station investment is for hobby or for professional use.. |
02-11-2017, 22:55 | #10 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Italy, Bahrain, India Age: 53
Member: 125037 Status: Offline Sonork: 100.1649338 Thanks Meter: 254 | I've a set of original Aoyue stations and they are very precise when it's a bout temperature control and air flow. Flux, Amtech or Mechanic (original of course ) ehehhe |
03-11-2017, 08:44 | #14 (permalink) |
No Life Poster Join Date: May 2005 Location: Romania Focsani
Member: 149135 Status: Offline Thanks Meter: 234 | There are lot of model..but almost all use same f.u.king letcon..poor power to tips! You need to operate at 330-350 degree..gordak,net,quiq,baku,luky..all use same s.h.i.t..all are same s.h.i.t. |
03-11-2017, 15:48 | #15 (permalink) |
Member: 1825965 Status: Offline Thanks Meter: 874 | hi before stating that all are s.h.i.t. you should think that those who approach the world of hardware repair, building an idea using those cheap stations .. even the gsm master use economic stations, is the experience that makes the real difference.. |
The Following User Says Thank You to orx For This Useful Post: |
