Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Alcatel > Alcatel & TCL Old Models
Alcatel & TCL Old Models Alcatel Old models like HD-x, HE-x , also BE Series like BE1, BE2 ,, BEx ext. here also located all TCL models threads like e777,d308,d868 & d818 models.
Old 07-11-2009, 10:37   #1 (permalink)
Member: 548859
Post please help reset code alcatel ot-c550x
good morning
thank u
Old 07-11-2009, 11:04   #2 (permalink)
U.F.O.'s Avatar
Member: 801293
Sonork: 100.1581561
Thanks Meter: 170
Originally Posted by lyne View Post
good morning
thank u
Alcatel service codes :
set language to English: *#0044#
set language to Russian: *#0007#
set language to French: *#0033#
software version: *#4837*#
auto call test: *#2255*#
memory status: *#6362*#
reset menu: *#7378*#
factory mode: *#3228#
engineer mode: *#364463#
software version: *#837#
auto test: *#2886#
clean test records: *#3872#
restore default settings: *#73738#
something unknown: *#200709*01#
Regards
KOKO_TARGET
The Following 2 Users Say Thank You to U.F.O. For This Useful Post:
Old 07-11-2009, 12:45   #3 (permalink)
hawks007's Avatar
Member: 621737
Thanks Meter: 72
your phone is blocked so you cant enter your code,multibox can do it
try this code with moto test card
###765*08#
Old 07-11-2009, 15:22   #4 (permalink)
puumba's Avatar
Member: 613113
Thanks Meter: 21
Try with this code for reset bro*#7728*#
The Following User Says Thank You to puumba For This Useful Post:
Old 07-11-2009, 17:00   #5 (permalink)
samirstare's Avatar
Member: 316262
Thanks Meter: 22
auto test: *#2886#
Regards
KOKO_TARGET
thanks .............................
Old 03-14-2011, 08:45   #6 (permalink)
Member: 1299732
Sonork: pruiyot
can anyone help give original alcatel ot-880 engineer mode values.
ii have changed some values and have lost sound in the earpiece
Old 03-24-2011, 12:52   #7 (permalink)
Member: 468952
Thanks Meter: 15
reset bro*#7728*# ,,,,,,,,,,,,,,,,,,,,,,
Old 03-24-2011, 17:14   #8 (permalink)
Member: 462514
Sonork: 100.1596836
Thanks Meter: 602
hello friend try with this
ZTE Mobile:>1- *938*737381#
2- PHONE WILL DIPLAYED DONE
3- POWER OFF YOUR PHONE AND POWER ON AGAIN
alcatel:>E205
unlocking phone code,only press***847# without simcardE900 software version: *#5002*8376263#
E900 full reset: *2767*3855#
Service codes Spice:
S404 enable COM port: *#42253646633# -> Device -> Set UART -> PS -> UART1/115200
S410 engineer mode: *#3646633#
S900 software version: *#8375#
S900 serial no: *#33778#
Service codes Philips:
S200 enable COM port: *#3338913# -> Device -> Set UART -> PS -> UART1/115200
Service codes "Chinese" models:
default user code: 1122, 3344, 1234, 5678
Engineer mode: *#110*01#
Factory mode: *#987#
Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
Restore factory settings: *#987*99#
LCD contrast: *#369#
software version: *#800#
software version: *#900#
Service codes BenQ:
software version: *#300#
test mode: *#302*20040615#
Service codes Pantech:
software version: *01763*79837#
service menu: *01763*476#
reset defaults (phone/user code reset to default): *01763*737381#
Service codes VK-Mobile 3xx, 5xx:
software version: *#79#
service menu: *#85*364# (hold #)
Service codes VK200, VK2000, VK2010, VK2020, VK4000:
service menu: *#9998*8336# (hold #)
reset defaults (phone/user code reset to default): *#9998*7328# (hold #)
Service codes LG:
software version: 2945#*#
KG300 NVRAM format: 2945#*# -> menu 15
Service codes Sony-Ericsson:
J100 software version: #82#
Service codes Fly:
M100 software version: ####0000#
2040(i) reset defaults: *#987*99# Send
MX200 reset defaults: *#987*99# Send
MX200 software version: *#900# Send
SL300m reset defaults: *#987*99# Send
SL300m software version: *#900# Send
SL500m reset defaults: *#987*99# Send
SL500m software version: *#900# Send
MP500 reset defaults: *#987*99# Send
MP500 software version: *#900# Send
Set language to English: *#0044#
Set language to Russian: *#0007#
Service codes Konka:
C926 software version: *320# Send
C926 set default language: *#0000# Send
C926 set English language: *#0044# Send
Service codes GStar:
GM208 (Chinese Nokea 6230+) engineering menu: *#66*#
Service codes Motofone-F3:
Motofone F3 software version: **9999* Send
***300* Set SIM Pin
***310* / ***311* SIM Pin ON | OFF
***000* Reset Factory settings
***644* Set Voicemail number
***260* / ***261* Auto keypad lock ON | OFF
***510* / ***511* Voice Prompts ON | OFF
***160* / ***161* Restricted Calling (Phonebook only) ON | OFF
***200608* Send: software version
***200606* Send: software version
***200806* Send: flex version
***250* / ***251* Keypad tones ON | OFF
***470* Select time format
***500* /***501* Prepaid Balance Display ON | OFF
***520* Change language
Service codes Motorola:
C113, C114, C115, C115i, C116, C117, C118 software version: #02#*
C138, C139, C140 software version: #02#*
C155, C156, C157 software version: #02#*
C257, C261 software version: #02#*
V171, V172, V173 software version: #02#*
V175, V176, V176 software version: #02#*
C168, W220 software version: *#**837#
W208, W375 software version: #02#*
Old 03-25-2011, 21:05   #9 (permalink)
Member: 1541659
Sonork: ronniewilliams
Thanks Meter: 7
You should try this code for reset. Use it *#7728*#
Old 07-09-2011, 03:56   #10 (permalink)
Member: 1574558
Guatemala is a tigo
Hi I have a cel I need the code for free
ot model 105
imei012217007028406
loboy agrdecer is muc
Old 07-11-2011, 16:58   #11 (permalink)
Nadjombe's Avatar
Member: 185608
Thanks Meter: 577
Only fullflash!!!!!!!!!Otherwise NO SOLUTION.
Old 07-13-2011, 04:20   #12 (permalink)
Member: 660369
Sonork: 1602351
good morning . anybody
Old 07-20-2011, 07:33   #13 (permalink)
Member: 1619504
nice interesting and very informative post, thanks for sharing.
non voice projects
Old 07-21-2011, 09:48   #14 (permalink)
Member: 782390
Sonork: oshiu
Thanks Meter: 55
pls try with infinity full flash
problem solved
thanks
Old 07-21-2011, 09:48   #15 (permalink)
Member: 782390
Sonork: oshiu
Thanks Meter: 55
problem solved
thanks
please help polar team alcatel ot 708 [SOLVED] boliargsm PolarBox 3 3 03-05-2010 18:32
Please help me unlock alcatel OT C820a hohoangkhoi Infinity-Box 0 10-02-2008 03:12
Serious problem alcatel ot-c550x dead after connecting maplegsm Multi-box LITE 14 09-27-2008 07:25
Unlock Alcatel OT-C550X Antish Alcatel TCL Phones and New Models 2 09-28-2007 14:09
Alcatel ot-c550x azo_ja Multi-Box 4 07-27-2007 11:52
Page generated in 0.61575 seconds with 8 queries
