Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| Alcatel & TCL Old Models Alcatel Old models like HD-x, HE-x , also BE Series like BE1, BE2 ,, BEx ext. here also located all TCL models threads like e777,d308,d868 & d818 models. |
| | #1 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: May 2003 Location: Tonga Age: 42
Member: 29011 Status: Offline Thanks: 0
| Need help on Retrofit Ver 4.23 software installation please! I dowloaded the Alcatel Service SW Retrofit vers 4.23 for HE1 and HD1 from the http://unlock.prolidi.cz website to my laptop which have windows 2000. I tried to run the software but have some problem. When I unzipped the files I see so many files in there. Can anyone please help me how can I install this software to my laptop? Can I install it on Window 2000? Thanks in advance for any help. spv |
| | #4 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2002 Location: Canary Islands Age: 42
Member: 17351 Status: Offline Thanks: 43
| Well I dont need it now as I managed to get the code from the network eventually. I am sure every one will be different but just in case it is not then this is what they gave me 1191350964. Someone else has said to put the Cvirt into Windows systems folder, hasnt worked for me, you try it!! |
| | #6 (permalink) |
| Just tried copying the Cvirt and *.dll files into windows/system folders still does not work. Anyway when I try to run the program it gives me a red box window with the words "ERREUR INITIALISATION LGT" I think I'm getting somewhere. Anyone have come across the same problem, please share! spv |
| | #9 (permalink) |
| Hi all, I think I managed to installed retrofit correctly, I can naow enter the normal screen with main menus. But still I have some problems. 1. |
| | #10 (permalink) |
| Hi all, not yet finish my last post. here are the problems. 1. Most of the times as soon as I plug in the cable to the phone, the mobiles turns itself on. 2. Sometimes it stays off but I have to select switch on twice in order for the phone to be on. When I select general --> connect it displays error message "Erreur emission message", Erreur envoi message LCE. Then program seems to be freezed and can not exit normally. I have to Ctrl+Alt+Delete to quit the program. Please help if you have come across this kind of problem. thanks spv |
| | #11 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2001 Location: Poland, Kielce Age: 34
Member: 7493 Status: Offline Thanks: 10
| use cable with external power suply than 1. power on phone 2. power off (while doing it - when phone swithces off) connect cable press power on in retrofit and quickly connect 3. phone now should be in test mode 4. next is easy ![]() BR, gladeo |
| | #13 (permalink) |
| Hi guys, I really appreciate your help. I think thats my problem! I only used cable with no external power. Yes I have selected com 1 already. I don't have such cable but when I have one I'll try again. thanks spv |
| | #15 (permalink) |
| Junior Member ![]() ![]() Join Date: Feb 2003 Location: Lisbon - Portugal
Member: 20890 Status: Offline Thanks: 0
| Please let me try to put things you said before all together.. All software made for Windows95/98 that use port (COM ports) connections does not work in Windows 2000/XP just because there is no compatibility between 2000/XP with prior win versions in comunication API functions. There is a small program named Useport.exe (i think) that should solve this problem. It is a very simple task to change a simple data cable to a external powered one. Just use a 9V bat. with a diode following the positive wire (anode to the bat) and plug the two wires with the serial diode to the circuit. The black one goes to circuit ground. The one with the diode (positive) should be connected to a supply point. If there is an IC like 7404 link to its 14 pin, if there is a 5V regulator (7805), link it to pin ner 1. If there is nothing of this, find what COM port pins are beeing used to power the circuit and conect the positive wire after the circuit diode connected to that pin. Usualy there are 2 RS232 pins doing that job. This is not a good thing to explain in text but.. maybe it gives u some ideas : ) |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Vodastar clip Upgrade ver 4.23 | cairo_gsm | Vodafone Star | 49 | 10-15-2009 19:16 |
| Retrofit 4.23 software in English? | spvaka | Alcatel & TCL Old Models | 1 | 07-13-2003 19:00 |
| NOKIA 3310 VER.4.23-NEED BACKUP | 13061972 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 06-10-2001 13:57 |
| Need partila flash 3310 ver 4.23 | Gold_Horn | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 02-19-2001 06:22 |
| 3310 ver 4.23 Partial Flash For Free :) | X-Shadow | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 02-18-2001 18:17 |
