Various CDMA/TDMA Cell Phones All CDMA & TDMA Cell Phones Related Threads are here |
03-25-2007, 15:07 | #1 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 465750 Status: Offline Thanks Meter: 44 | All mobile unlocker http://dlarchiv.securitx.de/SIM_Unlo...rs_package.zip My panteck PA-711 is locked but I don't know lock code please help me if you know unlock code for Pantech PA-711 Thank you |
The Following 3 Users Say Thank You to jvd_cool For This Useful Post: |
03-27-2007, 17:34 | #2 (permalink) |
Member: 465750 Status: Offline Thanks Meter: 44 | New CDMA cdes Samsung sph-n240, n400, a460, a500, etc Nam Programming : Nam Set: ##Spc Test Mode: 47*869#1235 Debug Menu: ##33284,ok Service Menu: Menu+8+0 (#889) Reset (Life time, Clear Memory, etc): ##786,ok A-key: ##2539,ok Label Selection: ##3882,ok Label(Home, Work, etc) : **523,ok NGG Setting (Gateway, etc.): ##2769737,ok Vocoder: ##8626337,ok CAI Change: ##7738,ok Enable TTY: ##889,ok Samsung sch-411, 611, n105, a100, a300, a2000, etc Nam Programming : Nam Set: 47*869#08#9 Nam Set: Menu+60 Test Mode: *759#813580 Test Mode: 5809540*45680 A-key: Menu+0, 25## External Audio: Menu+0, #### Debug Menu: Menu+8, 0415 or Spc Debug Menu: Menu+9, 0415 or Spc Brief NAM Programing: Menu+40,626 (not all version) LCD Contrast: Menu+45 (not all version) SIO Mode: Menu+49 SIO Mode: Menu+69 Samsung a530, a610, a620, a660, a670, etc Nam Programming : Nam Set: Menu, 6, * Nam Set: ##3238, ok Nam Set: ##SPC (##000000), ok Service Menu: Menu, 9, * Test Mode: 47*68#13580 Test Mode: 47*869#1235 Samsung X, E, V, S-series (korean models), e250, v420, s350, etc Nam Programming : Nam Set: 6548#0**4#6 Nam Set: 47*869#08#9 Nam Set: 74153697193 Test Mode: 5809540*45680 (88 - EFS reset) Debug Menu: Menu(hold 2sec)+0, 6725 or 9720 or 1973 or 0415 Debug Menu: Menu+0(hold 2sec), 6725 or 9720 or 1973 or 0415 Debug Menu: Home(top of keypad)+0, 6725 or 9720 or 1973 or 0415 Samsung N356 (India version) Nam Programming : Test Mode: Menu, 5, down arrow, * Test Mode: **00## (in some flashes) Samsung i700, etc Nam Programming : Nam Set: Go to start and select "PHONE" from the drop down menu, dial #83587 Samsung i300, etc Nam Programming : 1. Tap on the Phone Icon with stylus 2. Press #907*9#0 ENTER LOCK should appear on screen 3. Enter OTKSL 4. SVC MENU will appear press 1 5. Enter 10 digit MIN and then press SAVE 6. Press SAVE again 7. Press 3 and then press SAVE 6 times 8. Enter the HOME SID and press SAVE once 9. Press END key twice TEST MODE COMMANDS: n105_test_mode.txt a500_test_mode.txt a530_test_mode.txt <<KYOCERA>> -------------------------------------------------------------------------------- Kyocera 2345, 3035, 5135, 6035, Se47, KX, KE - series, etc Nam Programming : Nam Set: 111111+Jog Dial(Ok) CAI Change: ##7738,ok Enable TTY: ##889,ok Life Timer: ##786,ok A-key: ##2539,ok Tips: On some kyocera handsets the factory service module has not been disabled and the phone can be programmed without the spc by inputting. Nam Set: ##333333 menu (service) Qualcomm qcp-800 Nam Pogramming : Nam Set: Menu+3+0+Spc Field Test: Menu+7+0+Fsc <<SANYO>> -------------------------------------------------------------------------------- Sanyo 4900, 5150, 5300, 8100, etc Nam Programming : Nam Set: ##Spc+Ok+Key Down+Ok Advanced Setup: ##3282+Ok+Key Down+Ok+Msl A-key: ##2539+Ok+Key Down+Ok Version: ##**837+Ok+Key Down+Ok Debug Menu: ##FSC+Ok+Key Down+Ok Airtime menu: ##8463+Ok+Key Down+Ok Change CAI: ##7738+Ok+Key Down+Ok Vocoder: ##8626337+Ok+Key Down+Ok Reverse Logistic: ##786+Ok+Key Down+Ok Set IP Address: ##2769737+Ok+Key Down+Ok TTY On/Off: ##889+Ok+Key Down+Ok Ready Link: ##4636+Ok+Key Down+Ok Browser Init On/Off: ##4682+Ok+Key Down+Ok Picture Token: ##25327+Ok+Key Down+Ok Unknown Code: ##5282277+Ok+Key Down+Ok (SPC=000000, FSC=040793) Sanyo scp-A011, smp-A017, etc Nam Programming : Nam Set: F9(3 beep) + 0*72696#767 <<AUDIOVOX>> -------------------------------------------------------------------------------- Audiovox 4000, 9000, 9100, 9155, 9500, etc Nam Programming : Power the phone ON and wait until the little light on top goes out, then press: Nam Set: 289,Fcn, #,1 Service menu: Fcn,0,0, FSC Power the phone ON and press: Test Mode: Hold (2,*,Rcl) + Power Test Mode Commands: 99 - download - flash phone 124 - inam data write 125 - version 126 - get ESN 127 - get SPC 128 - get User lock 129 - is WFTV data write 137 - get FSC code 138 - NPcode (nam program code) 139 - dscode 141 - restart 218 - Read_Addr 000 - is cdma mode 001 - is fm mode 002 - is pcs mode 008 - is reg read addr 020 - is lna_range Audiovox (Hyundai) cdm-100, 130, 135, 8300, 8500, 8600, etc Nam Programming : Nam Set: ##20022002, end Read user lock: #5625*, end DM baud rate: ##2283, end DM mode enable: **1004, end DS mode enable: **1005, end Misc. Test: ##27752345, end S/W Test1: ##27732726, end S/W Test2: ##2240, end Debug screen: ##2773, end Clear MRU: ##6782, end Rfnu_Contents: ##2250, end ?????: ##1133, end ?????: ##1144, end P_Rev: ##7738, end GPS Test: ##4771, end A-Key: 2538** SMS Eng: ##767364, end Battery_adc: ##2768, end Tests: ##1122, end Audiovox 8610, 8910, etc Nam programming : Name Set: ##847446, end, 111111 Audiovox pcx-3500xl Nam Programming : Nam Set: ##2726+Send+1998+1+Spc+1 Audiovox-107 Nam Programming : Nam Set: 45680*47*869#1 Audiovox CMP-3 Nam Programming : Nam Set: 45680*47*869#1 Dm Mode: Menu, 6, 6 Audiovox 9950 Nam Programming : Nam Set: ##3282 Audiovox Z800 (Audiovox 7900, Sharp) Nam Programming : Nam Set: m + # + envelope key + * + 1 Audiovox Thera (Toshiba 2032) Nam Programming : Thera Nam Programming User Manual - nam_thera.pdf <<MOTOROLA>> -------------------------------------------------------------------------------- Motorola 7760, 7860, 2260, 8160, etc Nam Programming : Nam Set: Fcn,0000000000000, Rcl Nam Set: 74663#, Fcn, Fcn Test Mode: Fcn, 00**83786633, Sto Motorola v60c, v120c etc Nam Programming : Nam Set: 74663#, Menu, Menu, Spc Nam Set: Menu, 073887, * (type quickly) Test Mode: Menu, 073887*, Spc Debug Mode: ##33284 Force the phone into DIGITAL ONLY mode: 1) ##33284 (Debug) 2) RIGHT Softkey (Next) Twice 3) Down arrow 10 times to "PrefMod" 4) RIGHT Softkey (Change) until you see "DigOnly" 5) LEFT softkey (Exit) 6) MENU then LEFT Softkey return to idle screen 7) ##33284 (The last 4 will not display if you have done it correctly) Motorola t182, c210, etc Nam Programming : Nam Set: ##298645665, end Short Nam: ##073887, sto Debug Menu: ##1111, end Service Menu: ##2222, end Sound NS/EC on/off switch: ##1113, end Motorola v710, v730, v740, ms150, etc Nam Programming : Nam Set: 8378*# + press 3 times NATE (spc - 071082) Test Mode: Menu, 073887*, Spc Service Menu: #758353266#646# Motorola StarTac 2004 Nam Programming : Nam Set: 5759789*#, rec key (3)times (spc - 915037) Motorola ms200, ms230, etc Nam Programming : Nam Set: 5759789*# (spc - 915037) Motorola v6060 Nam Programming : Nam Set:147*369#456*0# Motorola Razr V3C Nam Programming: Nam Set: 74663 # clr clr Nam Set: #073887* , then SPC Motorola Q Nam Programming: Nam Set: [Send] + 074663 + [Send] + [Send], Selecct NAM# MOTOROLA TEST MODE : v60, c120, c331, etc: 1) Turn on the phone. Press MENU 0 7 3 8 8 7 * 2) The phone will require you to "Enter a Security Code", press 000000, OK 3) Scroll down to "Test mode" choose SELECT. Scroll down to "Enable" choose SELECT. Your phone is now in test mode. 4) Signal strength is the 3_rd number down on the left hand side of the screen. 5) To toggle between regular mode and test mode: Press MODE then quickly press the BUTTON DIRECTLY TO THE LEFT OF MENU. 6) To turn off the test mode the phone must be in regular mode, then follow the above sequence and scroll down to where it says "DISABLE" instead of "ENABLE" and choose select. Motorola Bible - bible.txt <<NOKIA>> -------------------------------------------------------------------------------- Nokia 3280, 3285, 3580, 3585, 5185, 6185, 8280, etc Nam Programming : Nam Set: *3001#12345# Software Version: *#837# Software Version: *#9999# Esn Number: *#92772689# Restart Phone: *#75681# Restart Phone: *#75682# Nokia 8887 Nam Programming : Nam Set: *3001#12345# Version: *#0000# Evrc: *#8378# Esn/Data/Timer: *#92772689# SID: *#743# Nokia 8587 Nam Programming : Nam Set: *#626#7764726# A-Key: #8159357022#4579# (26 digits) A-Key: #8159357022#4547# (20 digits) Version: *#0000# Version: *#837# Vocoder: *#3872# Change language: Menu 5, 3, 1 Change DM mode: *#7678# Debug Screen: *#8378# Debug: *#8380# Field Test Menu: *#83788# SPC Unlock, Factory Reset : Full Factory Reset: *#7370# Resets all settings including non-user changeable items (like SPC) NOKIA TEST MODE: 51xx, 61xx, 71xx, 3285, 63xx, etc : 1) Turn on the phone. Press *3001#12345# 2) Scroll up to where it says "Field Test" and choose SELECT 3) Highlight "Enable" and choose OK. Turn the phone off then back on. 4) If the test mode screen does not show up press MENU and scroll down to "Field Test" choose SELECT. Press 0 1 then choose OK. 5) Lower left or upper left number is the signal strength. 6) To turn off the test mode press MENU and scroll down to where it says "Field Test" choose SELECT. Press 0 0 and then choose OK. 3360, 6360, etc : 1) Turn on the phone. Press *3001#12345# 2) Scroll up to where it says "Field Test" and choose SELECT 3) Highlight "Enable" and choose OK. Turn the phone off then back on. 4) If the test mode screen does not show up press MENU and scroll down to "Field Test" choose SELECT. Press 2 1 0 1 then choose OK. 5) Lower left or upper left number is the signal strength. 6) To turn off the test mode press MENU and scroll down to where it says "Field Test" choose SELECT. Press 2 1 0 0 and then choose OK. <<LG>> -------------------------------------------------------------------------------- Lg LX,VX-series, VX4400, VX6000, etc Nam Programming : Nam Set: ##Spc Nam Set: Menu, 0 Advanced Settings: ##2342 Vocoder: ##8626337,ok CAI Change: ##7738,ok Enable TTY: ##889,ok A-key: ##2539,ok Reset (Life time, Clear Memory, etc): ##786,ok lgc-300, etc Nam Programming : Nam Set: Menu, 9, Spc A-key: Press "Sto" 3sec, 2539** lgc-330w, etc Nam Programming : Nam Set: Menu, 4, 0, Spc A-key: 2539** lgc-510, v111, etc Nam Programming : Nam Set: Menu, 3, 0, Spc A-key: 2539** lgc-500, 800w, etc Nam Programming : Nam Set: Menu, 9 , 0, Spc Debug Mode: Menu, 7, 0, Fsc Debug Mode: Menu, 8, 0, Fsc A-key: 2539** <<ERICSSON / SONY-ERICSSON>> -------------------------------------------------------------------------------- SonyEricsson T608, etc Nam Programming : Nam Set: 923885, joystick >, 111111 Nam Set shot: 987, joystick >, 111111 Nam Set long: 222652, joystick >, 111111 Vocoder: ##8626337, joystick >, 111111 Debug screen: ##33284, joystick > Life Timer: ##786, joystick > SW ver: 9#4#3#, joystick > Edit Profile: ##3282, joystick > Service menu: *#06* Ericsson A1228c, T61, etc Nam Programming : Short NAM: 987+Menu Long NAM: 923885+Menu+Spc CDMA Mode: 904093+Menu Analog Mode: 904095+Menu QNC: 904097+Menu Debug Screen: 904090+Menu DM Mode: 904050+Menu <<SK TELETECH>> -------------------------------------------------------------------------------- Sky All Models Nam Programming : Nam Set: #7583538324#626# Nam Set: *759#364*7388464# Min simple mode: #758353266#646# Irm simple mode #758353266#476# Voice memo: #8767#277# Test Mode: #7583538324#8378# A-key: #758353266#2539# Service Menu: Menu+4+0+Spc Service Menu: Menu+5+0+Spc <<WITHUS / MODOTTEL>> -------------------------------------------------------------------------------- Withus wce-100, 200, 300, etc Nam Programming : Nam Set: ##948487+Save Nam Set: ##948482+Save Nam Set: ##66835+Save SMS Settings: ##76766 NVM Rebuild: ##777464 <<HYUNDAI>> -------------------------------------------------------------------------------- Hyundai hwp-110 Nam Programming : Nam Set: #86904**89397# DM Mode: ##2740* (Open phone, inter code, close phone) Hyundai hgc-120, 130, 200 Nam Programming : Nam Set: #86904**89397# Hyundai hgc-310, 600, 610 Nam Programming : Nam Set: ##20022002, end, 1, Spc Code Field Test: ##20022002, end, 1, Master Code Hyundai Curitel h100, 150, hx510b, 520, etc Nam Programming : Nam Set: ##20022002, end, 1, Spc Code Field Test: ##20022002, end, 1, Master Code A-key: 2539** Debug Menu: ##27732726, end Sar Test: ##27752345, end Baud Rate: ##36**, end DM mode enable: **1004, end DS mode enable: **1005, end Test Bell/Voice/Led/Dot: ##1122, end RF Mode: ##2240, end Ras Ram: ##2774, end Cmux1: **0481, end Cmux2: **0482, end RX Mode Fax: **0492, end RX Mode Data: **0491, end RX Mode Reset: **0490, end <<HUAWEI>> -------------------------------------------------------------------------------- Huawei ETS-668, 678, 688, etc Nam Programming : Debug Mode: ##44+Menu Debug Screen: ##33+Menu CDG2 Test enable: ##234+Menu CDG2 Test disable: ##432+Menu China Lang Select: ##123+Menu Blocking Debug Code: ###888+Menu Home System Only On: ##461+Menu Home System Only Off: ##460+Menu Master Code for all Huawei models is - 309296 <<EPSILON / COMPAL>> -------------------------------------------------------------------------------- Epsilon vc-5x, Compal 1100, etc Nam Programming : Nam Set:: **321456987## Short Nam: **147258963## Service Menu 1: **1232580## Service Menu 2: **078987## Service Menu 3: **1234756## Show SPC: **3214569871472365## Version: **1470963## Debug: **000000## A-key: 2539** Reset: **14789## <<VK MOBILE>> -------------------------------------------------------------------------------- VK-100C, 110C, 200C, etc Nam Programming : Nam Set: 153147539741593 Test Mode: 153147539123258 (88 - clear efs) <<GIGA TELECOM>> -------------------------------------------------------------------------------- Z510, Z710i(gcd-456) Nam Programming : Nam Set: Menu+0+Spc <<AnyDATA>> -------------------------------------------------------------------------------- AMC450 Nam Programming : Nam Set: *74269#*748#96148063+SEL <<ZTE>> -------------------------------------------------------------------------------- ZTE C150 Nam Programming: Nam Set: *983*3641# <<GTRAN>> -------------------------------------------------------------------------------- Gtran gcp-2000 Nam Programming : Nam Set: 01#737+Spc Debug Menu: 01#324+Spc Debug Mode: 01#727 Test Mode: 01#764+Spc System Test Mode: 01#768+Spc Gtran gcp-5000 Nam Programming : Debug Mode: 01#727+Spc Test Mode: 01#765 <<PANASONIC>> -------------------------------------------------------------------------------- PANASONIC TEST MODE : Panasonic (Most): 1) Turn on the phone. Press #7764726# choose SEND 2) Scroll down to where it says "NAM 1" and choose OK. Scroll down to "Access To Level 4" choose YES. Scroll down to "Built-In-Monitor" and choose EDIT. 3) Press 1 and choose OK then choose BACK. The phone will say "Back To Level 1" choose YES. Now choose EXIT the phone will ask you "Exit And Save Change" choose YES. 4) Signal strength is the top right number on the screen. 5) To turn off the test mode follow the above sequence except press 0 instead of 1 at the "Built-In-Monitor" <<SYNERTEK>> -------------------------------------------------------------------------------- Synertek S200 Nam Programming : Nam Set: Menu+0+Spc Debug Mode: Test vibro/rx/tx: ##5555+Save Debug Screen: ##33+Save Debug Screen: ##523+Save RF Test: ####+Save Unknown code: ##325+Save <<SONY>> -------------------------------------------------------------------------------- Sony CM-M1300, 3300, Z200 Nam Programming : Nam Set: 111111+Ok(Jog Dial)+Select+Programming+Ok+Spc |
03-27-2007, 17:35 | #3 (permalink) |
Member: 465750 Status: Offline Thanks Meter: 44 | Other CDMA codes all cdma codes -------------------------------------------------------------------------------- Samsung: All type of phones (old modeles): NAM programming: 47*869#08#9 Test mode: *759#813580 or 5809540*45680 exit test mode - 02 A-Key: menu + 0, code 25## Samsung A500 1. Enter ## and the 6 digit OTKSL 2. SERVICE MENU will appear and 1.Basic will be highlighted 3. Press OK 4. Device will display NAM CDMA/ Phone Number 5. Enter 10 digit MIN 6. Press OK (3 times) 7. Display will return to Service Menu. Press END. 8. Programming is complete Samsung N240 and N400 1. Enter ## and type in the 6 digit OTKSL 2. The display will show SVC MENU and 1. Phone Number 3. Press OK 4. Enter the 10 digit MIN and press OK 5. The display will show NAM with Home SID on the second line (Note: SID is no longer used) 6. Press OK 7. The display will return to the SVC MENU 8. Press END to complete the programming Samsung Uproar 1. Press MENU key 2. Enter 9 2 0 3. Enter the OTKSL 4. At SVC Menu screen press OK 5. Enter MIN and press OK 4 times 6. Enter SID (4654) and press OK 7. Press END key 8. Programming is complete Samsung N300 1. Press ## followed by the OTKSL 2. SVC menu will be displayed 3. Press 1 for Phone # 4. Enter the 10 digit MIN and press OK 5. MIN that was entered will be displayed press OK 6. SVC Menu will display press 3 for NAM 7. Enter the 4 digit Home SID press OK 8. Press END and handset will power cycle Samsung i300 1. Tap on the Phone Icon with stylus 2. Press #907*9#0 ENTER LOCK should appear on screen 3. ENTER OTKSL 4. SVC MENU will appear press 1 5. Enter 10 digit MIN and then press SAVE 6. Press SAVE again 7. Press 3 and then press SAVE 6 times 8. Enter the HOME SID and press SAVE once 9. Press END key twice Samsung A400 and A460 1. Enter ## and OTKSL 2. Press 1 for Basic at MENU (1 of Phone # when using the MSL) 3. Enter 10 digit MIN and press OK 4. At 1.Basic Menu press the END key 5. Handset will power cycle Samsung 3500 8500 6100 N200 1. Press MENU 2. Press 6 0 (3500) 8 2 0 (8500/6100/N200) 3. Enter OTKSL 4. Press 1 at SVC MENU Screen 5. Enter MIN and press OK 6. Press OK 4 times 7. Enter SID (4654) and press OK 8. Press END key 9. Programming is complete Qualcomm: QCP-800 programming: menu + 3 + 0. SPC: "000000" or may be other SPC typed by user. QCP-820/1920/2035: type "111111" and press Jog Dial. Choose "Programming" and enter SPC: "000000" or may be other SPC typed by user. QCP 1960 and 2760 1. Press softkey under the work MENU 2. Press 8 0 3. Enter the OTKSL 4. Press softkey for OK 5. Enter MIN and press softkey for OK 6. No SID is require for this handset 7. Press softkey for EXIT 8. Programming is complete LG: LGC-300 programming: menu + 9 and enter SPC: "000000" or may be other SPC typed by user A-Key: press STO for some time while you can see special code enter zone. Type 2539** and enter A-key LGC-330W programming: menu + 4 + 0 and enter SPC: "000000" or may be other SPC typed by user. A-Key: type 2539** and enter A-key LGC-800W /500 programming: menu + 0 and enter SPC: "000000" or may be other SPC typed by user. A-Key: type 2539** and enter A-key LGC-510 programming: menu + 3 + 0 and enter SPC: "000000" or may be other SPC typed by user. A-Key: type 2539** and enter A-key LG1010 LG4NE1 TP2200 TP2100 Touchpoint SB/DB TP 1100 TP5200 1. Press ## 2. Enter the OTKSL 3. Scroll to SAVE and press OK 4. Scroll to MIN and press OK 5. Enter 10 digit MIN scroll to SAVE and press OK 6. Scroll to SID and press OK (Skip on 4NE1 go to RESET PHONE and press OK to complete) 7. Enter SID (4654) and scroll to SAVE and press OK 8. Programming is complete LG5350 1. Enter ## and enter the OTKSL and press the left soft key under the word “Save” 2. At the Service Program display select Mobile Phone # and press the OK in the center of the 4 way navigation key 3. Enter the 10 digit MIN and press OK 4. Scroll down to 4. Advanced and press OK 5. Scroll to NMSI and press OK 6. Enter the MSID and press OK 7. Scroll down to 9. Amps Phone # and press OK 8. Enter the MSID and press OK 9. Press the END key TP 2100 1. Press ## 2. Enter OTKSL 3. Scroll to SAVE and press Roller Ball in for OK (ESN will display) 4. Select NEXT (by pressing in the roller ball) 5. Scroll to EDIT and press in the roller ball 6. Enter MIN 7. Scroll to SAVE and press roller ball in 8. Select NEXT at the next 3 screens and then EXIT 9. Programming is complete TP3000 1. Press ## 2. Enter OTKSL 3. Scroll to SAVE and press OK 4. Open flip 5. Use Stylus to enter the 10 digit MIN 6. Press OK (No SID entry is required) 7. Programming is complete TP 5250 1. Press ## 2. Enter the OTKSL 3. Scroll to SAVE and press OK 4. The phone display will read SVC Program 5. Scroll to MOBILE PHONE # and press OK 6. Phone display will read Mobile Phone Number 7. Enter the 10 digit MIN and press OK 8. Scroll to Home SID and press OK 9. Enter the 4 digit SID (4654) and press OK 10. Reset Phone will be highlighted. Press OK 11. Phone will reset 12. Programming is complete LG V111(DM110) [menu]30. After ask lockcode, enter: 843691. Ericsson: Programming: Shot NAM 987 + menu Long NAM 923885 + menu and enter SPC: "000000" or may be other SPC typed by user. CDMA mode 904093 + menu Analog mode 904095 + menu DM mode 904959 + menu Hyundai: HGC-120E / -130E programming: #86904**89397# HGC-600E programming: ##20022002, END and enter SPC: "000000" or may be other SPC typed by user. Sony: CM-M1300/3300/Z200 programming: type "111111" and press Jog Dial. Choose "Programming" and enter SPC: "000000" or may be other SPC typed by user. Sony CM-M1300 1. Power phone on 2. Enter six "1s" ( 111111 ) 3. Press the jog dial in 4. Press the jog dial in again to select programming 5. Enter six "0s" for the service security code 6. Phone displays the ESN 7. Press the jog dial in for OK 8. Enter your ten digit cellular telephone number 9. Press the jog dial in for OK 10. Enter your cellular carrier’s system ID (SID) without the zeros (Example: if your carrier’s system ID is 00035, enter just 35) 11. Press the jog dial in for OK 12. Enter a name for NAM 1 or just press the jog dial in for OK 13. Phone displays Basic NAM 1 Programming is complete 14. Press the jog dial in 15. Press the jog dial in again for EXIT 16. Phone powers itself off 17. Press the power button to power the phone back on 18. Basic programming is complete Motorola: StarTAC 7760/7860 programming: Service menu: FCN+0+000000+000000+RCL Test mode: FCN 00**83786633 STO V60c programming: Service menu: 74663 # [Menu] [Menu] (programming code) Test mode: [Menu] 073887 * (security code = 000000) Motorola Tarpon (120x) 1. Press 74663 (spells PHONE) 1. Press # MENU MENU quickly 2. Enter OTKSL 3. The work MIN will be highlighted 4. Select the word CHANGE by selecting the top right button 5. Select DELETE. Press and hold the button until clear 6. Have the customer enter the 10 digit MIN number 7. Select OK with the top right button. The “User Activation” screen will appear 8. Scroll to highlight the CDMA Sys ID 9. Select CHANGE by selecting the top right button 10. Enter SID 11. Select OK by selecting the top right button 12. Select DONE with the top left button 13. Press the END key 14. Press # MENU MENU quickly 15. Enter OTKSL 16. The work MIN will be highlighted 17. Select the word CHANGE by selecting the top right button 18. Select DELETE. Press and hold the button until clear 19. Have the customer enter the 10 digit MIN number 20. Select OK with the top right button. The “User Activation” screen will appear 21. Scroll to highlight the CDMA Sys ID 22. Select CHANGE by selecting the top right button 23. Enter SID 24. Select OK by selecting the top right button 25. Select DONE with the top left button Press the END key Motorola Phones (ALL) 1. Enter 74663 # FCN FCN 2. Enter OTKSL 3. Enter MIN and press STO 4. Enter SID (4654) and press STO 5. Press STO again – programming is complete Note: on the Tarpon (120C) you will need to press the MENU key instead of FCN. Nokia: 5185/6185 programming: *3001#12345# Software version: *#837# or *#VER# or *#9999# Serial / ESN: *#92772689# or *#WARRANTY# Phone reset: *#75681# or *#75682# Nokia 6185-5170 1. Press *#639# 2. Enter OTKSL and press OK 3. Enter the MIN and select OK 4. Enter the SID and select OK 5. Programming is complete Nokia 3585 1. Enter ## followed by the OTKSL 2. Number (MDN) is highlighted. Press the upper left-hand soft key to select 3. Mobile Number will display. Enter the 10 digit MIN 4. Press OK 5. IMSI will appear. Press and hold the Clear key until the display is empty. 6. Enter 31000 plus the MSID (15 digits total) 7. Press the upper left hand soft key and select OK 8. It will take you back to the SVC Programming. Press the upper right hand soft key to select EXIT 9. Press END. 10. Phone will power cycle and programming is complete. SK Teletech: SK-IM 1000/1400/2000/2200/2400 programming: #7583538324#626# Getrun 2000: System NAM programming mode: 0 + 1 + # + 7 + 3 + 7 + SECURITY CODE (000000) Debug menu: 0 + 1 + # + 3 + 2 + 4 + SECURITY CODE (000000) Debug screen of field test mode: 0 + 1 + # + 7 + 2 + 7 Test mode: 0 + 1 + # + 7 + 6 + 4 + SECURITY CODE (000000) System test mode: 0 + 1 + # + 7 + 6 + 8 + SECURITY CODE (000000) NEOPOINT: Neopoint 1000 1. Press M to display Main Menu 2. Scroll to PREFERENCES 3. Press softkey under SELECT 4. Enter 040793 5. Scroll to PROGRAMMING 6. Press softkey under SELECT 7. Enter OTKSL 8. Press softkey under DONE 9. Scroll to PHONE NUMBER 10. Enter 10 digit MIN 11. Scroll to HOME SID 12. Enter SID (4654) 13. Press softkey under SAVE to exit 14. Programming is complete NEOPOINT 1600 1. Power the phone on 2. Press the "Menu" key 3. Scroll to "Preferences" - press "Select" 4. Key in the "Field Service Code" (the phone will not prompt you for the code) at the "preferences" screen to access the "Service" menu (Default code is "000000") 5. Scroll to "Programming" - press "Select" - the phone will ask for the "Subsidy Lock Code" 6. Enter the "Subsidy Lock Code(654321)" to access the "NAM" menu 7. Select the NAM to be programmed (NAM 1 or NAM 2) 8. Program the NAM - Phone number and CDMA Home SID 9. After programming has been completed press "Save" - the phone will reset Audiovox: Audiovox 9100 1. Press ## 2. Enter the OTKSL 3. Display will read Service/Menu 1 Basic…press OK 4. Next screen will read Service Mode/Home SID…press OK 5. Next screen will read Service Mode/Home SID…press OK 6. Device will display Service Menu 1. Basic # 7. Press END button to complete programming Handspring TREO: 1. Open the flip and press the PHONEBOOK button one time to display the dial pad 2. Enter ## and the OTKSL using the numbers on the Dial Pad 3. Press the handset button shown in the diagram above 4. At the Activations screen enter the MIN in the phone number field using the numbers on the device keyboard 5. Put a check in the Enable Number Portability box and type the MSID in the MSIN field 6. Press OK 7. The device will display the network search pop-up and return to the Phonebook display Hitachi P300: 1. Enter ## and the 6 digit OTKSL 2. Press the Options soft key and then scroll to Save Phone #. Press the OK soft key. 3. At the NAM display scroll to EDIT and press the OK soft key 4. Display will read NAM and MDN will be highlighted. Press the OK soft key. 5. At the MDN display enter the 10 digit MIN and press the SAVE soft key. 6. At the Save prompt press the OK soft key. The next display will show several options that should not edited. 7. Press the EXIT soft key and the device will power cycle. 8. Programming is complete. Kyosera: Kyocera 2345 1135 1. Press 111111 (#1 key 6 times) 2. Option will be highlighted 3. Press OK 4. Scroll down to Programming 5. The service programming dialog will appear Enter Security Code. 6. Enter the 6 digit OTSKL (code will show as asterisks on screen) 7. Service Options will appear 8. Scroll down to the BASIC NAM1 Info 9. Press OK 10. Select the Phone Number by pressing the OK key 11. Using the keypad enter the 10 digit MIN 12. Press OK 13. Press END to complete the programming Kyocera 6035 1. Press 1 six times (111111) and select OPTIONS 2. Select PROGRAMMING 3. Open flip 4. Tap the OTKSL on keypad on the screen. Tap OK 5. Tap on the PHONE NUMBER field. Enter MIN. 6. Leave A-KEY blank 7. Enter HOME SID (4654) 8. Tap SAVE & EXIT 9. Tap YES 10. Phone will be in OFF MODE Close flip. Kyocera 3035 1. Press 111111 (the #1 key six times) 2. Options will be highlighted 3. Press in the navigation key (Navigation key is the button located between the TALK & END key) 4. Scroll to PROGRAMMING using the Navigation key 5. Select PROGRAMMING by pressing in the Navigation key 6. Enter the six digit OTKSL and press in the navigation key 7. SERVICE OPTIONS will appear 8. Scroll down to the Basic NAM1 info 9. Press in the navigation key 10. Clear any numbers that may appear using the “clear” key (arrow key located directly below the navigation key) 11. Select the PHONE NUMBER by pressing in the navigation key 12. Enter the 10 digit MIN select OK by pressing in the navigation key 13. Press END. Programming is complete. Kyocera 2255 1. Press the 1 key six times (111111) “Option will be highlighted 2. Press OK 3. Scroll down to “Programming” and press “OK” 4. Enter OTKSL and press the navigation key 5. “Service Options” will appear scroll down to the “Basic NAM1 Info” 6. Press OK 7. Select Phone Number by pressing OK 8. Enter MIN and press OK again 9. Scroll to Home SID and press OK 10. Enter SID (4654) and press OK 11. Press END. Programming is complete. QCP 2035 1. Press 1 six times (111111) 2. Press u key to select OPTIONS 3. Highlight PROGRAMMING and press u key 4. Enter OTKSL 5. ESN will appear press left arrow key to select OK 6. Enter MIN and press ç key 7. Press ç key again to exit - Programming is complete Sanyo: Sanyo 4000 4500 4700 5000 6000 1. Press ## 2. Enter the OTKSL 3. Scroll to SAVE and press OK 4. ESN will be displayed – press OK 5. Enter 10 digit MIN and press OK 6. Enter SID (4654) and press OK 7. Press OK twice 8. Programming is complete Sanyo 5150 5300 and 6400 1. Enter ## followed by the OTKSL 2. Press MENU SAVE PHONE # 3. Press Ok 4. SVC Programming will be displayed. Scroll and highlight Mobile Number. Press OK 5. Press OK again 6. ESN will be displayed. Press OK 7. Mobile Number will be displayed enter the 10 digit MIN press OK 8. Press OK 4 times 9. Phone will power cycle 10. Programming is complete Sanyo 6000 1. Press ## 2. Enter OTKSL 3. Press MENU Key and scroll to SAVE PHONE # and press OK 4. ESN will be displayed press OK 5. Enter MIN and press OK 6. Enter SID and press OK 7. Press OK twice more 8. Programming is complete Sanyo 4900 1. Enter ## followed by the 6 digit OTKSL 2. Press the MENU/OK key and scroll and highlight SAVE PHONE # 3. Press MENU/OK 4. Scroll and highlight MOBILE NUMBER press OK 5. At the ESN display press OK 6. In the MOBILE NUMBER screen enter your MIN and press OK 4 times 7. At the service program menu scroll to exit and press the MENU/OK key. 8. Programming is complete Sanyo 6200 1. Enter ## 2. Enter OTKSL 3. Press the MENU key and scroll to highlight SAVE PHONE # 4. Press OK 5. Scroll and highlight MOBILE NUMBER 6. Press OK twice 7. Scroll and highlight EXIT 8. Press OK 9. Phone will power cycle 10. Programming is complete Toshiba: Toshiba 2032P 1. Slide the Radio Standby Switch on the left side of the device to the upper side (ON) to activate the phone function. This is the switch with the phone icon over it 2. After power up is completed use the stylus to tap on the ADMIN pull up menu at the bottom of the screen and select ACTIVATION WIZARD. If your device has not yet been activated the ACTIVATION WIZARD will automatically start when you turn on the radio in your device. 3. Tap NEXT 3 times. If the device has been previously activated it will require only 2 presses. 4. On the fourth screen enter the 6 digit OTKSL using keyboard 5. Enter the MIN in both entery fields then tap NEXT 6. Wait for the device to initialize and display “ready to connect” 7. To initiate IOTA tap the word ADMIN at the bottom of the display and then Data Provisioning 8. Programming is complete ******* Here is a list of various codes to try out. Some may require an MSL to be able to make full use of the functionality. ##2769737 [##BROWSER] - MiniBrowser Settings (2G) ##8626337 [##VOCODER] - Set Vocoder ##3282 [##DATA] - Setup Menu for Vision handsets ##8463 [##TIME] - Airtime Menu ##040793 - Debug Menu ##786 [##RUN] - Technical Information (be careful with this one, you can reset the handset) ##932 [##WEB] - IP Address information (2G) ##889 [##TTY] - TTY On or TTY Off ##4357 [##HELP] - Help |
03-27-2007, 17:37 | #4 (permalink) |
Member: 465750 Status: Offline Thanks Meter: 44 | LG CDMA CODES LG 2030 V15 SARVICE MODE IS: 720829771104 ================================================== ====== LG 2030 Ver.11 service mode is 951753951753 ================================================== ====== menu+0+"SPC"/000000 for v8 and 770214790102 ================================================== == #542362#*737130* 7130 nam ===================================== rd 6130 sarvice programming code is: #542362#*6130* ================================================== == RD 6130 rd 6130 sarvice programming code is: #542362#*736130* ================================================= RD5130 Service programming Code is #542362#*735130* ================================================== ==== RD 2030 11 VER--951753951753 RD 2030 15 & 17 VER--720829771104 RD 2130, RD 2330--#542362#*542362* RD 5130--#542362#*735130* RD 6130--#542362#*736130* ======================================= Lg LX,VX-series, VX4400, VX6000, etc Nam Programming : Nam Set: ##Spc Nam Set: Menu, 0 Advanced Settings: ##2342 Vocoder: ##8626337,ok CAI Change: ##7738,ok Enable TTY: ##889,ok A-key: ##2539,ok Reset (Life time, Clear Memory, etc): ##786,ok =============================================== lgc-300, etc Nam Programming : Nam Set: Menu, 9, Spc A-key: Press "Sto" 3sec, 2539** ---------------------------------- lgc-330w, etc Nam Programming : Nam Set: Menu, 4, 0, Spc A-key: 2539** ----------------------------- lgc-510, v111, etc Nam Programming : Nam Set: Menu, 3, 0, Spc A-key: 2539** ------------------------------- lgc-500, 800w, etc Nam Programming : Nam Set: Menu, 9 , 0, Spc Debug Mode: Menu, 7, 0, Fsc Debug Mode: Menu, 8, 0, Fsc A-key: 2539** ============================ |
03-28-2007, 15:47 | #5 (permalink) |
Member: 465750 Status: Offline Thanks Meter: 44 | Other New Codes =============== Samsung: All type of phones (old modeles): NAM programming: 47*869#08#9 Test mode: *759#813580 or 5809540*45680 exit test mode - 02 A-Key: menu + 0, code 25## Samsung A500 1. Enter ## and the 6 digit OTKSL 2. SERVICE MENU will appear and 1.Basic will be highlighted 3. Press OK 4. Device will display NAM CDMA/ Phone Number 5. Enter 10 digit MIN 6. Press OK (3 times) 7. Display will return to Service Menu. Press END. 8. Programming is complete Samsung N240 and N400 1. Enter ## and type in the 6 digit OTKSL 2. The display will show SVC MENU and 1. Phone Number 3. Press OK 4. Enter the 10 digit MIN and press OK 5. The display will show NAM with Home SID on the second line (Note: SID is no longer used) 6. Press OK 7. The display will return to the SVC MENU 8. Press END to complete the programming Samsung Uproar 1. Press MENU key 2. Enter 9 2 0 3. Enter the OTKSL 4. At SVC Menu screen press OK 5. Enter MIN and press OK 4 times 6. Enter SID (4654) and press OK 7. Press END key 8. Programming is complete Samsung N300 1. Press ## followed by the OTKSL 2. SVC menu will be displayed 3. Press 1 for Phone # 4. Enter the 10 digit MIN and press OK 5. MIN that was entered will be displayed press OK 6. SVC Menu will display press 3 for NAM 7. Enter the 4 digit Home SID press OK 8. Press END and handset will power cycle Samsung i300 1. Tap on the Phone Icon with stylus 2. Press #907*9#0 ENTER LOCK should appear on screen 3. ENTER OTKSL 4. SVC MENU will appear press 1 5. Enter 10 digit MIN and then press SAVE 6. Press SAVE again 7. Press 3 and then press SAVE 6 times 8. Enter the HOME SID and press SAVE once 9. Press END key twice Samsung A400 and A460 1. Enter ## and OTKSL 2. Press 1 for Basic at MENU (1 of Phone # when using the MSL) 3. Enter 10 digit MIN and press OK 4. At 1.Basic Menu press the END key 5. Handset will power cycle Samsung 3500 8500 6100 N200 1. Press MENU 2. Press 6 0 (3500) 8 2 0 (8500/6100/N200) 3. Enter OTKSL 4. Press 1 at SVC MENU Screen 5. Enter MIN and press OK 6. Press OK 4 times 7. Enter SID (4654) and press OK 8. Press END key 9. Programming is complete Qualcomm: QCP-800 programming: menu + 3 + 0. SPC: "000000" or may be other SPC typed by user. QCP-820/1920/2035: type "111111" and press Jog Dial. Choose "Programming" and enter SPC: "000000" or may be other SPC typed by user. QCP 1960 and 2760 1. Press softkey under the work MENU 2. Press 8 0 3. Enter the OTKSL 4. Press softkey for OK 5. Enter MIN and press softkey for OK 6. No SID is require for this handset 7. Press softkey for EXIT 8. Programming is complete LG: LGC-300 programming: menu + 9 and enter SPC: "000000" or may be other SPC typed by user A-Key: press STO for some time while you can see special code enter zone. Type 2539** and enter A-key LGC-330W programming: menu + 4 + 0 and enter SPC: "000000" or may be other SPC typed by user. A-Key: type 2539** and enter A-key LGC-800W /500 programming: menu + 0 and enter SPC: "000000" or may be other SPC typed by user. A-Key: type 2539** and enter A-key LGC-510 programming: menu + 3 + 0 and enter SPC: "000000" or may be other SPC typed by user. A-Key: type 2539** and enter A-key LG1010 LG4NE1 TP2200 TP2100 Touchpoint SB/DB TP 1100 TP5200 1. Press ## 2. Enter the OTKSL 3. Scroll to SAVE and press OK 4. Scroll to MIN and press OK 5. Enter 10 digit MIN scroll to SAVE and press OK 6. Scroll to SID and press OK (Skip on 4NE1 go to RESET PHONE and press OK to complete) 7. Enter SID (4654) and scroll to SAVE and press OK 8. Programming is complete LG5350 1. Enter ## and enter the OTKSL and press the left soft key under the word “Save” 2. At the Service Program display select Mobile Phone # and press the OK in the center of the 4 way navigation key 3. Enter the 10 digit MIN and press OK 4. Scroll down to 4. Advanced and press OK 5. Scroll to NMSI and press OK 6. Enter the MSID and press OK 7. Scroll down to 9. Amps Phone # and press OK 8. Enter the MSID and press OK 9. Press the END key TP 2100 1. Press ## 2. Enter OTKSL 3. Scroll to SAVE and press Roller Ball in for OK (ESN will display) 4. Select NEXT (by pressing in the roller ball) 5. Scroll to EDIT and press in the roller ball 6. Enter MIN 7. Scroll to SAVE and press roller ball in 8. Select NEXT at the next 3 screens and then EXIT 9. Programming is complete TP3000 1. Press ## 2. Enter OTKSL 3. Scroll to SAVE and press OK 4. Open flip 5. Use Stylus to enter the 10 digit MIN 6. Press OK (No SID entry is required) 7. Programming is complete TP 5250 1. Press ## 2. Enter the OTKSL 3. Scroll to SAVE and press OK 4. The phone display will read SVC Program 5. Scroll to MOBILE PHONE # and press OK 6. Phone display will read Mobile Phone Number 7. Enter the 10 digit MIN and press OK 8. Scroll to Home SID and press OK 9. Enter the 4 digit SID (4654) and press OK 10. Reset Phone will be highlighted. Press OK 11. Phone will reset 12. Programming is complete LG V111(DM110) [menu]30. After ask lockcode, enter: 843691. Ericsson: Programming: Shot NAM 987 + menu Long NAM 923885 + menu and enter SPC: "000000" or may be other SPC typed by user. CDMA mode 904093 + menu Analog mode 904095 + menu DM mode 904959 + menu Hyundai: HGC-120E / -130E programming: #86904**89397# HGC-600E programming: ##20022002, END and enter SPC: "000000" or may be other SPC typed by user. Sony: CM-M1300/3300/Z200 programming: type "111111" and press Jog Dial. Choose "Programming" and enter SPC: "000000" or may be other SPC typed by user. Sony CM-M1300 1. Power phone on 2. Enter six "1s" ( 111111 ) 3. Press the jog dial in 4. Press the jog dial in again to select programming 5. Enter six "0s" for the service security code 6. Phone displays the ESN 7. Press the jog dial in for OK 8. Enter your ten digit cellular telephone number 9. Press the jog dial in for OK 10. Enter your cellular carrier’s system ID (SID) without the zeros (Example: if your carrier’s system ID is 00035, enter just 35) 11. Press the jog dial in for OK 12. Enter a name for NAM 1 or just press the jog dial in for OK 13. Phone displays Basic NAM 1 Programming is complete 14. Press the jog dial in 15. Press the jog dial in again for EXIT 16. Phone powers itself off 17. Press the power button to power the phone back on 18. Basic programming is complete Motorola: StarTAC 7760/7860 programming: Service menu: FCN+0+000000+000000+RCL Test mode: FCN 00**83786633 STO V60c programming: Service menu: 74663 # [Menu] [Menu] (programming code) Test mode: [Menu] 073887 * (security code = 000000) Motorola Tarpon (120x) 1. Press 74663 (spells PHONE) 1. Press # MENU MENU quickly 2. Enter OTKSL 3. The work MIN will be highlighted 4. Select the word CHANGE by selecting the top right button 5. Select DELETE. Press and hold the button until clear 6. Have the customer enter the 10 digit MIN number 7. Select OK with the top right button. The “User Activation” screen will appear 8. Scroll to highlight the CDMA Sys ID 9. Select CHANGE by selecting the top right button 10. Enter SID 11. Select OK by selecting the top right button 12. Select DONE with the top left button 13. Press the END key 14. Press # MENU MENU quickly 15. Enter OTKSL 16. The work MIN will be highlighted 17. Select the word CHANGE by selecting the top right button 18. Select DELETE. Press and hold the button until clear 19. Have the customer enter the 10 digit MIN number 20. Select OK with the top right button. The “User Activation” screen will appear 21. Scroll to highlight the CDMA Sys ID 22. Select CHANGE by selecting the top right button 23. Enter SID 24. Select OK by selecting the top right button 25. Select DONE with the top left button Press the END key Motorola Phones (ALL) 1. Enter 74663 # FCN FCN 2. Enter OTKSL 3. Enter MIN and press STO 4. Enter SID (4654) and press STO 5. Press STO again – programming is complete Note: on the Tarpon (120C) you will need to press the MENU key instead of FCN. Nokia: 5185/6185 programming: *3001#12345# Software version: *#837# or *#VER# or *#9999# Serial / ESN: *#92772689# or *#WARRANTY# Phone reset: *#75681# or *#75682# Nokia 6185-5170 1. Press *#639# 2. Enter OTKSL and press OK 3. Enter the MIN and select OK 4. Enter the SID and select OK 5. Programming is complete Nokia 3585 1. Enter ## followed by the OTKSL 2. Number (MDN) is highlighted. Press the upper left-hand soft key to select 3. Mobile Number will display. Enter the 10 digit MIN 4. Press OK 5. IMSI will appear. Press and hold the Clear key until the display is empty. 6. Enter 31000 plus the MSID (15 digits total) 7. Press the upper left hand soft key and select OK 8. It will take you back to the SVC Programming. Press the upper right hand soft key to select EXIT 9. Press END. 10. Phone will power cycle and programming is complete. SK Teletech: SK-IM 1000/1400/2000/2200/2400 programming: #7583538324#626# Getrun 2000: System NAM programming mode: 0 + 1 + # + 7 + 3 + 7 + SECURITY CODE (000000) Debug menu: 0 + 1 + # + 3 + 2 + 4 + SECURITY CODE (000000) Debug screen of field test mode: 0 + 1 + # + 7 + 2 + 7 Test mode: 0 + 1 + # + 7 + 6 + 4 + SECURITY CODE (000000) System test mode: 0 + 1 + # + 7 + 6 + 8 + SECURITY CODE (000000) NEOPOINT: Neopoint 1000 1. Press M to display Main Menu 2. Scroll to PREFERENCES 3. Press softkey under SELECT 4. Enter 040793 5. Scroll to PROGRAMMING 6. Press softkey under SELECT 7. Enter OTKSL 8. Press softkey under DONE 9. Scroll to PHONE NUMBER 10. Enter 10 digit MIN 11. Scroll to HOME SID 12. Enter SID (4654) 13. Press softkey under SAVE to exit 14. Programming is complete NEOPOINT 1600 1. Power the phone on 2. Press the "Menu" key 3. Scroll to "Preferences" - press "Select" 4. Key in the "Field Service Code" (the phone will not prompt you for the code) at the "preferences" screen to access the "Service" menu (Default code is "000000") 5. Scroll to "Programming" - press "Select" - the phone will ask for the "Subsidy Lock Code" 6. Enter the "Subsidy Lock Code(654321)" to access the "NAM" menu 7. Select the NAM to be programmed (NAM 1 or NAM 2) 8. Program the NAM - Phone number and CDMA Home SID 9. After programming has been completed press "Save" - the phone will reset Audiovox: Audiovox 9100 1. Press ## 2. Enter the OTKSL 3. Display will read Service/Menu 1 Basic…press OK 4. Next screen will read Service Mode/Home SID…press OK 5. Next screen will read Service Mode/Home SID…press OK 6. Device will display Service Menu 1. Basic # 7. Press END button to complete programming Handspring TREO: 1. Open the flip and press the PHONEBOOK button one time to display the dial pad 2. Enter ## and the OTKSL using the numbers on the Dial Pad 3. Press the handset button shown in the diagram above 4. At the Activations screen enter the MIN in the phone number field using the numbers on the device keyboard 5. Put a check in the Enable Number Portability box and type the MSID in the MSIN field 6. Press OK 7. The device will display the network search pop-up and return to the Phonebook display Hitachi P300: 1. Enter ## and the 6 digit OTKSL 2. Press the Options soft key and then scroll to Save Phone #. Press the OK soft key. 3. At the NAM display scroll to EDIT and press the OK soft key 4. Display will read NAM and MDN will be highlighted. Press the OK soft key. 5. At the MDN display enter the 10 digit MIN and press the SAVE soft key. 6. At the Save prompt press the OK soft key. The next display will show several options that should not edited. 7. Press the EXIT soft key and the device will power cycle. 8. Programming is complete. Kyosera: Kyocera 2345 1135 1. Press 111111 (#1 key 6 times) 2. Option will be highlighted 3. Press OK 4. Scroll down to Programming 5. The service programming dialog will appear Enter Security Code. 6. Enter the 6 digit OTSKL (code will show as asterisks on screen) 7. Service Options will appear 8. Scroll down to the BASIC NAM1 Info 9. Press OK 10. Select the Phone Number by pressing the OK key 11. Using the keypad enter the 10 digit MIN 12. Press OK 13. Press END to complete the programming Kyocera 6035 1. Press 1 six times (111111) and select OPTIONS 2. Select PROGRAMMING 3. Open flip 4. Tap the OTKSL on keypad on the screen. Tap OK 5. Tap on the PHONE NUMBER field. Enter MIN. 6. Leave A-KEY blank 7. Enter HOME SID (4654) 8. Tap SAVE & EXIT 9. Tap YES 10. Phone will be in OFF MODE Close flip. Kyocera 3035 1. Press 111111 (the #1 key six times) 2. Options will be highlighted 3. Press in the navigation key (Navigation key is the button located between the TALK & END key) 4. Scroll to PROGRAMMING using the Navigation key 5. Select PROGRAMMING by pressing in the Navigation key 6. Enter the six digit OTKSL and press in the navigation key 7. SERVICE OPTIONS will appear 8. Scroll down to the Basic NAM1 info 9. Press in the navigation key 10. Clear any numbers that may appear using the “clear” key (arrow key located directly below the navigation key) 11. Select the PHONE NUMBER by pressing in the navigation key 12. Enter the 10 digit MIN select OK by pressing in the navigation key 13. Press END. Programming is complete. Kyocera 2255 1. Press the 1 key six times (111111) “Option will be highlighted 2. Press OK 3. Scroll down to “Programming” and press “OK” 4. Enter OTKSL and press the navigation key 5. “Service Options” will appear scroll down to the “Basic NAM1 Info” 6. Press OK 7. Select Phone Number by pressing OK 8. Enter MIN and press OK again 9. Scroll to Home SID and press OK 10. Enter SID (4654) and press OK 11. Press END. Programming is complete. QCP 2035 1. Press 1 six times (111111) 2. Press u key to select OPTIONS 3. Highlight PROGRAMMING and press u key 4. Enter OTKSL 5. ESN will appear press left arrow key to select OK 6. Enter MIN and press ç key 7. Press ç key again to exit - Programming is complete Sanyo: Sanyo 4000 4500 4700 5000 6000 1. Press ## 2. Enter the OTKSL 3. Scroll to SAVE and press OK 4. ESN will be displayed – press OK 5. Enter 10 digit MIN and press OK 6. Enter SID (4654) and press OK 7. Press OK twice 8. Programming is complete Sanyo 5150 5300 and 6400 1. Enter ## followed by the OTKSL 2. Press MENU SAVE PHONE # 3. Press Ok 4. SVC Programming will be displayed. Scroll and highlight Mobile Number. Press OK 5. Press OK again 6. ESN will be displayed. Press OK 7. Mobile Number will be displayed enter the 10 digit MIN press OK 8. Press OK 4 times 9. Phone will power cycle 10. Programming is complete Sanyo 6000 1. Press ## 2. Enter OTKSL 3. Press MENU Key and scroll to SAVE PHONE # and press OK 4. ESN will be displayed press OK 5. Enter MIN and press OK 6. Enter SID and press OK 7. Press OK twice more 8. Programming is complete Sanyo 4900 1. Enter ## followed by the 6 digit OTKSL 2. Press the MENU/OK key and scroll and highlight SAVE PHONE # 3. Press MENU/OK 4. Scroll and highlight MOBILE NUMBER press OK 5. At the ESN display press OK 6. In the MOBILE NUMBER screen enter your MIN and press OK 4 times 7. At the service program menu scroll to exit and press the MENU/OK key. 8. Programming is complete Sanyo 6200 1. Enter ## 2. Enter OTKSL 3. Press the MENU key and scroll to highlight SAVE PHONE # 4. Press OK 5. Scroll and highlight MOBILE NUMBER 6. Press OK twice 7. Scroll and highlight EXIT 8. Press OK 9. Phone will power cycle 10. Programming is complete Toshiba: Toshiba 2032P 1. Slide the Radio Standby Switch on the left side of the device to the upper side (ON) to activate the phone function. This is the switch with the phone icon over it 2. After power up is completed use the stylus to tap on the ADMIN pull up menu at the bottom of the screen and select ACTIVATION WIZARD. If your device has not yet been activated the ACTIVATION WIZARD will automatically start when you turn on the radio in your device. 3. Tap NEXT 3 times. If the device has been previously activated it will require only 2 presses. 4. On the fourth screen enter the 6 digit OTKSL using keyboard 5. Enter the MIN in both entery fields then tap NEXT 6. Wait for the device to initialize and display “ready to connect” 7. To initiate IOTA tap the word ADMIN at the bottom of the display and then Data Provisioning 8. Programming is complete ******* Here is a list of various codes to try out. Some may require an MSL to be able to make full use of the functionality. ##2769737 [##BROWSER] - MiniBrowser Settings (2G) ##8626337 [##VOCODER] - Set Vocoder ##3282 [##DATA] - Setup Menu for Vision handsets ##8463 [##TIME] - Airtime Menu ##040793 - Debug Menu ##786 [##RUN] - Technical Information (be careful with this one, you can reset the handset) ##932 [##WEB] - IP Address information (2G) ##889 [##TTY] - TTY On or TTY Off ##4357 [##HELP] - Help |
The Following User Says Thank You to jvd_cool For This Useful Post: |
03-28-2007, 20:01 | #7 (permalink) |
Product Supporter Join Date: May 2004 Location: INDIA Age: 55
Member: 65063 Status: Offline Thanks Meter: 2,419 | @jvd_cool i m really disappointed i thought this time some new codes are here, which are not posted earlier ! pl dont waste time and space thank you wbr |
04-11-2007, 00:18 | #8 (permalink) | |
Junior Member Join Date: May 2006
Member: 281706 Status: Offline Thanks Meter: 1 | Quote:
04-11-2007, 04:25 | #9 (permalink) | |
Junior Member Join Date: Nov 2005 Location: 78_RUS
Member: 196377 Status: Offline Sonork: BB PIN 313E7Cxx Thanks Meter: 10 | Quote:
really trash | |
05-10-2007, 18:16 | #11 (permalink) | |
Freak Poster Join Date: May 2004 Location: Ukraine-Lugansk Age: 44
Member: 67246 Status: Offline Thanks Meter: 70 | Quote:
8 mByte OLD soft ) I live in 2007 year and this soft for 1996-97 years ))) | |
05-10-2007, 18:20 | #12 (permalink) | |
Member: 465750 Status: Offline Thanks Meter: 44 | Quote:
Model: Nokia (3120 ) IMEI: 356245002417450 Network: 30272000 #pw+07 82 23 60 26 64 52 3+1# #pw+77 38 30 70 31 40 23 1+2# #pw+93 25 42 26 30 77 14 5+3# #pw+44 41 67 37 32 33 46 6+4# #pw+91 21 52 34 40 73 65 0+5# #pw+72 43 30 35 62 05 63 6+6# #pw+20 84 35 33 46 76 43 1+7# if code not working plz give me your network name | |
05-10-2007, 20:42 | #13 (permalink) | |
Choose the right section for your posting! http://forum.gsmhosting.com/vbb/misc.php?do=cfrules WBR M.J.Akhtar | |
05-10-2007, 20:47 | #14 (permalink) |
Member: 465750 Status: Offline Thanks Meter: 44 | Sorry freinds link was changed by website owner new solutions download from here now. http://www.gsmegypt.com/support/mouazen/ Or http://www.gsmegypt.com/support/ WBR M.J.Akhtar |
09-04-2007, 11:10 | #15 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | need to unlock a 120c motorola, is it the same that v120C? because I have something o unlock v120t on my arsenal, is there a way to convert a CDMA phone to TDMA maybe this is a stupid question bit... |
All Mobile Unlocker Specially Nokia Download Free | tehseen ahmed | Nokia Multimedia | 43 | 06-20-2009 14:21 |
All Mobile Unlocker | aapkae | Nokia Multimedia | 3 | 03-20-2009 15:01 |
What is best company to deal with for all mobile unlocking/spares etc | Astro_Warp | The Market Feed Back | 23 | 08-26-2005 05:13 |
All mobiles unlockers here free>>>>>>>>>>>> | faisi | UFS2 + UFS3-Tornadoflasher | 2 | 08-25-2005 05:51 |
Needed All Mobiles Unlock Codes | sachin60545 | Nokia Multimedia | 1 | 07-31-2005 14:49 |
