Various CDMA/TDMA Cell Phones All CDMA & TDMA Cell Phones Related Threads are here |
12-15-2014, 13:53 | #1 (permalink) |
Product Supporter Join Date: Mar 2008 Location: India
Member: 718725 Status: Offline Sonork: 100.1604953 QQ 2339690693 Thanks Meter: 6,701 | Haier CG220 (GSM+CDMA) Flasher/Driver/All SW Version In One Palace Haier CG220 (GSM+CDMA) All SW Version/Flasher/Driver Download Here Firmware:.. Version 1 : HC-CG220_HW2_R-P2.02.11_S002B_Lock_130108.rar Version 2 : CG220_Software_HC-CG220_S-050_3 Dec_2012.rar Version 3 : CG220_SP_Q1105-CG220_HW3_R-P2.02.12_S005_OMH_RELIANCE_130108_Lock.rar Version 4 : CG220_SP_Q1105-CG220_R-P2.02.62_S050_OMH_RELIANCE_130122_Lock (22 Jan 2013).rar Flasher:.. CG220_Sofware_Download_Tool_3_Dec_2012.rar Driver:.. CG220_Windows_Driver_3_Dec_2012.rar Flash Guide:.. Haier_CG_220_Software_Download_Guide_Ver_1 0_03_December_2012.doc B.R., Prem_India |
The Following User Says Thank You to Prem_India For This Useful Post: |
08-06-2015, 20:57 | #2 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friend, Cellphone Version. --------------------------------------------------------- HARDWARE : CG220S00 COMPILE : Jan 08 2013 (18:32:23) REALEASE : Oct 18 2011 (00:00:00) SW Version : HC CG220_HW3_R S005 _ --------------------------------------------------------- I Flashed With This Version Firmware : CG220_SP_Q1105-CG220_HW3_R-P2.02.12_S005_OMH_RELIANCE_130108_Lock Now When I Power On It's Show "Reliance" Then While LCD. When I Switch Off It 's Show Again "Reliance" & Power Off. If It's NV File Problem So I Need It. |
08-14-2015, 16:58 | #5 (permalink) | |
No Life Poster Join Date: Oct 2009 Location: India [UNKNOWN]
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | Quote:
HI i got the nv but i m not sure this nv is correct model 0xa10000259e4237-2015-01-07-13-11-59 just write with same tool select nv in option and write give result if success or not | |
The Following User Says Thank You to MOHIT_THAREJA For This Useful Post: |
08-14-2015, 18:01 | #6 (permalink) | |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Quote:
Yes, It's Working, Now LCD/Display Perfect. Here Is Log. Code: Prepare... Open Port... SPC Unlock ESN: 0x0 Write Item: 10 sub0 OK! Write Item: 10 sub1 OK! Write Item: 20 sub0 OK! Write Item: 21 sub0 OK! Write Item: 24 sub0 OK! Write Item: 39 sub0 OK! Write Item: 40 sub0 OK! Write Item: 42 sub0 OK! Write Item: 62 sub0 OK! Write Item: 64 sub0 OK! Write Item: 65 sub0 OK! Write Item: 69 sub0 OK! Write Item: 74 sub0 OK! Write Item: 82 sub0 OK! Write Item: 85 sub0 Fail!,istatus=0 Write Item: 90 sub0 OK! Write Item: 148 sub0 OK! Write Item: 161 sub0 OK! Write Item: 176 sub0 OK! Write Item: 179 sub0 OK! Write Item: 240 sub0 OK! Write Item: 241 sub0 OK! Write Item: 255 sub0 OK! Write Item: 256 sub0 OK! Write Item: 291 sub0 OK! Write Item: 297 sub0 OK! Write Item: 298 sub0 OK! Write Item: 301 sub0 OK! Write Item: 409 sub0 OK! Write Item: 415 sub0 OK! Write Item: 429 sub0 OK! Write Item: 441 sub0 OK! Write Item: 441 sub1 OK! Write Item: 442 sub0 OK! Write Item: 447 sub0 OK! Write Item: 450 sub0 OK! Write Item: 451 sub0 OK! Write Item: 453 sub0 OK! Write Item: 454 sub0 OK! Write Item: 455 sub0 OK! Write Item: 543 sub0 OK! Write Item: 550 sub0 OK! Write Item: 550 sub1 OK! Write Item: 559 sub0 OK! Write Item: 562 sub0 OK! Write Item: 570 sub0 OK! Write Item: 572 sub0 OK! Write Item: 724 sub0 OK! Write Item: 725 sub0 OK! Write Item: 726 sub0 OK! Write Item: 727 sub0 OK! Write Item: 728 sub0 OK! Write Item: 729 sub0 OK! Write Item: 730 sub0 OK! Write Item: 731 sub0 OK! Write Item: 732 sub0 OK! Write Item: 733 sub0 OK! Write Item: 806 sub0 OK! Write Item: 807 sub0 OK! Write Item: 808 sub0 OK! Write Item: 809 sub0 OK! Write Item: 810 sub0 OK! Write Item: 811 sub0 OK! Write Item: 812 sub0 OK! Write Item: 818 sub0 OK! Write Item: 819 sub0 OK! Write Item: 820 sub0 OK! Write Item: 821 sub0 OK! Write Item: 822 sub0 OK! Write Item: 830 sub0 OK! Write Item: 847 sub0 OK! Write Item: 848 sub0 OK! Write Item: 849 sub0 OK! Write Item: 850 sub0 OK! Write Item: 850 sub1 OK! Write Item: 855 sub0 OK! Write Item: 882 sub0 OK! Write Item: 909 sub0 OK! Write Item: 916 sub0 OK! Write Item: 917 sub0 OK! Write Item: 928 sub0 OK! Write Item: 929 sub0 OK! Write Item: 930 sub0 OK! Write Item: 941 sub0 OK! Write Item: 943 sub0 OK! Write Item: 944 sub0 OK! Write Item: 945 sub0 OK! Write Item: 946 sub0 OK! Write Item: 947 sub0 OK! Write Item: 1057 sub0 OK! Write Item: 1058 sub0 OK! Write Item: 1059 sub0 OK! Write Item: 1060 sub0 OK! Write Item: 1061 sub0 OK! Write Item: 1096 sub0 OK! Write Item: 1097 sub0 OK! Write Item: 1098 sub0 OK! Write Item: 1099 sub0 OK! Write Item: 1100 sub0 OK! Write Item: 1101 sub0 OK! Write Item: 1102 sub0 OK! Write Item: 1103 sub0 OK! Write Item: 1104 sub0 OK! Write Item: 1105 sub0 OK! Write Item: 1138 sub0 OK! Write Item: 1139 sub0 OK! Write Item: 1140 sub0 OK! Write Item: 1141 sub0 OK! Write Item: 1142 sub0 OK! Write Item: 1191 sub0 OK! Write Item: 1206 sub0 OK! Write Item: 1273 sub0 OK! Write Item: 1274 sub0 OK! Write Item: 1275 sub0 OK! Write Item: 1287 sub0 OK! Write Item: 1288 sub0 OK! Write Item: 1289 sub0 OK! Write Item: 1302 sub0 OK! Write Item: 1312 sub0 OK! Write Item: 1313 sub0 OK! Write Item: 1314 sub0 OK! Write Item: 1326 sub0 OK! Write Item: 1327 sub0 OK! Write Item: 1328 sub0 OK! Write Item: 1341 sub0 OK! Write Item: 1344 sub0 OK! Write Item: 1626 sub0 OK! Write Item: 1635 sub0 OK! Write Item: 1636 sub0 OK! Write Item: 1637 sub0 OK! Write Item: 1638 sub0 OK! Write Item: 1639 sub0 OK! Write Item: 1640 sub0 OK! Write Item: 1641 sub0 OK! Write Item: 1645 sub0 OK! Write Item: 1647 sub0 OK! Write Item: 1648 sub0 OK! Write Item: 1649 sub0 OK! Write Item: 1650 sub0 OK! Write Item: 1651 sub0 OK! Write Item: 1652 sub0 OK! Write Item: 1654 sub0 OK! Write Item: 1655 sub0 OK! Write Item: 1666 sub0 OK! Write Item: 1668 sub0 OK! Write Item: 1669 sub0 OK! Write Item: 1670 sub0 OK! Write Item: 1671 sub0 OK! Write Item: 1673 sub0 OK! Write Item: 1674 sub0 OK! Write Item: 1675 sub0 OK! Write Item: 1676 sub0 OK! Write Item: 1677 sub0 OK! Write Item: 1678 sub0 OK! Write Item: 1681 sub0 OK! Write Item: 1682 sub0 OK! Write Item: 1683 sub0 OK! Write Item: 1715 sub0 OK! Write Item: 1724 sub0 OK! Write Item: 1725 sub0 OK! Write Item: 1726 sub0 OK! Write Item: 1727 sub0 OK! Write Item: 1728 sub0 OK! Write Item: 1729 sub0 OK! Write Item: 1730 sub0 OK! Write Item: 1734 sub0 OK! Write Item: 1736 sub0 OK! Write Item: 1737 sub0 OK! Write Item: 1738 sub0 OK! Write Item: 1739 sub0 OK! Write Item: 1740 sub0 OK! Write Item: 1741 sub0 OK! Write Item: 1743 sub0 OK! Write Item: 1744 sub0 OK! Write Item: 1745 sub0 OK! Write Item: 1747 sub0 OK! Write Item: 1748 sub0 OK! Write Item: 1749 sub0 OK! Write Item: 1750 sub0 OK! Write Item: 1752 sub0 OK! Write Item: 1753 sub0 OK! Write Item: 1754 sub0 OK! Write Item: 1755 sub0 OK! Write Item: 1756 sub0 OK! Write Item: 1757 sub0 OK! Write Item: 1760 sub0 OK! Write Item: 1761 sub0 OK! Write Item: 1762 sub0 OK! Write Item: 1791 sub0 OK! Write Item: 1792 sub0 OK! Write Item: 1811 sub0 OK! Write Item: 1875 sub0 OK! Write Item: 1877 sub0 OK! Write Item: 1878 sub0 OK! Write Item: 1881 sub0 OK! Write Item: 1885 sub0 OK! Write Item: 1886 sub0 OK! Write Item: 1887 sub0 OK! Write Item: 1888 sub0 OK! Write Item: 1889 sub0 OK! Write Item: 1891 sub0 OK! Write Item: 1907 sub0 OK! Write Item: 1945 sub0 OK! Write Item: 1946 sub0 OK! Write Item: 1947 sub0 OK! Write Item: 1948 sub0 OK! Write Item: 1949 sub0 OK! Write Item: 1950 sub0 OK! Write Item: 1951 sub0 OK! Write Item: 1952 sub0 OK! Write Item: 1953 sub0 OK! Write Item: 1954 sub0 OK! Write Item: 1955 sub0 OK! Write Item: 1958 sub0 OK! Write Item: 2002 sub0 OK! Write Item: 2743 sub0 OK! Write Item: 2745 sub0 OK! Write Item: 2747 sub0 OK! Write Item: 2749 sub0 OK! Write Item: 2758 sub0 OK! Write Item: 2759 sub0 OK! Write Item: 2760 sub0 OK! Write Item: 2761 sub0 OK! Write Item: 2762 sub0 OK! Write Item: 2763 sub0 OK! Write Item: 2764 sub0 OK! Write Item: 2765 sub0 OK! Write Item: 2770 sub0 OK! Write Item: 2771 sub0 OK! Write Item: 2772 sub0 OK! Write Item: 2773 sub0 OK! Write Item: 2790 sub0 OK! Write Item: 2791 sub0 OK! Write Item: 2793 sub0 OK! Write Item: 2820 sub0 OK! Write Item: 2821 sub0 OK! Write Item: 2822 sub0 OK! Write Item: 2839 sub0 OK! Write Item: 2840 sub0 OK! Write Item: 2954 sub0 OK! Write Item: 3006 sub0 OK! Write Item: 3059 sub0 OK! Write Item: 3060 sub0 OK! Write Item: 3061 sub0 OK! Write Item: 3062 sub0 OK! Write Item: 3063 sub0 OK! Write Item: 3064 sub0 OK! Write Item: 3065 sub0 OK! Write Item: 3066 sub0 OK! Write Item: 3067 sub0 OK! Write Item: 3068 sub0 OK! Write Item: 3069 sub0 OK! Write Item: 3070 sub0 OK! Write Item: 3071 sub0 OK! Write Item: 3072 sub0 OK! Write Item: 3073 sub0 OK! Write Item: 3074 sub0 OK! Write Item: 3075 sub0 OK! Write Item: 3076 sub0 OK! Write Item: 3077 sub0 OK! Write Item: 3142 sub0 OK! Write Item: 3143 sub0 OK! Write Item: 3144 sub0 OK! Write Item: 3145 sub0 OK! Write Item: 3150 sub0 OK! Write Item: 3253 sub0 OK! Write Item: 3254 sub0 OK! Write Item: 3259 sub0 OK! Write Item: 3260 sub0 OK! Write Item: 3265 sub0 OK! Write Item: 3266 sub0 OK! Write Item: 3271 sub0 OK! Write Item: 3272 sub0 OK! Write Item: 3277 sub0 OK! Write Item: 3278 sub0 OK! Write Item: 3353 sub0 OK! Write Item: 3359 sub0 OK! Write Item: 3375 sub0 OK! Write Item: 3446 sub0 OK! Write Item: 3446 sub1 OK! Write Item: 3458 sub0 OK! Write Item: 3461 sub0 OK! Write Item: 3467 sub0 OK! Write Item: 3469 sub0 OK! Write Item: 3470 sub0 OK! Write Item: 3501 sub0 OK! Write Item: 3506 sub0 OK! Write Item: 3507 sub0 OK! Write Item: 3508 sub0 OK! Write Item: 3509 sub0 OK! Write Item: 3510 sub0 OK! Write Item: 3511 sub0 OK! Write Item: 3532 sub0 OK! Write Item: 3533 sub0 OK! Write Item: 3635 sub0 OK! Write Item: 3851 sub0 OK! Write Item: 4101 sub0 OK! Write Item: 4123 sub0 OK! Write Item: 4124 sub0 OK! Write Item: 4125 sub0 OK! Write Item: 4126 sub0 OK! Write Item: 4127 sub0 OK! Write Item: 4128 sub0 OK! Write Item: 4129 sub0 OK! Write Item: 4130 sub0 OK! Write Item: 4131 sub0 OK! Write Item: 4132 sub0 OK! Write Item: 4133 sub0 OK! Write Item: 4134 sub0 OK! Write Item: 4135 sub0 OK! Write Item: 4136 sub0 OK! Write Item: 4137 sub0 OK! Write Item: 4138 sub0 OK! Write Item: 4139 sub0 OK! Write Item: 4140 sub0 OK! Write Item: 4141 sub0 OK! Write Item: 4142 sub0 OK! Write Item: 4143 sub0 OK! Write Item: 4144 sub0 OK! Write Item: 4145 sub0 OK! Write Item: 4146 sub0 OK! Write Item: 4147 sub0 OK! Write Item: 4148 sub0 OK! Write Item: 4149 sub0 OK! Write Item: 4150 sub0 OK! Write Item: 4151 sub0 OK! Write Item: 4152 sub0 OK! Write Item: 4153 sub0 OK! Write Item: 4154 sub0 OK! Write Item: 4155 sub0 OK! Write Item: 4156 sub0 OK! Write Item: 4204 sub0 OK! Write Item: 4212 sub0 OK! Write Item: 4225 sub0 OK! Write Item: 4226 sub0 OK! Write Item: 4228 sub0 OK! Write Item: 4229 sub0 OK! Write Item: 4257 sub0 OK! Write Item: 4366 sub0 OK! Write Item: 4368 sub0 OK! Write Item: 4369 sub0 OK! Write Item: 4370 sub0 OK! Write Item: 4371 sub0 OK! Write Item: 4395 sub0 OK! Write Item: 4524 sub0 OK! Write Item: 4526 sub0 OK! Write Item: 4532 sub0 OK! Write Item: 4533 sub0 OK! Write Item: 4548 sub0 OK! Write Item: 4635 sub0 OK! Write Item: 4636 sub0 OK! Write Item: 4637 sub0 OK! Write Item: 4703 sub0 OK! Write Item: 4795 sub0 OK! Write Item: 4796 sub0 OK! Write Item: 4797 sub0 OK! Write Item: 4798 sub0 OK! Write Item: 4799 sub0 OK! Write Item: 4800 sub0 OK! Write Item: 4801 sub0 OK! Write Item: 4802 sub0 OK! Write Item: 4831 sub0 OK! Write Item: 4832 sub0 OK! Write Item: 4833 sub0 OK! Write Item: 4834 sub0 OK! Write Item: 4835 sub0 OK! Write Item: 4836 sub0 OK! Write Item: 4837 sub0 OK! Write Item: 4838 sub0 OK! Write Item: 4880 sub0 OK! Write Item: 4881 sub0 OK! Write Item: 4953 sub0 OK! Write Item: 4954 sub0 OK! Write Item: 4955 sub0 OK! Write Item: 4958 sub0 OK! Write Item: 4959 sub0 OK! Write Item: 4960 sub0 OK! Write Item: 4997 sub0 OK! Write Item: 4998 sub0 OK! Write Item: 4999 sub0 OK! Write Item: 5001 sub0 OK! Write Item: 5002 sub0 OK! Write Item: 5003 sub0 OK! Write Item: 5029 sub0 OK! Write Item: 5066 sub0 OK! Write Item: 5067 sub0 OK! Write Item: 5068 sub0 OK! Write Item: 5069 sub0 OK! Write Item: 5080 sub0 OK! Write Item: 5081 sub0 OK! Write Item: 5082 sub0 OK! Write Item: 5083 sub0 OK! Write Item: 5084 sub0 OK! Write Item: 5085 sub0 OK! Write Item: 5086 sub0 OK! Write Item: 5087 sub0 OK! Write Item: 5108 sub0 OK! Write Item: 5109 sub0 OK! Write Item: 5270 sub0 OK! Write Item: 5271 sub0 OK! Write Item: 5272 sub0 OK! Write Item: 5273 sub0 OK! Write Item: 5280 sub0 OK! Write Item: 5291 sub0 OK! Write Item: 5292 sub0 OK! Write Item: 5293 sub0 OK! Write Item: 5294 sub0 OK! Write Item: 5295 sub0 OK! Write Item: 5296 sub0 OK! Write Item: 5297 sub0 OK! Write Item: 5298 sub0 OK! Write Item: 5299 sub0 OK! Write Item: 5300 sub0 OK! Write Item: 5301 sub0 OK! Write Item: 5302 sub0 OK! Write Item: 5303 sub0 OK! Write Item: 5304 sub0 OK! Write Item: 5305 sub0 OK! Write Item: 5306 sub0 OK! Write Item: 5307 sub0 OK! Write Item: 5308 sub0 OK! Write Item: 5309 sub0 OK! Write Item: 5310 sub0 OK! Write Item: 5311 sub0 OK! Write Item: 5312 sub0 OK! Write Item: 5313 sub0 OK! Write Item: 5314 sub0 OK! Write Item: 5315 sub0 OK! Write Item: 5316 sub0 OK! Write Item: 5317 sub0 OK! Write Item: 5318 sub0 OK! Write Item: 5319 sub0 OK! Write Item: 5320 sub0 OK! Write Item: 5321 sub0 OK! Write Item: 5322 sub0 OK! Write Item: 5323 sub0 OK! Write Item: 5324 sub0 OK! Write Item: 5325 sub0 OK! Write Item: 5326 sub0 OK! Write Item: 5327 sub0 OK! Write Item: 5328 sub0 OK! Write Item: 5329 sub0 OK! Write Item: 5330 sub0 OK! Write Item: 5331 sub0 OK! Write Item: 5332 sub0 OK! Write Item: 5333 sub0 OK! Write Item: 5334 sub0 OK! Write Item: 5335 sub0 OK! Write Item: 5336 sub0 OK! Write Item: 5337 sub0 OK! Write Item: 5338 sub0 OK! Write Item: 5339 sub0 OK! Write Item: 5340 sub0 OK! Write Item: 5341 sub0 OK! Write Item: 5342 sub0 OK! Write Item: 5343 sub0 OK! Write Item: 5344 sub0 OK! Write Item: 5345 sub0 OK! Write Item: 5346 sub0 OK! Write Item: 5347 sub0 OK! Write Item: 5348 sub0 OK! Write Item: 5349 sub0 OK! Write Item: 5350 sub0 OK! Write Item: 5351 sub0 OK! Write Item: 5352 sub0 OK! Write Item: 5353 sub0 OK! Write Item: 5354 sub0 OK! Write Item: 5355 sub0 OK! Write Item: 5356 sub0 OK! Write Item: 5357 sub0 OK! Write Item: 5358 sub0 OK! Write Item: 5359 sub0 OK! Write Item: 5360 sub0 OK! Write Item: 5361 sub0 OK! Write Item: 5362 sub0 OK! Write Item: 5363 sub0 OK! Write Item: 5364 sub0 OK! Write Item: 5365 sub0 OK! Write Item: 5366 sub0 OK! Write Item: 5367 sub0 OK! Write Item: 5368 sub0 OK! Write Item: 5369 sub0 OK! Write Item: 5370 sub0 OK! Write Item: 5371 sub0 OK! Write Item: 5372 sub0 OK! Write Item: 5380 sub0 OK! Write Item: 5381 sub0 OK! Write Item: 5382 sub0 OK! Write Item: 5383 sub0 OK! Write Item: 5384 sub0 OK! Write Item: 5385 sub0 OK! Write Item: 5386 sub0 OK! Write Item: 5387 sub0 OK! Write Item: 5388 sub0 OK! Write Item: 5389 sub0 OK! Write Item: 5390 sub0 OK! Write Item: 5391 sub0 OK! Write Item: 5392 sub0 OK! Write Item: 5393 sub0 OK! Write Item: 5399 sub0 OK! Write Item: 5400 sub0 OK! Write Item: 5401 sub0 OK! Write Item: 5402 sub0 OK! Write Item: 5403 sub0 OK! Write Item: 5404 sub0 OK! Write Item: 5405 sub0 OK! Write Item: 5406 sub0 OK! Write Item: 5407 sub0 OK! Write Item: 5408 sub0 OK! Write Item: 5409 sub0 OK! Write Item: 5410 sub0 OK! Write Item: 5411 sub0 OK! Write Item: 5412 sub0 OK! Write Item: 5413 sub0 OK! Write Item: 5414 sub0 OK! Write Item: 5415 sub0 OK! Write Item: 5416 sub0 OK! Write Item: 5417 sub0 OK! Write Item: 5418 sub0 OK! Write Item: 5419 sub0 OK! Write Item: 5420 sub0 OK! Write Item: 5421 sub0 OK! Write Item: 5422 sub0 OK! Write Item: 5423 sub0 OK! Write Item: 5424 sub0 OK! Write Item: 5425 sub0 OK! Write Item: 5426 sub0 OK! Write Item: 5427 sub0 OK! Write Item: 5428 sub0 OK! Write Item: 5429 sub0 OK! Write Item: 5430 sub0 OK! Write Item: 5477 sub0 OK! Write Item: 5478 sub0 OK! Write Item: 5479 sub0 OK! Write Item: 5480 sub0 OK! Write Item: 5481 sub0 OK! Write Item: 5482 sub0 OK! Write Item: 5483 sub0 OK! Write Item: 5484 sub0 OK! Write Item: 5485 sub0 OK! Write Item: 5486 sub0 OK! Write Item: 5487 sub0 OK! Write Item: 5488 sub0 OK! Write Item: 5489 sub0 OK! Write Item: 5490 sub0 OK! Write Item: 5491 sub0 OK! Write Item: 5492 sub0 OK! Write Item: 5493 sub0 OK! Write Item: 5494 sub0 OK! Write Item: 5495 sub0 OK! Write Item: 5496 sub0 OK! Write Item: 5497 sub0 OK! Write Item: 5498 sub0 OK! Write Item: 5499 sub0 OK! Write Item: 5500 sub0 OK! Write Item: 5501 sub0 OK! Write Item: 5502 sub0 OK! Write Item: 5503 sub0 OK! Write Item: 5504 sub0 OK! Write Item: 5505 sub0 OK! Write Item: 5506 sub0 OK! Write Item: 5507 sub0 OK! Write Item: 5508 sub0 OK! Write Item: 5509 sub0 OK! Write Item: 5510 sub0 OK! Write Item: 5511 sub0 OK! Write Item: 5512 sub0 OK! Write Item: 5513 sub0 OK! Write Item: 5514 sub0 OK! Write Item: 5515 sub0 OK! Write Item: 5516 sub0 OK! Write Item: 5517 sub0 OK! Write Item: 5518 sub0 OK! Write Item: 5519 sub0 OK! Write Item: 5520 sub0 OK! Write Item: 5521 sub0 OK! Write Item: 5522 sub0 OK! Write Item: 5523 sub0 OK! Write Item: 5524 sub0 OK! Write Item: 5525 sub0 OK! Write Item: 5526 sub0 OK! Write Item: 5527 sub0 OK! Write Item: 5528 sub0 OK! Write Item: 5529 sub0 OK! Write Item: 5530 sub0 OK! Write Item: 5531 sub0 OK! Write Item: 5532 sub0 OK! Write Item: 5533 sub0 OK! Write Item: 5534 sub0 OK! Write Item: 5535 sub0 OK! Write Item: 5536 sub0 OK! Write Item: 5537 sub0 OK! Write Item: 5538 sub0 OK! Write Item: 5539 sub0 OK! Write Item: 5540 sub0 OK! Write Item: 5541 sub0 OK! Write Item: 5542 sub0 OK! Write Item: 5543 sub0 OK! Write Item: 5544 sub0 OK! Write Item: 5545 sub0 OK! Write Item: 5546 sub0 OK! Write Item: 5547 sub0 OK! Write Item: 5548 sub0 OK! Write Item: 5549 sub0 OK! Write Item: 5550 sub0 OK! Write Item: 5551 sub0 OK! Write Item: 5552 sub0 OK! Write Item: 5553 sub0 OK! Write Item: 5554 sub0 OK! Write Item: 5555 sub0 OK! Write Item: 5556 sub0 OK! Write Item: 5557 sub0 OK! Write Item: 5558 sub0 OK! Write Item: 5559 sub0 OK! Write Item: 5560 sub0 OK! Write Item: 5561 sub0 OK! Write Item: 5562 sub0 OK! Write Item: 5563 sub0 OK! Write Item: 5564 sub0 OK! Write Item: 5565 sub0 OK! Write Item: 5566 sub0 OK! Write Item: 5567 sub0 OK! Write Item: 5568 sub0 OK! Write Item: 5569 sub0 OK! Write Item: 5570 sub0 OK! Write Item: 5571 sub0 OK! Write Item: 5572 sub0 OK! Write Item: 5573 sub0 OK! Write Item: 5574 sub0 OK! Write Item: 5575 sub0 OK! Write Item: 5597 sub0 Fail!,istatus=0 Write Item: 5601 sub0 OK! Write Item: 5602 sub0 OK! Write Item: 5605 sub0 OK! Write Item: 5606 sub0 OK! Write Item: 5609 sub0 OK! Write Item: 5610 sub0 OK! Write Item: 5613 sub0 OK! Write Item: 5614 sub0 OK! Write Item: 5617 sub0 OK! Write Item: 5618 sub0 OK! Write Item: 5621 sub0 OK! Write Item: 5622 sub0 OK! Write Item: 5625 sub0 OK! Write Item: 5626 sub0 OK! Write Item: 5629 sub0 OK! Write Item: 5630 sub0 OK! Write Item: 5633 sub0 OK! Write Item: 5634 sub0 OK! Write Item: 5637 sub0 OK! Write Item: 5638 sub0 OK! Write Item: 5641 sub0 OK! Write Item: 5642 sub0 OK! Write Item: 5645 sub0 OK! Write Item: 5646 sub0 OK! Write Item: 5649 sub0 OK! Write Item: 5650 sub0 OK! Write Item: 5653 sub0 OK! Write Item: 5654 sub0 OK! Write Item: 5657 sub0 OK! Write Item: 5658 sub0 OK! Write Item: 5661 sub0 OK! Write Item: 5662 sub0 OK! Write Item: 5665 sub0 OK! Write Item: 5666 sub0 OK! Write Item: 5669 sub0 OK! Write Item: 5670 sub0 OK! Write Item: 5673 sub0 OK! Write Item: 5674 sub0 OK! Write Item: 5677 sub0 OK! Write Item: 5678 sub0 OK! Write Item: 5681 sub0 OK! Write Item: 5682 sub0 OK! Write Item: 5685 sub0 OK! Write Item: 5686 sub0 OK! Write Item: 5689 sub0 OK! Write Item: 5690 sub0 OK! Write Item: 5693 sub0 OK! Write Item: 5694 sub0 OK! Write Item: 5697 sub0 OK! Write Item: 5698 sub0 OK! Write Item: 5699 sub0 OK! Write Item: 5700 sub0 OK! Write Item: 5722 sub0 OK! Write Item: 5723 sub0 OK! Write Item: 5738 sub0 OK! Write Item: 5739 sub0 OK! Write Item: 5754 sub0 OK! Write Item: 5755 sub0 OK! Write Item: 5880 sub0 OK! Write Item: 6342 sub0 OK! Write Item: 6343 sub0 OK! Write Item: 6344 sub0 OK! Write Item: 6345 sub0 OK! Write Item: 6346 sub0 OK! Write Item: 6347 sub0 OK! Write Item: 6348 sub0 OK! Write Item: 6349 sub0 OK! Write Item: 6350 sub0 OK! Write Item: 6351 sub0 OK! Write Item: 6352 sub0 OK! Write Item: 6353 sub0 OK! Write Item: 6354 sub0 OK! Write Item: 6355 sub0 OK! Write Item: 6356 sub0 OK! Write Item: 6357 sub0 OK! Write Item: 6472 sub0 OK! Write Item: 6473 sub0 OK! Write Item: 6474 sub0 OK! Write Item: 6475 sub0 OK! Write Item: 6476 sub0 OK! Write Item: 6477 sub0 OK! Write Item: 6861 sub0 OK! Write Item: 6876 sub0 OK! Resetting phone... NV Restore Finished! | |
