Various CDMA/TDMA Cell Phones All CDMA & TDMA Cell Phones Related Threads are here |
01-06-2012, 08:31 | #1 (permalink) |
Freak Poster Join Date: Nov 2008 Location: LUCKNOW Age: 43
Member: 907684 Status: Offline Sonork: ASEEM_CHANDRA2008 Thanks Meter: 70 | spice c-3300 phone locked please contact service center |
01-06-2012, 08:59 | #2 (permalink) | |
Freak Poster Join Date: Feb 2007
Member: 455684 Status: Offline Thanks Meter: 79 | Quote:
i have allready posted this solution on this forum pls chak thnx and regards rahul jain [email protected] | |
01-06-2012, 15:37 | #3 (permalink) | |
No Life Poster Join Date: Oct 2009 Location: India [UNKNOWN]
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | Quote:
HERE IS SOLUTION BY vicky_42_42_42 http://forum.gsmhosting.com/vbb/7554732-post1.html | |
01-06-2012, 17:06 | #6 (permalink) |
No Life Poster Join Date: Oct 2006 Location: RAJASTHAN JAIPUR Age: 45
Member: 379001 Status: Online Sonork: 100.1606686 Thanks Meter: 494 | Here is tested selution 1000000000000000%%%%%%% HERE IS TESTED EXTRET THIS RAR FILE AND PUT THIS INI FILE AND FLASH AGAIN 10000000000000000000000000% SET OK THAN DIAL UNLOCK CODE C:\Program Files\Huntel Technologies\CDMA Phone Test System\software download WBR NKSONU THANKS TO VICKY |
The Following User Says Thank You to nksonu_jobner For This Useful Post: |
01-07-2012, 15:53 | #13 (permalink) |
Member: 907684 Status: Offline Sonork: ASEEM_CHANDRA2008 Thanks Meter: 70 | Auto backuping memory from phone C:\Program Files\Huntel Technologies\CDMA Phone Test System\software download\NV Backup\QSC11X0\A100001A59DE5A.nvm Backuping NV Item ID = 0 ... Backuping NV Item ID = 1943 ... Backuping NV Item ID = 4795 ... Backuping NV Item ID = 4796 ... Backuping NV Item ID = 4831 ... Backuping NV Item ID = 4832 ... Backuping NV Item ID = 4997 ... Backuping NV Item ID = 4998 ... Backuping NV Item ID = 1724 ... Backuping NV Item ID = 5722 ... Backuping NV Item ID = 5738 ... Backuping NV Item ID = 5754 ... Backuping NV Item ID = 1749 ... Backuping NV Item ID = 1750 ... Backuping NV Item ID = 1743 ... Backuping NV Item ID = 1744 ... Backuping NV Item ID = 1745 ... Backuping NV Item ID = 1739 ... Backuping NV Item ID = 1740 ... Backuping NV Item ID = 1741 ... Backuping NV Item ID = 3265 ... Backuping NV Item ID = 4799 ... Backuping NV Item ID = 4800 ... Backuping NV Item ID = 4835 ... Backuping NV Item ID = 4836 ... Backuping NV Item ID = 5001 ... Backuping NV Item ID = 5002 ... Backuping NV Item ID = 1635 ... Backuping NV Item ID = 5723 ... Backuping NV Item ID = 5739 ... Backuping NV Item ID = 5755 ... Backuping NV Item ID = 1670 ... Backuping NV Item ID = 1671 ... Backuping NV Item ID = 1654 ... Backuping NV Item ID = 1655 ... Backuping NV Item ID = 1666 ... Backuping NV Item ID = 1650 ... Backuping NV Item ID = 1651 ... Backuping NV Item ID = 1652 ... Backuping NV Item ID = 3266 ... Backuping NV Item ID = 4811 ... Backuping NV Item ID = 4812 ... Backuping NV Item ID = 4847 ... Backuping NV Item ID = 4848 ... Backuping NV Item ID = 5009 ... Backuping NV Item ID = 5010 ... Backuping NV Item ID = 1400 ... Backuping NV Item ID = 5727 ... Backuping NV Item ID = 5743 ... Backuping NV Item ID = 5759 ... Backuping NV Item ID = 1425 ... Backuping NV Item ID = 1426 ... Backuping NV Item ID = 1419 ... Backuping NV Item ID = 1420 ... Backuping NV Item ID = 1421 ... Backuping NV Item ID = 1415 ... Backuping NV Item ID = 1416 ... Backuping NV Item ID = 1417 ... Backuping NV Item ID = 3269 ... Backuping NV Item ID = 61440 ... Backuping NV Item ID = 5 ... Backuping NV Item ID = 10 ... Backuping NV Item ID = 20 ... Backuping NV Item ID = 21 ... Backuping NV Item ID = 32 ... Backuping NV Item ID = 33 ... Backuping NV Item ID = 34 ... Backuping NV Item ID = 35 ... Backuping NV Item ID = 36 ... Backuping NV Item ID = 37 ... Backuping NV Item ID = 43 ... Backuping NV Item ID = 85 ... Backuping NV Item ID = 176 ... Backuping NV Item ID = 177 ... Backuping NV Item ID = 178 ... Backuping NV Item ID = 179 ... Backuping NV Item ID = 256 ... Backuping NV Item ID = 258 ... Backuping NV Item ID = 259 ... Backuping NV Item ID = 262 ... Backuping NV Item ID = 263 ... Backuping NV Item ID = 264 ... Backuping NV Item ID = 265 ... Backuping NV Item ID = 285 ... Backuping NV Item ID = 298 ... Changing the Phone to Download Mode Transition to Download Mode Successfully Waiting for open serial port after change phone to Download mode... Waiting for phone's responsion... Sending Flash Programmer File to SRAM Flash Programming File loaded Successfully Attempting to run Flash Programmer Begin executive flash programming file Successfully Flash Programming File loaded Successfully Loading selected image file... Begining to Writing boot area... Writing BOOT Area successfully! Beginning Flash Part Erase Step Flash NO.3 block erased successfully Flash NO.4 block erased successfully Flash NO.5 block erased successfully Flash NO.6 block erased successfully Flash NO.7 block erased successfully Flash NO.8 block erased successfully Flash NO.9 block erased successfully Flash NO.10 block erased successfully Flash NO.11 block erased successfully Flash NO.12 block erased successfully Flash NO.13 block erased successfully Flash NO.14 block erased successfully Flash NO.15 block erased successfully Flash NO.16 block erased successfully Flash NO.17 block erased successfully Flash NO.18 block erased successfully Flash NO.19 block erased successfully Flash NO.20 block erased successfully Flash NO.21 block erased successfully Flash NO.22 block erased successfully Flash NO.23 block erased successfully Flash NO.24 block erased successfully Flash NO.25 block erased successfully Flash NO.26 block erased successfully Flash NO.27 block erased successfully Flash NO.28 block erased successfully Flash NO.29 block erased successfully Flash NO.30 block erased successfully Flash NO.31 block erased successfully Flash NO.32 block erased successfully Flash NO.33 block erased successfully Flash NO.34 block erased successfully Flash NO.35 block erased successfully Flash NO.36 block erased successfully Flash NO.37 block erased successfully Flash NO.38 block erased successfully Flash NO.39 block erased successfully Flash NO.40 block erased successfully Flash NO.41 block erased successfully Flash NO.42 block erased successfully Flash NO.43 block erased successfully Flash NO.44 block erased successfully Flash NO.45 block erased successfully Flash NO.46 block erased successfully Flash NO.47 block erased successfully Flash NO.48 block erased successfully Flash NO.49 block erased successfully Flash NO.50 block erased successfully Flash NO.51 block erased successfully Flash NO.52 block erased successfully Flash NO.53 block erased successfully Flash NO.54 block erased successfully Flash NO.55 block erased successfully Flash NO.56 block erased successfully Flash NO.57 block erased successfully Flash NO.58 block erased successfully Flash NO.59 block erased successfully Flash NO.60 block erased successfully Flash NO.61 block erased successfully Flash NO.62 block erased successfully Flash NO.63 block erased successfully Flash NO.64 block erased successfully Flash NO.65 block erased successfully Flash NO.66 block erased successfully Flash NO.67 block erased successfully Flash NO.68 block erased successfully Flash NO.69 block erased successfully Flash NO.70 block erased successfully Flash NO.71 block erased successfully Flash NO.72 block erased successfully Flash NO.73 block erased successfully Flash NO.74 block erased successfully Flash NO.75 block erased successfully Flash NO.76 block erased successfully Flash NO.77 block erased successfully Flash NO.78 block erased successfully Flash NO.79 block erased successfully Flash NO.80 block erased successfully Flash NO.81 block erased successfully Flash NO.82 block erased successfully Flash NO.83 block erased successfully Flash NO.84 block erased successfully Flash NO.85 block erased successfully Flash NO.86 block erased successfully Flash NO.87 block erased successfully Flash NO.88 block erased successfully Flash NO.89 block erased successfully Flash NO.90 block erased successfully Flash NO.91 block erased successfully Flash NO.92 block erased successfully Flash NO.93 block erased successfully Flash NO.94 block erased successfully Flash NO.95 block erased successfully Flash NO.96 block erased successfully Flash NO.97 block erased successfully Flash NO.98 block erased successfully Flash NO.99 block erased successfully Flash NO.100 block erased successfully Flash NO.101 block erased successfully Flash NO.102 block erased successfully Flash NO.103 block erased successfully Flash NO.104 block erased successfully Flash NO.105 block erased successfully Flash NO.106 block erased successfully Flash NO.107 block erased successfully Flash NO.108 block erased successfully Flash NO.109 block erased successfully Flash NO.110 block erased successfully Flash NO.111 block erased successfully Flash NO.127 block erased successfully Flash NO.128 block erased successfully Flash NO.129 block erased successfully Flash NO.130 block erased successfully Flash NO.131 block erased successfully Flash NO.132 block erased successfully Flash NO.133 block erased successfully Flash NO.134 block erased successfully Downloading selected image file to flash, please waiting... Download Completed in 2 minutes 8 seconds set phir bhi phone locked please contact service center hai |
01-07-2012, 16:00 | #14 (permalink) |
Member: 907684 Status: Offline Sonork: ASEEM_CHANDRA2008 Thanks Meter: 70 | Auto backuping memory from phone C:\Program Files\Huntel Technologies\CDMA Phone Test System\software download\NV Backup\QSC11X0\A100001A59DE5A.nvm Backuping NV Item ID = 0 ... Backuping NV Item ID = 1943 ... .................................................. ... Flash NO.134 block erased successfully Downloading selected image file to flash, please waiting... Download Completed in 2 minutes 8 seconds set phir bhi phone locked please contact service center hai . kese hoga...........only fake solution |
01-07-2012, 21:15 | #15 (permalink) | |
Insane Poster Join Date: Jan 2011 Location: BWR
Member: 1485947 Status: Offline Thanks Meter: 23 | Quote:
and please read nksonu posting go to c drive > program file >Huntel Technologies >CDMA Phone Test System >software download and past this MultiDloaderStrategy.rar file | |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
SP Lock 1&4 | dw | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 11 | 06-26-1999 06:22 |
