Various CDMA/TDMA Cell Phones All CDMA & TDMA Cell Phones Related Threads are here |
01-08-2009, 05:55 | #1 (permalink) |
No Life Poster Join Date: May 2008
Member: 774169 Status: Offline Thanks Meter: 123 | samsung 109 killed while flashing . i was trying to unlock s109 with unlokced bin . the bin is tested one . i did that ealier with the same bin file . at 2% it stopped . now the phone says " download error ! download again " is there any way to revive that . when it again try to flash the phone its giving " auto test error" is tehre any way to revive the phone regards [email protected] |
01-11-2009, 18:27 | #9 (permalink) |
Registered User Join Date: Jun 2007 Location: KOLKATA, INDIA Age: 53
Member: 535330 Status: Offline Thanks Meter: 20 | Yes, my seniors are right. As per your information, your handset now is not dead state. You can easily reboot it. open samsung pst, select file (you can select also the unlock bin file to unlock the provider lock at a time), select emergency, select comport, press pwr+8 and your phone will go to emergency mode manually that you can see at your phone lcd. click start software download. after flashing if any problem persist then rebuild once. It must must be ok. |
10-06-2009, 18:20 | #11 (permalink) |
Freak Poster Join Date: Feb 2008 Location: DONT REMEMBER
Member: 712290 Status: Offline Thanks Meter: 62 | Auto test error In mostly cases auto test appear in handset when cable is damaged or not working well and mostly handset goes blinking .......... SO CHANGE THE CABLE TO NEW ONE Its all experience based |
samsung e250d error while flashing.. | SicilianBoy | NSPRO | 4 | 12-21-2008 12:36 |
samsung a200 error while flashing | roy_naber | Samsung Flashers, Software, Firmware. | 1 | 11-08-2008 14:13 |
Samsung F300 freeze while flashing | Hellosamir | Samsung Flashers, Software, Firmware. | 2 | 05-02-2007 08:54 |
Lg- U880 ACCIDENTALLY KILLED WHILE FLASHING | ber747 | LG | 1 | 02-11-2007 08:22 |
Samsung x450 error while flashing | Gr8SightMan | Twisterflasher | 0 | 01-01-2006 14:00 |
