Various CDMA/TDMA Cell Phones All CDMA & TDMA Cell Phones Related Threads are here |
08-05-2006, 07:08 | #1 (permalink) |
Insane Poster Join Date: Jun 2006
Member: 295692 Status: Offline Thanks Meter: 0 | Samsung A130 CDMA - Code for Test menu To enter test menu press 47*68*13580 Press 0 3 2 to display current handset MIN - you will need this later on when doing the NAM1 reprogram, press 1 to display the entire MIN - write down the first 10 digits as that is the handsets IMSI number. To bypass the handsets SERVICE PROGRAM CODE you can change the carrier ID. To enter the carrier ID code in the TEST MENU press # 1 2 6 Do not change carrier ID code unless you have got the current handset MIN and also know the network settings for your CDMA provider: Example: Telstra CDMA SID: 8320 NID: 65535 MCC: 505 MNC: 11 MIN: 1616 XXX XXX LOCKOUT SID: 7801 LOCKOUT SID: 7761 PRL: NO Unless you know the network settings don't change the carrier ID or have the the actual SPC for the handset. Carrier ID codes for the Samsung A130: Carrier ID 10: StarCom PCS (do not use as the SPC need a cable to be reset) Carrier ID 26: Telstra - Service Program Code: 000000 - basic NAM1 reprogram availiable Carrier ID 28: Telstra - Service Program Code: 000000 - basic NAM1 reprogram availiable Carrier ID 29: Telstra - Service Program Code: 000000 - basic NAM1 reprogram availiable Carrier ID: 30 Telstra - Service Program Code: 000000 - basic NAM1 reprogram availiable Carrier ID: 32 Telstra - Service Program Code: 000000 - basic NAM1 reprogram availiable Carrier ID: 33 IUSACELL - Service program Code: 000000 - basic NAM1 reprogram availiable Carrier ID: 34 Telstra - Service Program Code: 000000 - basic NAM1 reprogram availiable Carrier ID: 35 Telstra - Service Program Code: 000000 - basic NAM1 reprogram availiable Carrier ID: 36 Telstra - Service Program Code: 000000 - basic NAM1 reprogram availiable Carrier ID: 37 TELCEL - 3 digit lock code: 6 2 6 - basic NAM1 reprogram availiable SERVICE PROGRAM CODE is unknown Carrier ID: 38 MOVILNET - 3 digit lock code: 6 2 6 - basic NAM1 reprogram availiable SERVICE PROGRAM CODE is unknown Carrier ID: 40 Telstra - Service Program Code: 000000 - basic NAM1 reprogram availiable Carrier ID: 44 BELLSOUTH - SERVICE PROGRAM CODE is unknown Carrier ID: 45 MOVICOM - SERVICE PROGRAM CODE is unkown Carrier ID: 46 BELLSOUTH - SERVICE PROGRAM CODE is unknown Carrier ID: 47 Telstra - Service Program Code: 000000 - basic NAM1 reprogram availiable Carrier ID: 54 Telstra Telstra - Service Program Code: 000000 - basic NAM1 reprogram availiable Carrier ID: 64 RELIANCE - SERVICE PROGRAM CODE is unknown Carrier ID: 65 RELIANCE - SERVICE PROGRAM CODE is unknown Carrier ID: 66 RELIANCE - SERVICE PROGRAM CODE is unknown Carrier ID: 74 CTI MOBILE - SERVICE PROGRAM CODE is unknown Carrier ID: 86 RELIANCE - SERVICE PROGRAM CODE is unknown Any other 2 digit carrier ID should only be used if you can find the SPC for the handset ... in other words don't bother using them. The Telstra carrier ID codes (as displayed above) excluding carrier ID 54 the the SPC is 000000. To change the carrier ID: enter the 2 digit carrier ID code then press OK key wait 30 seconds then press # 002 to exit the TEST MENU the handset will auto reboot and display what ever carrier ID you selected: i.e.: TELCEL To enter the Service Menu, enter on the keypad: Menu 5 * Then press 1 and enter the 3 digit lock code or the 6 digit SPC. The display will show NAM1: MIN 0000000000 (or 3030303030) Enter the 10 digit MIN you wrote down, press OK It will then display NAM1 / MDN (Mobile Directory Number - your mobile telephone number should be entered) Press OK HOME SID: Enter your Home SID (i.e.: if Telstra then enter 8320) NAM1 NAME: Enter your Service Providers name then press OK Your handset will then display basic NAM programing complete. Press OK the handset will reboot and then register with your service provider. |
09-28-2007, 14:02 | #3 (permalink) |
Junior Member Join Date: Sep 2007
Member: 597684 Status: Offline Thanks Meter: 0 | Hi Having difficulties getting my phone into test menu Have entered the code 47*.... but doesn't seem to work do u have to enter anything before or does the phone have to be in a certain menu Please help!!!! Thank you in advance |
09-28-2007, 14:16 | #4 (permalink) |
Free Alcatel & Huawei Unlock Codes for testing to follow with BB and other codes soon | Fast Unlocking | Phone Unlocking Codes & Maps | 57 | 03-08-2010 11:55 |
8180 code for service menu ? | L&R | VygisToolbox | 1 | 10-20-2005 05:55 |
Need several logs for Z5 and them`s unlock codes for test! | Bogi | Sony | 0 | 09-25-2001 19:41 |
