Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| Various CDMA/TDMA Cell Phones All CDMA & TDMA Cell Phones Related Threads are here |
| | #1 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Mar 2008 Location: India
Member: 718725 Status: Offline Sonork: 100.1604953 QQ 2339690693 Thanks: 364
| All Micromax CDMA Og Flash File And Flasher Here All Micromax CDMA OG Flash File And Flash With Download Guide Daily Updated Thanks Prem_India |
| The Following 2 Users Say Thank You to Prem_India For This Useful Post: |
| | #2 (permalink) |
| Micromax C100 Flash File And Flasher Micromax C100 (QSC1100) download guide 1. Connect the phone to PC by USB cable. If it is the first time connection, the driver should be installed according to the requirement. 2. After connection successfully, confirm the COM port of the phone. For example: the port of following Picture is COM4. (system properties>hardware>device manager>Ports) http://i1206.photobucket.com/albums/...Micromax/1.jpg 3. Click MutiDL 60X5_11XX_V2.51 in the tool Folder. 4. Then you will get the following interface: You can choose the correct port accordingly, in our example, the port No is COM4, so we select COM4. http://i1206.photobucket.com/albums/...Micromax/2.jpg 5. Select “Open”, you will get the following interface, select Browse, then you can choose the SW in your PC, and choose the file named “config.bmbn” and “open” it. Normally we will mark the “Erase EFS” option. This will erase everything in the phone. http://i1206.photobucket.com/albums/...Micromax/4.jpg 6. press OK in following interface: http://i1206.photobucket.com/albums/...Micromax/3.jpg 7. Click “Start” on your choosing COM port: http://i1206.photobucket.com/albums/...Micromax/5.jpg 8. Wait the downloading, as the following pictures: if the process bar is blue, it means during the download process, please do not interrupt it. If the bar is green, and it shows “Download OK” it means the download is finish. While if the bar is red, it means some failure happens during the download. 9. Finish. When you see the green bar and “Download OK” it means this flashing process is done. http://i1206.photobucket.com/albums/...Micromax/6.jpg Download Here Flash And Flash File Flasher Flash File Driver More Soon B.R., Prem_India |
| The Following 4 Users Say Thank You to Prem_India For This Useful Post: |
| | #3 (permalink) |
| Micromax C111 QSC6010 Micromax C111 QSC6010 Flasher And Flash File With Download Guide Steps to download the software: 1. Double click on the tool name is ‘C118 MultiDL V1.0’ then press start, after complete the process press ‘OK’ button. http://i1206.photobucket.com/albums/..._india/1-6.jpg 2. Now you can the new file name ‘C118 MultiDL V1.0.exe’ in a new page, please double click on the same then you will see the below image. http://i1206.photobucket.com/albums/..._india/2-4.jpg 3. Browse the software through menu File-> Open download file, Select software file. 4. Now Go to menu option->Paramset-> press on button ‘administrator’ and enter the value “3000” as password. http://i1206.photobucket.com/albums/..._india/3-2.jpg 5. Select/click on the box name ‘Download all Erase EFS’ then press button ‘OK’ http://i1206.photobucket.com/albums/..._india/4-1.jpg 6. Now finally clicked on ‘Downward yellow arrow’ button for start to download the software. http://i1206.photobucket.com/albums/..._india/5-1.jpg Note:- If Set Blink Condition Than Press 1 + 3 Than Insert USB Process same as above Download Flasher And Flash File Here Flasher & Driver Flash File More Soon... B.R., Prem_India |
| The Following User Says Thank You to Prem_India For This Useful Post: |
| | #4 (permalink) |
| C111 QSC1100 Flasher And Flash File C111 QSC1100 Flasher And Flash File With Download Guide Note:- Flash Process Is same Like Micromax C100 Flasher Flash file Driver Note:- If Set Blink Condition Than Press 1 + 3 Than Insert USB Process same as above More Soon B.R., Prem_India |
| | #5 (permalink) |
| Password Removing Tool Free Password removing tool Remove Password Without Any Tool Instruction of Password removing tool MutiDL 7625_60X5_11XX 1. Run MutiDL 7625_60X5_11XX_V3.2.exe http://i1206.photobucket.com/albums/...em_india/a.jpg 2. Select Software file by clicking Open button http://i1206.photobucket.com/albums/...m_india/a1.jpg 3. click Browse button and select config.hmbn http://i1206.photobucket.com/albums/...m_india/a2.jpg 4. click Open and OK button and return to MutiDL 7625_60X5_11XX interface. 5. click menu Operator and select Password 0000 item. http://i1206.photobucket.com/albums/...m_india/a3.jpg 6. Type “MM00” into Dialog box and click OK button then the MutiDL7625_60X5_11XX_V3.2 interface will be like the picture as follows http://i1206.photobucket.com/albums/...m_india/a4.jpg 7. Connect phone with data cable to the computer and click 0000 button according to the communication port of the phone. The phone’s password will be set to be 0000 after reset the phone. Download MutiDL7625_60X5_11XX_V3.2 Instruction of Password removing tool More Soon B.R., Prem_India |
| | #6 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2008 Location: i support u
Member: 877336 Status: Offline Sonork: 100.1606970 Thanks: 486
| Quote:
| | #8 (permalink) |
| Micromax C112 Flasher And Flash File Micromax C112 Flasher And Flash File With Download Guide Software Download Process C112 Connect C112 to PC through plane mini USB data cable. Step 1. Install USB Driver From Driver Folder Step 2. Go to mobile flashing software folder. http://i1206.photobucket.com/albums/...em_india/c.jpg Step 3. Then CDMA download tool folder. http://i1206.photobucket.com/albums/...m_india/c1.jpg Step 4. Run the CDMA Download program http://i1206.photobucket.com/albums/...m_india/c2.jpg Step 5. Click SETTING, Enter password wtcdma1218 and click OK http://i1206.photobucket.com/albums/...m_india/c3.jpg Step 6. Go to configure and select files as given below. http://i1206.photobucket.com/albums/...m_india/c4.jpg Step 7. Browse & Select write code file (CODE_Z5805U2_V012_ALL.bin) from “SW_Z5805U2_V012_MICROMAX_HIND_final version.” Folder or any latest version, if available. http://i1206.photobucket.com/albums/...m_india/c5.jpg Step 8. Browse & Select EFS file (EFS_Z5805U2_V012.bin) from “SW_Z5805U2_V012_MICROMAX_HIND_final version.” Or any latest version, if available. http://i1206.photobucket.com/albums/...m_india/c6.jpg Step 9. Then select ‘Change LCD sign’ option and write 61 value manually. http://i1206.photobucket.com/albums/...m_india/c7.jpg Step 10. Press Start and see if download process is running like below. http://i1206.photobucket.com/albums/...m_india/c8.jpg FINISH..... More Soon Download Here FLASHER FLASH FILE DRIVER B.R., Prem_India |
| | #10 (permalink) | |
| Product Supporter ![]() ![]() ![]() Join Date: May 2009 Location: ***Mastertools Helpdesk*** Age: 22
Member: 1023528 Status: Online Sonork: 100.1594367 Thanks: 1,382
| Quote: This Is Old Server !!!!! Not Work More. Br Puneet5154 | |
| The Following User Says Thank You to PUNEET5154 For This Useful Post: |
| | #11 (permalink) |
| Micromax C114 flasher And Flash File Micromax C114 CDMA Flash Dloader Software User Guide 1) Double-click “MultiDloader.exe” to startup the download program. 2)Input the user ID and Password, and then click “OK” to enter the system. http://i1206.photobucket.com/albums/..._india/1-7.jpg A. Input “Operator” in the User ID; and it has no password. B. Click “!” to input “Administrator” automatically. Input “htcdmadload” in the Password. You can enter the system as a manager. 3) After startup, (For example, COM5. Select “Software DownLoad” to update it). If it can not connect the phone http://i1206.photobucket.com/albums/..._india/2-5.jpg IF Set Not Connect A. Check the connection is correct. B. Check the battery has power and the phone already power on, etc. 4) When the connection is correct, it will display the software version http://i1206.photobucket.com/albums/..._india/3-3.jpg 5) Click “Start [COM5]” to update the software. (If you select “Software Repair”, you will download the software to the phone, it will display “Repairing”) http://i1206.photobucket.com/albums/..._india/4-2.jpg 6) The update is successful Download Here Flasher Flash File More Soon B.R., Prem_India |
| | #12 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2008 Location: bhilai(chatisghar)
Member: 900306 Status: Offline Thanks: 942
| Quote:
ftp://sts.micromaxinfo.com:22/mxlive/ same id passward | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
| IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 11-15-2011 12:08 |
| FREECALLING HACKED SIM CARDS AND PROGRAMMERS SEE FREECELL'S NEW SITE FOR MORE!!! | FREECELLUK | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 06-26-1999 22:48 |
| wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 06-13-1999 19:18 |
