Various CDMA/TDMA Cell Phones All CDMA & TDMA Cell Phones Related Threads are here |
03-07-2008, 06:21 | #46 (permalink) |
No Life Poster Join Date: Apr 2005
Member: 137582 Status: Offline Thanks Meter: 93 | About samsung, whenever I can't read SPC I try a full EEPROM reset at the ENG menu ON THE PHONE (I've never done it from software) and SPC is reset to zeroes. On Sanyo 8300 I could read SPC but I don't remember if I was using either EFS or RAM method. |
03-07-2008, 17:37 | #47 (permalink) | |
Insane Poster Join Date: Aug 2003 Location: usa
Member: 38014 Status: Offline Thanks Meter: 1 | Quote:
the box, i tried with jaf cables, ust cables, and no luck... has to be box I e-mailed support with the email on my acct with you... thanks... I bet im the only one who has box issues... heheh no pun intended.. xpgx | |
03-13-2008, 01:48 | #51 (permalink) |
Junior Member Join Date: Apr 2007
Member: 486756 Status: Offline Thanks Meter: 3 | LG MX240 Connections Dear Sir Pluton: i tryng Connect by USB one LG MX240, you say That Working Connections USB. where are the USB Drivers? Nedd Test connecting and Change ESN . |
03-18-2008, 19:36 | #52 (permalink) |
Member: 486756 Status: Offline Thanks Meter: 3 | LG MX240 Change ESN Failed!! Dear Friends, can't Change ESN in one LG MX240. Already connecting via USB, bout not Change ESN. Why? anybody can Support to me for Chenge ESN ?, i'm using CDMA WORKSHOP 3.1.0. |
03-22-2008, 17:36 | #53 (permalink) |
Member: 137582 Status: Offline Thanks Meter: 93 | Tested Treo 700p supported To connect via serial enable passtrhough using ##3424 + send for sprint units, for verizon units use #*#3424# For USB connections use ##8778 + send for sprint and for verizon #*#8778# If you're using USB connection remember to disble USB connection on active sync first. Is anyone able to share treo 700 hpst? I have Crowdy's 0.17 but it won't connect to treo 700, loops itself and never gets to connect. Thank you. |
03-25-2008, 17:43 | #54 (permalink) |
Member: 137582 Status: Offline Thanks Meter: 93 | Tested LG LX125, not able to connect, looks like serial port is disabled from service menu on phone, and there's no way to read the SPC to activate port on phone. Anybody know a way around this? |
04-12-2008, 15:55 | #55 (permalink) |
Member: 137582 Status: Offline Thanks Meter: 93 | Tested Audiovox PPC 6700, mogul. SPC, PRL, NAM, ESN read/write succesful. Model suported. Need to put it in diag mode first using either of this codes: ##3424+send, #*#3424+send |
04-12-2008, 16:02 | #56 (permalink) |
Member: 137582 Status: Offline Thanks Meter: 93 | Tested Vyrgin Kyocera cyclops, phone does connect and is readable, but requires SPC for everything, even for EFS reading so SPC is impossible to get. A good update for the software developers to consider is a way around this. |
04-21-2008, 20:59 | #60 (permalink) | |
No Life Poster Join Date: Jan 2003 Location: CDMA-WARE
Member: 20073 Status: Offline Thanks Meter: 250 | Quote:
+ As a result of feature above, will be ability to enable/disable current license key and move software to any PC user want. | |
need support models list | .:Kuku:. | Multi-Box | 2 | 12-22-2006 07:03 |
Full supported models list | snsoftkiller | UST Pro II | 0 | 09-25-2006 05:02 |
No A1000, no c550, correct supported models list | radiodepilhas | Motorola P2K (USB-Smart) | 2 | 05-19-2006 12:26 |
Current All Supported Models List? | mfreaks | Twisterflasher | 0 | 01-03-2005 23:24 |
