Notebooks & Personal Computers Notebook, Personal Computer - repair, disassemble guides, drivers, bios pasword, and problems with pc. |
04-11-2021, 14:57 | #1 (permalink) |
Banned Join Date: Mar 2019 Location: Gsm-Boss Age: 46
Member: 2902804 Status: Offline Sonork: 100.1660513 Thanks Meter: 928 | ESET SysRescue v.1.0.20.0 ESET SysRescue v.1.0.20.0 11-04-2021 ========================= ESET SysRescue aims to scan your computer and remove malware components that might have affected its functioning. Its major advantage is that it runs outside the operating system, directly accessing the file system and the hard disk to run thorough on-demand scans of the boot sector or existing partitions Launched from a bootable USB drive, a CD or a DVD ESET SysRescue can be deployed on a USB drive, a CD or a DVD. Thanks to the wizard-like interface of the Live USB Creator, creating a bootable USB is a simple task However, please note that the drive will be formatted, so make sure you created a backup of your data. Alternatively, you can mount the available ISO image and boot ESET SysRescue afterward Scan your PC for various threats You can use ESET SysRescue to initiate smart or custom scans of your computer, in the attempt to detect and completely remove traces of viruses and other type of threats that might endanger data integrity and affect the way your PC works There are various scan profiles you can choose from and the application enables you to customize them by choosing the folders or files to include in the analysis. Optionally, it can only retrieve information concerning potentially dangerous files, without actually deleting them from the PC The scan results are logged to file and the application can display detailed statistical data and conclusive graphs regarding system protection. Quarantined items can be browsed, restored or deleted with just a click A powerful removal tool to find and erase malware components Relying on a robust scanning engine, ESET SysRescue implements a defense system that is ready to clean your system even from the most intrusive threats Rising up to its developer's name, it helps you scan your system from the outside, performing a deep analysis of the file system and the storage unit so as to remove resolute threats. Please note that is is not recommended as a permanent real-time protection solution for your PC Create your ESET SysRescue Live disk Run the LiveUSBCreator file Choose either “Create USB drive” or “Create CD/DVD” and select the desired media Create your ESET SysRescue Live USB/CD In addition, you can use a separate ISO image in the archive Scan any PC with ESET SysRescue Live Insert your ESET SysRescue Live CD/USB & reboot Select “Run ESET SysRescue” Once the program starts, click “Update” to download the latest signatures Click “On-demand scan” and select “Smart scan” or “Custom scan Whats New Added: New EULA update Improved: OS distribution upgrade Improved: eSysRescue VSDB database update ESET SysRescue 1.0.20.0 File Size : 702 Mb ================================= ESET SysRescue v.1.0.20.0 |
The Following 2 Users Say Thank You to Gsm-Boss. For This Useful Post: |
