Alcatel & TCL Old Models Alcatel Old models like HD-x, HE-x , also BE Series like BE1, BE2 ,, BEx ext. here also located all TCL models threads like e777,d308,d868 & d818 models. |
04-24-2001, 13:20 | #1 (permalink) |
Freak Poster Join Date: Dec 2000 Location: Portugal
Member: 2785 Status: Offline Thanks Meter: 0 | who tested this soft? Connect phone. Power must be OFF. Press any key to start ... Sending BOOT1 ... Sending BOOT2 ... Sending BOOT3 ... and nothing else. i've read that many of you guys have successfully revived dead alcatels with this soft. please, can you report what SO, hardware (PC) and Cable schematic are you using? thanx a lot I have P3 800, MB ASUS CUSL2, 256 RAM and use a cable similiar to misiek Universal 3.0 (just one diode and one 4k7 resistor) thanx Dark Lemming |
04-24-2001, 13:36 | #2 (permalink) | |
Freak Poster Join Date: Feb 2001 Location: Cj,Ro,Eu
Member: 3262 Status: Offline Thanks Meter: 1 | Hi Dark Leming! I use a Pentium 133Mhz,32Ram.Try another Pc up to Pentium 200Mz. Or I receive this error if I am runing under windows,or if the batery is empty. My best regards to all. P.s: From my experience with alcatel db,v.163 not works very well this prog,just some version of 163 I repaird. Quote:
04-24-2001, 17:49 | #3 (permalink) |
No Life Poster Join Date: Feb 2001
Member: 3279 Status: Offline Thanks Meter: 19 | Hi Darklemming ,can you possibly mail me this scheme cable similiar to misiek Universal 3.0 (just one diode and one 4k7 resistor) [email protected] |
04-25-2001, 08:13 | #5 (permalink) |
Member: 3262 Status: Offline Thanks Meter: 1 | Hi Dark! Mobil Plus has right,if the phone doesen't comunicate with Andromeda software,it's blocking at boot3...with Mihnea's.So it's an hardware problem. My best regards to all cosmo |
04-25-2001, 14:29 | #8 (permalink) |
Freak Poster Join Date: Dec 1999 Location: Earth
Member: 751 Status: Offline Thanks Meter: 19 | Hi DarkLemming, The Minea's soft runs under dos mode, the error you'd experienced indicates a hardware problem, might be on the phone or on the interface itself. I'm sending to you the schematic of the interface I use......I was able to repair a lot of alcatels using this soft and interface. By the way, big tnx for the shell you developed..it is the best and made unlocking easier. Best regards, neb |
04-26-2001, 01:30 | #10 (permalink) |
Member: 751 Status: Offline Thanks Meter: 19 | Yes, Be1 Service Software by Zulea can also repair and at the same time unlocks during the process. I use it in repairing problems such as: "no network signal", "can't power on" and etc, assuming of course, that their is no hardware problem on the unit......Andromeda 5.9 works good also on repairing. But in a severe case, say: unit indicates "insert card" after receiving network a few seconds, original flash not saved and reflasing it with same version isn't successfull ....Minea's soft is better. Regards, neb |
04-26-2001, 07:36 | #11 (permalink) |
No Life Poster Join Date: Sep 2000 Location: Czech Republic
Member: 1993 Status: Offline Thanks Meter: 94 | Dark Lemming i think that problem is your cable - or your PC. I have the some problem on my notebook(ports) - i run it on other pc in pure dos mode and everyting was ok...hardware problem is the last thing. (but may be).... Best Regards Eerchant |
04-26-2001, 09:27 | #12 (permalink) | |
Freak Poster Join Date: Sep 2000 Location: Slovenia, EU Age: 59
Member: 2202 Status: Offline Thanks Meter: 0 | Hi, Run Mihnea from clear DOS and must work (100%). Regards, Marian Quote:
04-27-2001, 04:48 | #15 (permalink) |
Freak Poster Join Date: Jun 2000 Location: In front of pc
Member: 1585 Status: Offline Thanks Meter: 15 | hi! i have the same problem with DarkLemming. boot1,boot2,boot3...sometimes it stops erasing flash and i have to start again. i have 2 PC and it doesn't work at all. i have 2 cables, one is misiek modified with bc547 and the other one designed for USPU. they work well with other softs. pls send me the modified one with diode and resistor only.. MY SOLUTION TO DEAD BE1 phones: (below 16F) 1. Read phone with andromeda 4.8/4.9. 2. Write again using the flash read. IMPT!!! (just to heat up the flash) 3. Run Service Software by Zulea. It depends on sw version of phone. If phone is 16C and below, use BE1v12.3(special for SS-andromeda). If phone is 16D, use BE1v12.3 (protected version-only for 16D). 4. When done, disconnect..turn phone on.. IT'S ALIVE!!! 5. Do the usual check (charge battery, make a call, etc.) 6. The phone is not only alive but also unlocked!!! note: not writing back the flash (in no.2) and using zulea serv sw doesnt help at all..from my experience phone is still dead) I hope this method helps regards |
Who tested this cables? | ..::khaled::.. | Nokia Base Band 5 ( BB-5 ) | 18 | 10-10-2009 17:29 |
who tested this solution? | Sear | iPhone 2 / iPhone 3G / iPhone 3GS | 3 | 08-19-2008 08:37 |
need help. who have this soft ..... | chip_2000 | QUALCOMM Models (3G) | 2 | 03-05-2007 11:25 |
who test this http://www.byemoto.com/ | chotky | Motorola P2k | 1 | 03-18-2004 23:24 |
Who has this soft? | vshahabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-30-2001 19:08 |
