Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Various CDMA/TDMA Cell Phones
Various CDMA/TDMA Cell Phones All CDMA & TDMA Cell Phones Related Threads are here
Old 06-28-2013, 18:38   #1 (permalink)
Member: 1601594
Thanks Meter: 13
Cool how to hard reset Pantech TXT8035PP ????
hi guys I came a verizon pantech TXT8035PP model with password, i was looking for and not encuenta as do a hard reset if anyone can help me I would greatly appreciate.
greetings and thanks
Old 06-28-2013, 19:58   #2 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,788
Instructions
Turn your Pantech phone on
Press "Menu" and then "Settings."
Scroll down and press "Reset.
Enter the default password "1234" when prompted for a password.
Then select "Master Reset" to reset your phone to factory settings.
Old 06-28-2013, 20:00   #3 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,788
Alternate Method
Ensure the device is powered down.
Note If needed, remove and replace the battery.
Press and hold the volume down and search keys then press the power key.
Note When the Android triage screen (triangle with a yellow exclamation sign) appears, release the keys.
Press the menu key.
Using the volume down key, scroll to wipe data/factory reset then press the Home key to select it.
Using the volume down key, scroll to Yes -- delete all user data then press the Home key to select it.
Note This boot process takes several moments, reference the progress bar located in the upper-right. If the device hangs or freezes, remove/replace the battery, refer to Inserting/removing the battery for additional assistance.
If presented,
Select reboot system now.
Press the Home key to return to the Android OS.
[IMG] code is Off
Page generated in 0.16005 seconds with 8 queries
