computer1 | 05-04-2009 07:47 | Recovery Mode
When it is failed to upgrade the mobile phone program with Haier Maintain Tool , then lead to the mobile phone can’t boot-strap. We can try to use the Recovery mode of Haier Maintain Tool to upgrade the mobile phone program over again.
1) Run Haier Maintain Tool , select the right Image file and right serial port.
2) Click Start Button, then Haier Maintain Tool will try to connect to the mobile (SayHello).
If failed, Haier Maintain Tool will enter the Recovery mode, at the same time, the message of “please power on” will show at the status bar. Now, Both press the “*” key and the power key on mobile phone to power up it. If the cable you use has the function of electrification, you need to press ”*” key when the message “please power on ” is show, then insert the cable in the connected socket.
4)If the message “erasing” show at the status bar, it says the mobile phone has connected with DloaderLite, and it is upgrading now. |
