Go Back   GSM-Forum > CDMA & TDMA Phones / Tablets Area > Various CDMA/TDMA Cell Phones
Various CDMA/TDMA Cell Phones All CDMA & TDMA Cell Phones Related Threads are here
Old 09-16-2009, 06:35   #1 (permalink)
Member: 472592
haier c 2000 usb device not recognised
haier c2000 shows usb device not recognised as i attache to computer,
can any body gives me pinout for this model
Old 09-16-2009, 08:22   #2 (permalink)
shashankmobile's Avatar
Member: 800668
Sonork: 100.1590720
are you using cable in front of cpu........
Br.
Shashank
Old 09-16-2009, 10:17   #3 (permalink)
jamaletw's Avatar
Member: 599228
using cable back said.....
Old 09-16-2009, 11:04   #4 (permalink)
Hariom123's Avatar
Member: 804452
cheak usb cable & ur charging jeak clean ya change ur problam 100% solve tested me
Hariom
Old 09-17-2009, 06:35   #5 (permalink)
Member: 472592
i have replace the jack and also used back USb But Problem is still the same
pls do something or tell me pinouts for this model???????
Old 09-17-2009, 07:06   #6 (permalink)
sneha's Avatar
Member: 327043
Sonork: 1587811
use small cable for good resultes......long cables fase some problems
Old 09-18-2009, 09:15   #7 (permalink)
Member: 472592
i have tried with 20 of cables,short and long and medium also, but problem remains same.
"pls do something 4 for me"
thanx in advance.
Old 09-18-2009, 10:39   #8 (permalink)
Member: 397862
brother no solution for this problem.dont waste time.i face this problem some time
Old 09-18-2009, 11:42   #9 (permalink)
Hariom123's Avatar
Member: 804452
use card reader ya original v3i cable ok
Hariom
Old 09-19-2009, 05:36   #10 (permalink)
Member: 472592
Hariom
Dear Hari om i had used card reader and also v3 cable in earlier time but not solved
Old 09-19-2009, 05:53   #11 (permalink)
~AKSingh~'s Avatar
Member: 65063
Sonork: 100.1603561
widely available cheap handsets are most proned to dry solderings
so if u have checked everything now its turn to reflow cpu or flash
surely set will be detected on usb
br,
Old 09-19-2009, 07:00   #12 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
yes mr ak singh is right this is hardwer problem
Old 09-19-2009, 08:06   #13 (permalink)
Member: 236743
yes 100% cpu problem just re flow cpu carefully
Old 09-22-2009, 06:36   #14 (permalink)
Member: 472592
tanx to all ,my problem has been solved now by heating cpu
The Following User Says Thank You to farsi_007 For This Useful Post:
[IMG] code is Off
W580 need to be flashed bt sats usb device not recognised dapinderjit Sony Ericsson Hardware Repair Area 2 12-31-2009 17:46
D900 USB Device Not recognised drancill NSPRO 1 02-06-2009 02:38
ubl device not recognise GHOSTMAN10 Ultima Box Light 5 05-26-2007 14:36
My Vygis Box USB Device Not Recognised Sixth`SenSe VygisToolbox 2 06-09-2006 12:01
USB Device not recognised chipxtreme UFS2 + UFS3-Tornadoflasher 1 11-10-2005 14:10
Page generated in 0.35667 seconds with 11 queries
