Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > Hardware Repair Item Wanted
Hardware Repair Item Wanted Post here if you are looking for test equipment or service tools.
Old 11-23-2017, 11:04   #1 (permalink)
Member: 2358547
Power supply to heat up shorted components
Hello, what power supplies do you use for heating up shorted components on the Board?
I want to work on a shorted iphone 6 board.
Thanks in advance.
Old 11-24-2017, 01:16   #2 (permalink)
Member: 2657093
Good looks there are several that you can buy.
This is two amper but does not serve you to charge the baria.
This is the five aperio and that should remove the short and will serve you to charge the battery.
Old 11-24-2017, 08:28   #3 (permalink)
pazeth™'s Avatar
Member: 74519
Thanks Meter: 56
just use any old battery to heat up short components, remove circuit board inside battery and use directly. Some case, this method can burn damage your phone seriously.
The Following 2 Users Say Thank You to pazeth™ For This Useful Post:
Old 11-28-2017, 11:48   #4 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 8,436
@ pazeth™
You are absolutely correct, Me also use this method for find out short circuit components.
__________________
To get Instant help use "search" & follow "sticky thread"..!!!
Get back respect / Read The forum Rules Carefully!!!,You will & be respect .!
Best regard
Palash Ahammad
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post:
Old 11-28-2017, 12:36   #5 (permalink)
khorsed_pabna's Avatar
Member: 2049143
Sonork: not use
Thanks Meter: 165
yes this working method
Old 11-30-2017, 09:52   #6 (permalink)
Member: 2783963
how do you do it. i dont know how to solve short circuit
Old 12-12-2017, 15:15   #7 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Sonork: Wechat ID: gsmdenis
Thanks Meter: 4,438
the best solution is this :
iPhone 8 harddisk replacement by iREWORK
The Following User Says Thank You to .::Gsmdenis::. For This Useful Post:
Old Yesterday, 08:51   #8 (permalink)
alkim's Avatar
Member: 992568
Sonork: kulit
Thanks Meter: 205
this is not a power supply
his asking what kind of power-supply that can ****up the capacitor or component shorted in the circuit board. his asking a brand name or type of that tools
Powered by Searchlight © 2017 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
Page generated in 0.17465 seconds with 7 queries
