Alcatel & TCL Old Models Alcatel Old models like HD-x, HE-x , also BE Series like BE1, BE2 ,, BEx ext. here also located all TCL models threads like e777,d308,d868 & d818 models. |
01-22-2002, 23:17 | #1 (permalink) |
No Life Poster Join Date: Apr 2000 Location: Bulgaria Kyustendil Age: 47
Member: 1191 Status: Offline Thanks Meter: 128 | BE4 Read/Write flash problem with Celeron ??? I have too PCs:<br />1st is with AMD 500MHz 128MB RAM and MB ACORP with chipset ALI<br />2nd is with Cel 950MHz 256MB RAM and MB ZIDA 815EP with internal Sound Card i use 'BE4 Flasher by GSMBoyM v1.2' and read/write many Alcatel 302 phone with 1st PC. problem is with 2nd PC. unable to read/write flash ?<br />when start reading flash after 1-2% software says to check battery and stop. but when i connect phone to 1st PC i read flash w/o problem.<br />i use the same hardware with external power, that i use for all alcatel phones BE1-BE5. i use this hardware from 1-2 years and now problem with it. can anybody help for this strange problem ? regards Svetli<br />ICQ 37901019 |
01-23-2002, 10:10 | #3 (permalink) |
No Life Poster Join Date: Jun 2000 Location: Everywhere
Member: 1580 Status: Offline Thanks Meter: 2 | I have Ņeleron 800 motherboard chaintech i815<br />Cable with external power GSM Boy flasher works fine (read/write - I use flasher v1.4), mcomm's flashers works good only for writing (I can't read flash).<br />BE4 reader by S2 gsm - works good for flash reading. Use 44oBx motherboard - all soft will work fine |
01-23-2002, 11:52 | #4 (permalink) |
Member: 1191 Status: Offline Thanks Meter: 128 | 10x guys. I will change my MB imediatly ! F-cu-K this stupid i815xx chipset <img src="smile.gif" border="0"> <img src="smile.gif" border="0"> <br />Before one moneth I use MB ZIDA v693 w/o problems, 1st with Win98 SE then with Win XP Pro. Then i change MB with ZIDA i815ep and Win XP stop work !!! Every time go to blue screen with text that says "...remove all new hardware. Start CHKDSK /F and try reinstall Windows again..." <img src="smile.gif" border="0"> <img src="smile.gif" border="0"> but if I remove my MB then how will work my new PC <img src="smile.gif" border="0"> <img src="smile.gif" border="0"> regrds Svetli |
01-23-2002, 22:00 | #5 (permalink) |
Guest
Posts: n/a
Member: | I also got this XP sh***t, it works fine for some other things, but for unlocking? Nope...<br />Go back to win98 or winME.<br />If you want anyway keep using XP, start comp i SAFE MODE using F8 key, and choose Safe mode on startup menu.<br />I hope this will help you, if windows XP manage to start, open device manager and remove old stuff - hardware from old MB -, and restart you comp.<br />Or you can start setup again and choose repair option after first restart during instalation,but this is fof "power users"... |
01-24-2002, 03:01 | #6 (permalink) |
Member: 1191 Status: Offline Thanks Meter: 128 | <img src="smile.gif" border="0"> 10x for answer<br />i know that for XP - not work for unlocking. i found solution for my problem <img src="smile.gif" border="0"> - i will change MB with other w/o i815 chip. today i test my software and hardware with one old PC intel 233 MHz 8MB RAM <img src="smile.gif" border="0"> all work 100%. Svetli |
E250 read/write flash problem | VIZER | UST Pro II | 6 | 09-23-2007 03:02 |
read/write flash toshiba ts21i with testpoint - 100%!!! | ErlanH | Various | 75 | 05-04-2007 19:09 |
e259 read-write flash problem | deYo | FuriousGold | 9 | 11-12-2006 22:18 |
Dejan Read/Write Flash | pks | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-26-2001 22:48 |
Read/Write Flash | Gorgonzola | Alcatel & TCL Old Models | 2 | 05-20-2000 20:05 |
