01-04-2005, 12:55 | #3 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 47
Member: 58704 Status: Offline Sonork: 100.1618753 Thanks Meter: 43 | hi mate that phone izzit water demaged??that not chaging is the track VBAAT go C105 broken.then the no network u cantry to reflo the hold tx/rx part. |
01-07-2005, 20:19 | #4 (permalink) |
Freak Poster Join Date: Aug 2003 Location: PORT HARCOURT,NIGERIA. Age: 54
Member: 36906 Status: Offline Thanks Meter: 1 | what is your discovery what have you diagnoze...? when you do a manual search on network,does it shows network sign ,or if you power phone network will come and go before the light goes off. Then have you check the fuse 'k' that controls the + in at the charging base and the resistor beside it.Lets know your discovery. |
01-18-2005, 13:46 | #6 (permalink) | |
No Life Poster Join Date: Jul 2004 Age: 46
Member: 74084 Status: Offline Thanks Meter: 8 | Quote:
but file .WUG for 2100 is necessary when I flash it with Twister? Because all flash is ok, but the phone has not network! Thanks | |
01-20-2005, 07:12 | #7 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Tirupati-India Age: 49
Member: 48156 Status: Offline Thanks Meter: 127 | 2100 help hi 2100 contact service after flash set will ok but NOCALL LIST& REDAIL LIST i will up& down grade all5.11v to 5.78 the problem will same i am changing flash ic also the fault will same ARGENT....................PLY |
Nokia 7100sn no network and no SIM | jlec1 | Nokia Hardware & Hardware Repair | 0 | 03-18-2010 13:33 |
7260 no speaker and not charging | vishal123123 | Nokia Hardware & Hardware Repair | 4 | 10-15-2007 13:28 |
N80 after unlock no network and not charge | F@RUK S | MT-BOX | 22 | 09-28-2007 18:02 |
Nokia 5140 no network and charge? | jhoncybpr | Nokia Hardware & Hardware Repair | 0 | 08-28-2006 19:17 |
Nokia 6270 no network and restart problem | haider | Nokia Hardware & Hardware Repair | 1 | 07-12-2006 16:25 |
