Alcatel & TCL Old Models Alcatel Old models like HD-x, HE-x , also BE Series like BE1, BE2 ,, BEx ext. here also located all TCL models threads like e777,d308,d868 & d818 models. |
04-27-2003, 15:35 | #1 (permalink) |
Freak Poster Join Date: Sep 2002 Location: Kenya, E. Africa Age: 56
Member: 15772 Status: Offline Thanks Meter: 1 | How to use Mihnea Flash?? I downloaded all files 16a and 16b and unzipped them to one folder in c: 1. Connect phone 2. Select 16b-DB flash 3. Press enter Sends Boot 1... Sends Boot 2... Boot 3... starts up phone!( This phone has an 'insert Sim' problem which I am trying to solve) 4. Nothings happens! No sending boot , nothing. If I switch off phone nothing still happens. If I touch 'off' button again it says 'unknown flash type' If i select DB-all it says error in exe file contact [email protected]. DB-Flash give me message I cannot understand. So what Am I doing wrong?? Please help rgds |
05-02-2003, 13:36 | #7 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Egypt Age: 46
Member: 4263 Status: Offline Sonork: 100.1582330 Thanks Meter: 49 | mihnea is the best sw i used to repair BE1 but its problem is it need slaw pc like p5 233 i use P2 celeron 400 Mh and it work berfect with me if BE1 died for sw problem it will become alife full functionally |
05-03-2003, 08:26 | #8 (permalink) |
No Life Poster Join Date: Sep 2000 Location: Philippines
Member: 2034 Status: Offline Thanks Meter: 24 | @Xanga Try this: Using andromeda 5.9 download your phones flash, you can download it when phone activates as you hit the enter key.. if it finds reading your phone now download it as it is with a filename you wanted to specify... after it downloads save the flash file. now again run andromeda 5.9 same procedure in detecting the phone hit on REPAIR PHONE using its own flash dump phone should work now. Regards |
05-03-2003, 23:15 | #9 (permalink) |
Freak Poster Join Date: Jun 2002 Location: romania Age: 53
Member: 12891 Status: Offline Thanks Meter: 5 | downloader www.chavalgsm.com |
how to use patched flash files ??? | andy270871 | UST Pro II | 3 | 08-03-2008 21:12 |
z610 did and problem gdfs pleas how to use db2020 flash | ms.4011 | Cruiser Suite | 3 | 03-30-2008 18:34 |
how to use cruiser flash W550I | tonytan | Sony Ericsson | 1 | 02-22-2006 12:44 |
How to use test flashes for sony ericsson? | Arnis A | Sony Ericsson | 9 | 04-07-2004 12:05 |
