To all analogue phone masters!! ericsson 237/238 programing how do u program esn or analogue numbers on analogue phone. Pls tell it to me and are they belonging to tdma phones? thanks in advance |
Ericsson 237/238 are class 4 Etacs phones. Esns are programmed with programming clips. To enter programming mode you press *923885. Hope this works for you. |
@ eko pls tell me more , i know off key ring this I have and I have hex too pls just gimme a few info I need to enter in any of these analogue phones..... 10x |
there are 2 types of clips, i need to know the type you are using. is it the remove antenna type. Was just wandering is 237/238 still available anywhere in the Uk i will like to buy some |
I am not in the uk now but i have few of them and I need more soon coming from Italy... i can get u some too, I need the info very well.... i think the one i have is the remove antenna type, the dude that used it in my presence once removed the antenna why inserting codes.... i want u to pls join me in a chat yahoo.. am online [email protected] |
i am on icq and msnmessenger |
@ eko i just have to download anyway hope we have enof time pls paste here ur email so we can chat |
ESN transfer on Ericsson EH237 & EH238 You can activate the built in ESN transfer mode by entering M&922630. This means hold down the 'M' or function button and then entering 922630 within 10 seconds to activate this mode. You will need the same serial cable as described at your web site but this time, you need reverse the data in and data out pins to the other phone. Whit the keyboard looking up and you looking at the terminals of the connector, the terminals are numbered (from left to right) 14 down to 1 Keyboard up ________________ |..............| |14 1| Pin 11 is data from external source Pin 12 is the data to the phone All data to the phone is at 600 Baud, 8 bits with logic '1' being 4.8V and logic '0' being 0 V. This means you need an RS 232 to TTL converter Pin 9 is used to enable you to program the Flash EEPROM in the phone. Open is the normal operating mode. +5V is test mode +12 is Programming mode for ESN's and software changes etc. Pin 8 is the necessary digital ground for doing anything. There is yet another test code you can experiment with from the keyboard. Just enter M& 90510# and the unit will display the overhead message and status of the phone. Have fun ! regards LaserMan ----------------- Ericsson EH 1321/237/97 Use at your own risk and responsibility, void in PA USA [ This is for ETACS phones. I don't know if it works on the AMPS equivalents, but it probably will ] EH 237 NAM programming codes: FCN 923885 (or M 923885) " 924885" " 904885" " 904005" " 904035" " 904085" we can see the ESN and modify the parameters for the NAM. IMPORTANT! With FCN 904030 we can transfer data,(??) THREE o FOUR times ONLY. This means you can't clone the phone forever! There may be another code offering unlimited ESN transfers, or some test-mode option to reset the counter. Experiment, and let me know if you find anything. FCN 900000 asks for 5 Pin codes -- ?? EH237 ESN programming: Either build an ESN Transfer Cable for the Ericsson EH237 and EH238, or program it directly from your computer with the programming software (ericsson.zip) The Citronic Cellular Suite :: Ericsson EH237/97 Available from: http://www.geocities.com/SiliconValley/Heights/2675 At last the cellular suite is in wide distribution! Thanks to Phoenix of CCC for cracking this one. It's been around for a good while now but hadn't been released to the various p/h bbs's until more recently. Unfortunately, CCC neglected to include any wiring diagrams for the thing so here they are for you all to peruse along with a few pointers for running the thing. ::: Loading ::: I am not quite sure why but this software refuses to load if there are any memory managers loaded. In other words, most of you will need to boot off a clean floppy rather than your hard drive. To make such a 'bootdisk' use FORMAT A: /S from the DOS prompt which will format the disk in your floppy drive and make it bootable. I don't know why this is the case since the Cheese Factory have never released software with such problems before. ::: The Cable ::: Much the same as for the Sony CM-H333, the software is self-explanatory, the only thing you need to know is how to make the cable. ---------------------------------------------------------------------------- EH97 - View from bottom of phone (Keyboard up): ^ ^ ^ I I I I I I I I I I I I I I I I 21 11 8 Where 21, 11 and 8 represent the numbers of the D-plug pins you must connect to. (ie the leftmost pin of the phone must be connected to pin 21 on the male 25-way D-plug which connects to the printer port of your PC). ---------------------------------------------------------------------------- EH237 - View from bottom of phone (Keyboard up): ^ ^ ^ o o o o o o o o o o o o o o 21 8 11 ---------------------------------------------------------------------------- I have _never_ actually made either of these cables, nor rechipped a phone with it. Nevertheless, I am told that the way to make the cables is to buy a plug-in saver charger (eliminator that goes up the bottom socket) and modify that to make your cable from it. You _must_ buy one with a plug that has adjustable pins. Don't go out and buy one with pins fixed in certain positions since you need to slide them along into the positions shown above. Some may be fixed into the plastic (such as the "Mainline" ones) - Avoid these. If you're lucky the cable to the cigarette lighter will contain 3 wires. That way you can just cut off the lighter plug and solder the 3 wires onto your D-plug. Otherwise you'll need to take your own 3-wire cable from the plug to the D-plug which doesn't look quite as 'neat'. You may have heard a rumour about the Ericsson shutting down after too many ESN changes. I'm afraid I'm not in a position to say either way since I have never owned one. What I _can_ tell you is that I have a friend who has rechipped his at least 30 times with no problems, but I have heard that the maximum number is around 40. I'd love to hear from anyone who knows the real answer. It may be worth your while not using one of these phones for boning a hell of a lot of ESNs on just in case. It's a nice phone to pick up second hand and use for yourself... Anyway, good luck and if you have any comments, suggestions, questions please e-mail them to me at the address below. Hello (as always) to: Mr.Dalvin, DaveX, Disk Wizz, Harl, Jono, Huey, Cherokee & Cybernetik. ----------------------- Ericsson Accessory Connector Pin-outs 1 Audio input 2 +5V=External Power, 0V=Battery 3 PA Speaker control 4 Audio Ground 5 Audio Output 6 Power-on indicator 7 Charger control 8 Digital/DC GND 9 0V=normal,+5V=test, +12V=test+flash 10 hangup signal 11 TTL serial input 12 TTL serial output 13 Power Toggle (hold low 1 second) 14 DC Power supply IN |
wow wow wow!!! this is good 10x luzer u r very great!! kudos to eko too... |
