Various CDMA/TDMA Cell Phones All CDMA & TDMA Cell Phones Related Threads are here |
11-21-2003, 07:44 | #2 (permalink) |
Junior Member Join Date: Oct 2003 Location: Pakistan Age: 45
Member: 42124 Status: Offline Thanks Meter: 0 | BGA stands for Ball Grid Array, it simply means that the solder connection points joining the memory chips to the module board are spaced over a grid rather than is a straight line (like the traditional memory chips). This BGA assembly technique is used on select high-speed PC100 / PC133 & PC2100 modules. This design feature reduces the cross talk of signal information and allows for better routing of the traces. The net result is a memory that is more stable, runs cooler and works better with high speed CPUs. The problem with building BGA memory is that the modules need to be assembled with x-ray guided assembly machines because the solder contact points are underneath the DRAM chip. These newer x-ray guided placement machines eventually will be the norm however today they are very expensive and few memory module companies are willing or able to scrap their existing machines. |
Bga kit rebbal for new bga ..... | sergioems | Hardware Equipments for GSM | 12 | 11-18-2004 11:22 |
BGA solder balls/BGA reballing kits | Eisdieler | Wanted Products | 0 | 09-23-2003 09:26 |
SALE LCDS HOT AIR PENCILS BGA TOOL KITS | coolgsm2000 | Hardware Repair Item Wanted | 28 | 07-08-2003 19:47 |
BGA tool needed. | emix | Main Sales Section | 2 | 02-05-2002 18:19 |
BGA TOOLKITS | nokya | Hardware Equipments for GSM | 4 | 09-11-2001 06:45 |
