Various CDMA/TDMA Cell Phones All CDMA & TDMA Cell Phones Related Threads are here |
09-09-2005, 20:42 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Cuttack,India Age: 54
Member: 71721 Status: Offline Sonork: 100.106320 Thanks Meter: 139 | N191 Power Dead(only Blinking Light............. After Rehot On Pcb Some Set Alive........but After Few Days Again Same 10% Sucsess After Changing Charging Connector,rehot Etc. Etc.......... Any Body Have The Solutin.plz.........plz |
09-30-2005, 07:41 | #5 (permalink) |
No Life Poster Join Date: Dec 2002 Location: cell-spare cochin penta kerala
Member: 18837 Status: Offline Sonork: 100.1601544 Thanks Meter: 71 | thease all not perfect solution for this fault........ is there any other idea or any one knows about this fault please post in this forum. and i know its a common fault in this model |
09-30-2005, 09:13 | #6 (permalink) | |
No Life Poster Join Date: Oct 2004 Location: india
Member: 84807 Status: Offline Thanks Meter: 67 | Quote:
10-04-2005, 20:34 | #9 (permalink) |
Member: 71721 Status: Offline Sonork: 100.106320 Thanks Meter: 139 | everything done but i think heat method is work in all above cashes and for few days ,but hit why..........??????????????? any body tell me which parts perticularly needs heat thanks |
10-07-2005, 04:56 | #10 (permalink) |
Freak Poster Join Date: Apr 2003 Location: MUMBAI,INDIA Age: 63
Member: 27707 Status: Offline Thanks Meter: 6 | just remove the the keypad sticker .. and rehot the pcb just below cpu.. there is no fault with eeprom or crystal .. 100% works .. try it out and then confirm... i must hav repaired more than 40 sets like that .and it does not give problem .. keep the pcb connected to charger.. if it gives display and does not restart for more than one hour.. it works... |
10-13-2005, 20:47 | #13 (permalink) |
Member: 27707 Status: Offline Thanks Meter: 6 | sunil , there is no problem or crack under the ic.. since cpu and other main chips( bga) are glued to the pcb.. reballing is not possible.. so only option is to rehot cpu and pcb below cpu .. thatz the only way i cud repair most of the n191 boards.. there is no other problem but the contacts of the cpu chip. thanx Sunil |
03-04-2006, 20:36 | #14 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | but why heating is the only option with all of us , as the problem occurs while charging , so how can it be any cracks under FLASH IC or the CPU ? when any set is taken to the service center they tell it is the CPU problem and cannot be repaired , so PCB needs to be changed.., and that is not an affordable solution ...// so is there any perfect solution of this problem ? |
03-04-2006, 21:38 | #15 (permalink) | |
Member: 71721 Status: Offline Sonork: 100.106320 Thanks Meter: 139 | Quote:
i am saying u a practical thing i repaired 30 sets in a month which i follow as per opinion given by other members which 5 of them i repaired with reballing cpu i get 25 set complane but this 5 set till now running(scence 3 month)no complane so i think that there is a crack under cpu or may the solder paste use for that ic is poor quality that is my opinion only | |
how to i900 omnia Only red (led) power on button lighting and dont power on repair | turkcellgsm | Z3X-Team Products | 4 | 10-16-2009 14:44 |
how to i900 omnia Only red (led) power on button lighting and dont power on repair | turkcellgsm | Samsung Flashers, Software, Firmware. | 0 | 10-03-2009 06:33 |
c139 dead(only keypad light on) | bestcells | Smart-Clip | 9 | 02-08-2008 15:06 |
k700i when power on red light blink | syed.n | Sony Ericsson Hardware Repair | 2 | 05-11-2007 20:31 |
w550i when power on red light blinks | shoeb7 | Cruiser Suite | 10 | 01-19-2007 12:17 |
