-   Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) (http://forum.gsmhosting.com/vbb/f131/)
-   -   3210 flash and eeprom dump needed (http://forum.gsmhosting.com/vbb/f131/3210-flash-eeprom-dump-needed-3501/)
sigkill 08-20-2001 15:04
i'm looking 4 3210 full flash (00200000-00400000)<br />and eeprom dump from the same phone <br />better older version ...<br />to repair "contact-service"
[email protected]
maus 08-21-2001 00:11
what soft version/languagepack?
sigkill 08-21-2001 19:14
version 4.41 PPM 4.41B
aZyWeRks 08-22-2001 07:29
how do you plan to accomplish this? you can't just copy eeprom and flash from another unit and expect that to work. You will get all locks closed. If you want to fix the contact service, you can try checking first if the imei is intact.
if IMEI is damaged, usually the problem is hardware, otherwise it is just the eeprom. since you are asking for an eeprom copy, i assume you have an eeprom burner, ohterwise, the eeprom you are asking for is useless.
if you can download the eeprom, use repairer by guar or bartek to fix the contact service problem.
<br />regards,
aCe
sigkill 08-22-2001 12:30
i tried with bartec and guar repair but no <br />result imei destroied and not only that...<br />i dont have m-bus and f-bus communication <br />can't read with wintesla and pc-locals <br />only with nokia Dl and Jethro ....<br />i have eeprog and if u dont have i can make one for u <img src="smile.gif" border="0"> ))<br />so does anybody have dump and flash from 3210...?<br />i 'will get 4 lock close only if use <br />form different phones ....<br />i need eeprom and flash from ONE unit ...!
Page generated in 0.16394 seconds with 5 queries
