Hardware Repair Item Wanted Post here if you are looking for test equipment or service tools. |
04-24-2009, 08:03 | #1 (permalink) |
Junior Member Join Date: Jul 2006
Member: 304786 Status: Offline Thanks Meter: 9 | moto c168 spk problem |
The Following User Says Thank You to rajraj For This Useful Post: |
05-22-2009, 04:52 | #2 (permalink) |
No Life Poster Join Date: Nov 2006 Location: lake city
Member: 386868 Status: Offline Thanks Meter: 125 | just remove the handsfree jack clean the board thoroughly, now place the jack carefully now check your phone will definitely work properly................ wbr: sanjubhai. |
05-22-2009, 13:15 | #3 (permalink) |
Junior Member Join Date: May 2009
Member: 1036736 Status: Offline Sonork: [email protected] Thanks Meter: 0 | |
05-22-2009, 13:17 | #4 (permalink) |
Member: 1036736 Status: Offline Sonork: [email protected] Thanks Meter: 0 | dffffffffffffffffffffffffffffffujhh7kkkkkkkkkkkkkk kkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkhj |
05-23-2009, 07:00 | #5 (permalink) | |
Freak Poster Join Date: Sep 2005 Age: 61
Member: 181829 Status: Offline Thanks Meter: 119 | Quote:
try this solution ... | |
The Following User Says Thank You to ammar_gammoudi For This Useful Post: |
06-22-2009, 04:58 | #7 (permalink) |
Junior Member Join Date: Jun 2009
Member: 1058825 Status: Offline Thanks Meter: 0 | The Motorola C168 phone has a function of indicating to you that you missed an incoming text or phone call afslanken while you were away from the phone, it does this by giving a beep beep noise every 2 mins approx until u open the text. This avoids having to keep checking laser hair removalyour phone every time your away from it. What is this function called on phone stats. So when buying a phone u can check if this has the function? |
C168 SPK+RINGER+MIC solution | atulharnal | Motorola Hardware Repair | 4 | 08-17-2011 19:31 |
moto c168 charging problem | saqi160 | Motorola Hardware Repair | 0 | 08-12-2009 16:13 |
moto c168 spk problem | rajraj | Motorola Hardware Repair | 0 | 04-24-2009 07:59 |
moto c168 spk problem | rajraj | Motorola Hardware Repair | 0 | 04-20-2009 08:12 |
moto c168 flash problem | burraq | Infinity-Box | 5 | 07-21-2008 07:43 |
