Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Various CDMA/TDMA Cell Phones
Various CDMA/TDMA Cell Phones All CDMA & TDMA Cell Phones Related Threads are here
Old 08-18-2004, 11:25   #1 (permalink)
eeprom_flash's Avatar
Member: 58599
Thanks Meter: 2
To all analogue phone masters!!
ericsson 237/238 programing
how do u program esn or analogue numbers on analogue phone.
Pls tell it to me and are they belonging to tdma phones?
thanks in advance
Old 08-18-2004, 11:59   #2 (permalink)
eko
eko's Avatar
Member: 30098
Thanks Meter: 29
Ericsson 237/238 are class 4 Etacs phones. Esns are programmed with programming clips.
To enter programming mode you press *923885.
Hope this works for you.
Old 08-18-2004, 12:11   #3 (permalink)
Member: 58599
Thanks Meter: 2
@ eko pls tell me more , i know off key ring this I have and I have hex too pls just gimme a few info I need to enter in any of these analogue phones.....
10x
Old 08-18-2004, 12:21   #4 (permalink)
eko
eko's Avatar
Member: 30098
Thanks Meter: 29
there are 2 types of clips, i need to know the type you are using. is it the remove antenna type.
Was just wandering is 237/238 still available anywhere in the Uk i will like to buy some
Old 08-18-2004, 12:27   #5 (permalink)
Member: 58599
Thanks Meter: 2
I am not in the uk now but i have few of them and I need more soon coming from Italy... i can get u some too, I need the info very well....
i think the one i have is the remove antenna type, the dude that used it in my presence once removed the antenna why inserting codes....
i want u to pls join me in a chat yahoo.. am online
[email protected]
Old 08-18-2004, 12:32   #6 (permalink)
eko
eko's Avatar
Member: 30098
Thanks Meter: 29
i am on icq and msnmessenger
Old 08-18-2004, 13:00   #7 (permalink)
Member: 58599
Thanks Meter: 2
@ eko i just have to download anyway hope we have enof time pls paste here ur email so we can chat
Old 08-18-2004, 13:25   #8 (permalink)
luzer's Avatar
Member: 44659
Thanks Meter: 339
ESN transfer on Ericsson EH237 & EH238
You can activate the built in ESN transfer mode by entering M&922630.
This means hold down the 'M' or function button and then entering 922630
within 10 seconds to activate this mode.
You will need the same serial cable as described at your web site but
this time, you need reverse the data in and data out pins to the other
phone.
Whit the keyboard looking up and you looking at the terminals of the
connector, the terminals are numbered (from left to right) 14 down to 1
Keyboard up
________________
|14 1| Pin 11 is data from external source
Pin 12 is the data to the phone
All data to the phone is at 600 Baud, 8 bits with logic '1' being 4.8V
and logic '0' being 0 V. This means you need an RS 232 to TTL converter
Pin 9 is used to enable you to program the Flash EEPROM in the phone.
Open is the normal operating mode.
+5V is test mode
+12 is Programming mode for ESN's and software changes etc.
Pin 8 is the necessary digital ground for doing anything.
There is yet another test code you can experiment with from the keyboard.
Just enter M& 90510# and the unit will display the overhead message and
status of the phone.
Have fun !
regards
LaserMan
Ericsson EH 1321/237/97
Use at your own risk and responsibility, void in PA USA
[ This is for ETACS phones. I don't know if it works on the AMPS
equivalents, but it probably will ]
EH 237 NAM programming codes:
FCN 923885 (or M 923885)
" 924885"
" 904885"
" 904005"
" 904035"
" 904085"
we can see the ESN and modify the parameters for the NAM.
IMPORTANT! With FCN 904030 we can transfer data,(??) THREE o FOUR times
ONLY. This means you can't clone the phone forever! There may be
another code offering unlimited ESN transfers, or some test-mode option to
reset the counter. Experiment, and let me know if you find anything.
FCN 900000 asks for 5 Pin codes -- ??
EH237 ESN programming:
Either build an ESN Transfer Cable for the Ericsson EH237 and EH238,
or program it directly from your computer with the programming software (ericsson.zip)
The Citronic Cellular Suite :: Ericsson EH237/97
Available from: http://www.geocities.com/SiliconValley/Heights/2675
At last the cellular suite is in wide distribution! Thanks to Phoenix of
CCC for cracking this one. It's been around for a good while now but hadn't
been released to the various p/h bbs's until more recently. Unfortunately,
CCC neglected to include any wiring diagrams for the thing so here they are
for you all to peruse along with a few pointers for running the thing.
::: Loading :::
I am not quite sure why but this software refuses to load if there are any
memory managers loaded. In other words, most of you will need to boot off
a clean floppy rather than your hard drive. To make such a 'bootdisk' use
FORMAT A: /S
from the DOS prompt which will format the disk in your floppy drive and make
it bootable. I don't know why this is the case since the Cheese Factory have
never released software with such problems before.
::: The Cable :::
Much the same as for the Sony CM-H333, the software is self-explanatory, the
only thing you need to know is how to make the cable.
EH97 - View from bottom of phone (Keyboard up):
I I I I I I I I I I I I I I I I
21 11 8
Where 21, 11 and 8 represent the numbers of the D-plug pins you must connect
to. (ie the leftmost pin of the phone must be connected to pin 21 on the
male 25-way D-plug which connects to the printer port of your PC).
EH237 - View from bottom of phone (Keyboard up):
o o o o o o o o o o o o o o
21 8 11
I have _never_ actually made either of these cables, nor rechipped a phone
with it. Nevertheless, I am told that the way to make the cables is to buy
a plug-in saver charger (eliminator that goes up the bottom socket) and
modify that to make your cable from it.
You _must_ buy one with a plug that has adjustable pins. Don't go out and
buy one with pins fixed in certain positions since you need to slide them
along into the positions shown above. Some may be fixed into the plastic
(such as the "Mainline" ones) - Avoid these. If you're lucky the cable to
the cigarette lighter will contain 3 wires. That way you can just cut off
the lighter plug and solder the 3 wires onto your D-plug. Otherwise you'll
need to take your own 3-wire cable from the plug to the D-plug which doesn't
look quite as 'neat'.
You may have heard a rumour about the Ericsson shutting down after too many
ESN changes. I'm afraid I'm not in a position to say either way since I have
never owned one. What I _can_ tell you is that I have a friend who has
rechipped his at least 30 times with no problems, but I have heard that the
maximum number is around 40. I'd love to hear from anyone who knows the real
answer. It may be worth your while not using one of these phones for boning
a hell of a lot of ESNs on just in case. It's a nice phone to pick up second
hand and use for yourself...
Anyway, good luck and if you have any comments, suggestions, questions
please e-mail them to me at the address below. Hello (as always) to:
Mr.Dalvin, DaveX, Disk Wizz, Harl, Jono, Huey, Cherokee & Cybernetik.
Ericsson Accessory Connector Pin-outs
1 Audio input
2 +5V=External Power, 0V=Battery
3 PA Speaker control
4 Audio Ground
5 Audio Output
6 Power-on indicator
7 Charger control
8 Digital/DC GND
9 0V=normal,+5V=test, +12V=test+flash
10 hangup signal
11 TTL serial input
12 TTL serial output
13 Power Toggle (hold low 1 second)
14 DC Power supply IN
Old 08-18-2004, 13:45   #9 (permalink)
Member: 58599
Thanks Meter: 2
wow wow wow!!! this is good 10x luzer u r very great!! kudos to eko too...
[IMG] code is Off
The best softwars to all Sonyericsson phone LordMen007 Sony Ericsson Media, RingTones, Games 0 11-02-2005 23:52
to all (BIG GSM MASTER ) [email protected] HWK 0 08-04-2005 08:35
to all S.E master.t630 memory status go crazy ihwan Sony Ericsson Media, RingTones, Games 0 04-24-2005 03:10
data connect to all BT phones around me AnDxBln Bluetooth-Software 0 03-18-2005 22:42
Page generated in 0.32189 seconds with 8 queries
