02-01-2004, 14:30 | #1 (permalink) |
No Life Poster Join Date: Apr 2000 Location: India, China
Member: 44158 Status: Offline Sonork: 100.64344 Thanks Meter: 143 | 2100 reboot after every 10 sec i have got one 2100 which reboots after every 10 sec when the sim card is inserted , i tried full flash but prob. didnt solved , set is new inside , any solutions? |
02-02-2004, 11:16 | #4 (permalink) | |
Member: 44158 Status: Offline Sonork: 100.64344 Thanks Meter: 143 | Quote:
yes i tried full flash from 0020000-00400000 with geo flasher & tried with ufs also mcu ppm eep but same result | |
02-03-2004, 13:07 | #7 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Kenya,Mombasa
Member: 40758 Status: Offline Thanks Meter: 26 | Thats 100% hardware problem just wash your pc with white spirit and reflow the cobba,hagar and flash ic but be very careful with the flash ic good luck it works for me well Shadow27 |
02-07-2004, 16:30 | #8 (permalink) |
No Life Poster Join Date: Aug 2003 Location: Bangladesh
Member: 37349 Status: Offline Sonork: 100.1613413 Thanks Meter: 362 | @honey, it is software pb & i already repaired a lot of set like your pb.did you tried by write flsh & eeprom files indivigually?if not then you can use free Geoflasher software.if you need total solution contac with me. proxy_gsm@hotmail. proxy_gsm |
02-08-2004, 08:49 | #9 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | @like Shadow27 saw - this is mostly HW problem with bad cobbas (China maded and used in Hungary assembled 2100 phones!) |
02-09-2004, 11:37 | #12 (permalink) | |
No Life Poster Join Date: Jan 2002 Location: MARS
Member: 8304 Status: Offline Thanks Meter: 362 | Quote:
02-22-2004, 14:09 | #15 (permalink) |
Freak Poster Join Date: May 2003 Location: MADAGASCAR Age: 42
Member: 28378 Status: Offline Thanks Meter: 3 | I solved this problem on many 2100, using this following solution: 1/ Flash a FULL FLASH from a good 2100 ( version 5.41 . 5.49 ...) using a flasher, for me it is knok. 2/After flash, the 2100 will still in contact service; click on set IMEI, use original IMEI;then quick set FAID,then set SP locks to defaults. 3/ now, the 2100 will work, sometimes, it's working without prob, sometimes, the 2100 will ask for security code, after entering 12345, the 2100 will not find the network and restart after 10s, then displays SIM card not accepted... To fix it, 1/ After unlock, insert a SIM card, enter the security code (12345), go to the menu, restore factory settings, now the 2100 will not ask for any more security code but still not able to catch the network. 2/ Go to parameters, Network selection, choose manual, Then the 2100 will display all available network, choose your home network, and then it should be OK. If the 2100 restart before it displays the list of networks, just re-unlock it and research for network again (it wouldn't ask for any more security code). BR |
Samsung X480 Reboot After Every Incoming/outgoing Call-flashed-still Same Problem | zonetrichur | UST Pro II | 0 | 06-16-2007 19:21 |
N70 display Flicks after every 10 sec | Softway | Nokia Hardware & Hardware Repair | 1 | 04-26-2007 16:40 |
t630 restart every 10 sec!! | ashvin | Cruiser Suite | 4 | 02-28-2006 04:02 |
2100 Screen Goes blank after 10 Sec | zakiyyboss | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 02-21-2006 04:52 |
6510 looses network after 5-10 secs | laxxe | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 09-11-2002 04:16 |
